הוסף תרגום לתוסף
סיכום מבוסס בינה מלאכותית
Pad_Pors outlines the process for adding translations to a Discourse plugin. The guide begins by navigating to the plugin’s GitHub repository and locating the /config/locales directory, which contains yml files such as client.en.yml and server.en.yml. The author emphasizes that the client-side file is the priority for translation, as server-side strings are typically only visible to administrators. To translate, users should create a new file, copy the contents of the English file, and rename the locale identifier on the first line (e.g., changing en to fa_IR for Persian). The text strings within quotes are then translated, and the file is saved with a new name reflecting the target language (e.g., client.fa.yml). Finally, a pull request must be submitted for the plugin owner to review and merge. Pad_Pors notes that while other guides exist, this summary is based on their personal experience and references a related topic on meta.discourse.org for further details.
  1. go to the github repository of the plugin, e. g. discourse-canned-replies.
  • go to /config/locales folder of the plugin. you should see some yml files, like client.en.yml and server.en.yml.
  • the client file is for the text parts in client side and is more important to be translated. texts in server file are only shown to admins.
  • open the English yml file, as we want to first translate this file.
  • press create new file button.
  • copy the text in client.en.yml into the new file.
  • change the first line from en to the proper locale name in discourse. e.g. I want to translate it to Persian, the correct locale name would be fa_IR.
  • now translate the strings between quotations " to your preferred language.
  • save the file into another file named client.fa.yml, if you’re translating it into German the name would be something like this client.de.yml.
  • fill out the information for the file like: Persian translation of client.en.yml.
  • then you should add a pull request, and wait for the plugin owner to accept it.
BTW, there are other topics which show the way for this, but as I didn’t find it in howto just added my own experience: https://meta.discourse.org/t/how-to-add-plugin-translations/19890?u=pad_pors
14 לייקים
