Discourse themainstellingen migreren
Introduction
As of Discourse version 3.2.0.beta3, Discourse themes/components can leverage a migrations feature to evolve and alter their settings seamlessly. This feature ensures that updates to themes do not disrupt existing installations by handling changes to settings in a controlled manner.
When to Use Migrations
Common scenarios where migrations are particularly useful:
  • Changing the type of a setting (e.g., from a comma-separated string to a list).
  • Renaming a setting.
  • Modifying the structure or format of the data stored in a setting.
In these scenarios, if the setting type or name is changed in the settings.yml file without an accompanying migration, existing installations where the setting has been changed from the default value, they will lose the change they’ve made to the setting and potentially break when the theme is updated.
To ensure smooth transition when updating a theme setting, theme developers should ship a migration that instructs Discourse core how to migrate existing state that conforms to the old version of the settings.yml to the new version.
Migration Files
Migrations are JavaScript files located in the migrations/settings directory of the theme, following the naming convention XXXX-migration-name.js. The XXXX prefix is a version number, starting from 0001 and incrementing sequentially, which dictates the order of execution.
The name should be a concise description of the migration’s purpose, limited to alphanumeric characters, hyphens, and under 150 characters in length. Migrations are executed in ascending order based on the numerical value of their versions.
We recommend that you start with 0001 for the first migration and 0002 for the second migration etc. Note that if a migration’s version is below 1000, then the version must be padded with leading zeros to make it 4 digits long since migration filename must start with 4 digits. For the same reason, it’s not currently possible to have more than 9999 migrations in a theme, but we may change that in the future.
Migration Function
Standard JavaScript features such as classes, functions, arrays, maps etc. are all available for migrations to use. The only expectation from Discourse core is that each migration file must export a default function that serves as the entry point. This function receives a Map object representing modified theme settings and returns a Map object reflecting the desired final state of all settings.
Examples
Rename a theme setting:
// filename: 0001-rename-old-setting.js
export default function migrate(settings) {
  if (settings.has("old_setting_name")) {
    settings.set("new_setting_name", settings.get("old_setting_name"));
    settings.delete("old_setting_name");
  return settings;
This migration should be accompanied with the setting rename in the settings.yml file.
Convert a comma-separated string setting to a proper list:
// filename: 0001-convert-string-setting-to-list.js
  if (settings.has("list_setting")) {
    const list = settings.get("list_setting").split(",");
    settings.set("list_setting", list.join("|"));
  return settings;
Similar to the previous example, this migration should be accompanied with changing the setting type from string to list in the settings.yml file.
Rename a choice of an enum setting:
// filename: 0001-rename-enum-choice.js
  if (settings.get("enum_setting") === "old_option") {
    settings.set("enum_setting", "new_option");
  return settings;
Add a new item to a list setting:
// filename: 0001-add-item-to-list.js
    const list = settings.get("list_setting").split("|");
    list.push("new_item");
  } else {
    settings.set("list_setting", "new_item");
  return settings;
Move a text setting to a theme translation
Use helpers.migrateSettingToTranslation(settingName, translationKey) when replacing a string setting with a theme translation:
// filename: 0002-migrate-heading.js
export default function migrate(settings, helpers) {
  helpers.migrateSettingToTranslation("heading_text", "homepage.heading");
  return settings;
Remove heading_text from settings.yml and declare the destination in locales/en.yml in the same update:
en:
  homepage:
    heading: ""
The helper moves a saved setting into an English theme translation override and removes the setting. English is the fallback locale for other languages, so visitors keep seeing the saved text until a translation for their locale is supplied. A locale file that declares the same key, even with an empty value, hides that saved English text for its locale. This also applies to locale files added in future updates.
  • The helper reads from the settings map passed to the migration. Only saved settings are migrated. If the old setting had a non-empty default, use that default in en.yml so sites without a saved value keep their text.
  • The setting value must be a string and the destination must be a declared text key. Empty strings are preserved.
  • Existing English overrides, including empty ones, are not overwritten. If multiple migrations target the same key, the first migrated value wins.
  • The runner stages translation changes without writing to the database. Discourse saves them in the same transaction as the settings and migration records; a failed update rolls everything back.
  • The migration log retains the deleted setting’s value. Reverting the theme code does not move translation overrides back into settings.
Execution and Error Handling
Migrations run automatically during theme installation and updates. They execute only once; if a migration is altered after successful execution, it will not run again. If a migration fails, the update process stops, and an error message of what went wrong is provided.
If a migration has a bug that results in corrupt state for a setting, then the correct way to fix the problem is to create a new migration that corrects the corrupt state instead of modifying the original migration.
This document is version controlled - suggest changes on github.
