You can add various pieces of metadata to a theme. Some are stored in the about.json file, and some are stored in the locale files.
about.json
file format info
name (string, required): The default name for the theme when installed. This can be changed by admins after the theme is installed.
component (boolean, default false): whether the theme should be treated as a component.
license_url (string, optional): a URL for a license file. A link to this will be displayed in the admin interface. Most themes use this to link to their license file on GitHub.
about_url (string, optional): a URL which contains more information about the theme. A link to this will be displayed in the admin interface. Most themes use this to link to their Meta topic.
authors (string, optional): A string to describe the author of the theme. Displayed in the admin interface.
theme_version (string, optional): An arbitrary string to describe the version of the theme. Displayed in the admin interface.
screenshots (array, optional): Up to two screenshot paths which will be used in various places of the UI to display screenshots of the theme. See below for more detail on restrictions.
minimum_discourse_version (string, optional): the earliest discourse version which this theme is compatible with. If it does not match, the theme will be auto-disabled. Should be in the format 2.4.0.beta1.
maximum_discourse_version (string, optional): the latest discourse version which this theme is compatible with. If it does not match, the theme will be auto-disabled. Should be in the format 2.4.0.beta1.
locale files (e.g. en.yml)
file format info
theme_metadata.description: A localised description of the theme. Displayed in the admin interface.
theme_metadata.settings.setting_name: A localised description of setting_name, displayed below the theme setting in the admin panel.
Screenshots
Themes and components can define a maximum of two screenshots in the screenshots key of about.json, which will look something like this:
"screenshots": ["screenshots/light.webp", "screenshots/dark.webp"]
Keep these restrictions in mind:
- Screenshots must be in a
screenshotsfolder in the theme’s GitHub repo - Max file size:
1 MB - Max resolution:
3840×2160(4K) - Recommended ratio:
16:9 - Allowed formats:
We also follow a convention to include both light and dark screenshots.
This document is version controlled - suggest changes on github.
