Discourse Authentication Validations
The Discourse Authentication Validations plugin, introduced by isaac, allows administrators to add custom regex validations to User Fields and chain fields together to toggle their visibility on the Signup Modal. While the plugin is widely praised for its flexibility, the discussion highlights several critical issues and feature requests.
Users kravitsjacob and RGJ reported bugs where conditional logic fails on invite-only signups and where hidden required fields still save data or block form submission if they are technically required but invisible. Yan_Rudenko addressed the saving issue by submitting a fix for both frontend and backend validation PR and later enhanced the chaining logic to support multiple values per field PR. Additionally, jordanjay29 raised a concern regarding how conditional fields interact with the “Searchable” setting in the User Directory configuration.
The original author, isaac, acknowledged these issues and noted that broader adoption within Discourse core would require fixing the invite link logic. The thread concludes with a query from asc regarding the plugin’s potential use for age validation to block users under 18.
:discourse2: Summary Discourse Authentication Validations enables the ability to add custom validations to a User Field to toggle the display of User Fields on the Signup Modal.
:hammer_and_wrench: Repository Link https://github.com/discourse/discourse-authentication-validations
:open_book: Install Guide How to install plugins in Discourse
:information_source: About
Discourse Authentication Validations adds the ability to add custom validations to a User Field.
Custom User Fields do not have any type of validation provided by core, outside of detecting an empty value on a required field. This plugin adds the ability to define a regex, per user field, that will then be checked against the provided input value.
Additionally, this plugin adds the ability to toggle the display of User Fields on the Signup Modal. This allows you to “chain” User Fields together, so that a User Field is only displayed if a previous User Field has a specific value.
:building_construction: Basic Setup
1. Enable Plugin
The Discourse Authentication Validations plugin can be enabled either by the toggle or from its settings, both accessible from your admin/plugins page.
2. Add a custom validation to a User Field
After the Discourse Authentication Validations plugin has been enabled you will see a Include a Custom Validations checkbox at the bottom of your User Field form.
When checked it will display an additional three fields:
  1. Value Validation Regex
  2. Show Values
  3. Target User Fields
:closed_lock_with_key: Adding a Custom Validation
Include a valid regex in the Value Validation Regex field:
The user field’s value on the signup form will now be tested against the regex you have included. In the case that the input does not meet the standards of your custom Regex, the signup form will not submit.
No value (relies on default form validation)
Incorrect value
Correct value
:link: Chaining User Fields
Firstly, include a Show Values value on a User Field.
When a User Field has a Show Values value included it will watch the value of the attached input until the input value matches ANY of the show values. It will then toggle the visibility of any included Target User Fields, making them visible.
Secondly, add a Target User Fields value.
In the Target User Fields dropdown you will see a list of all available User Fields. Any User Field you select will have their visibility toggled by corresponding values in Show Values.
:hammer_and_wrench: Advanced Chaining
You can chain User Fields together by adding custom validations to multiple User Fields.
For example, let’s say we have three User Fields with the given values:
Name Has Custom Validation Show Values Target User Fields
Input One true show-field-two Input Two
Input Two true show-field-three Input Three
Input Three false
Input Two and Three will be hidden by default as they are “children” of Input One. When the show value of show-field-two is added to Input One, Input Two will be displayed, but Input Three will still remain hidden. It will remain hidden until Input Two has the value of show-field-three.
With the correct combination of Show Values and Target Classes you can infinitely nest User Fields beneath each other.
Hello @isaac.
I love this plugin, it’s exactly what I need! Is this still being maintained? I am having trouble with the “chaining” functionality.
I followed the example above using:
But it is showing all the fields by default… I apologize if I missed something in the writeup!
My apologies for this - the plugin is working. However, it does not work if you are viewing through an “invite” sign up link. It does work if you are using a public signup page.
Could be a nice feature to have the logic work for both invite and public sign up!
Great job with the plugin!
I very much agree. @tobiaseigen if we were to adopt this plugin as a feature more broadly, we would want to have the logic work in both places (public/invite) as @kravitsjacob has pointed out.
Hello @isaac. Thank you once again for this amazing plugin - it really has opened up so many discourse opportunities for me.
I ran into a little bug - I noticed that question responses are saved, even if a question is hidden. This has led to a few unintended situations where users are submitting response that shouldn’t really be possible (hence why we wanted to hide the questions in the first place). This behavior also causes another situation where when a question is double nested, it still appears even though the parent response has been deselected (because it still thinks the triggering answer is selected). I know this description is a big vague, so here is a gif highlighting this behavior:
auth null bug
I think my desired fix would be to reset the responses to the null value once they are no longer visible. This could also be “opt-in” behavior that is configurable by the person setting up the form - I could see different philosophies existing on whether responses should persist when going down these trees.
Would you be able to implement this? :pray:
Thank you for the detailed response! I will take a look at this next week :slight_smile:
I had the opportunity to look at these issues today :slight_smile:
https://github.com/discourse/discourse-authentication-validations/pull/23
Please read the PR description for details!
It is currently impossible to have an optional required field.
I have a field “Industry” and whenever “Other” is being selected, it unhides the “Other Industry” field.
But when I make the “Other Industry” field required, I am unable to submit the form when that field is hidden.
When I manually unhide the div you can see that it is requiring this input, even though the form is hidden.
When I select “Other”, fill in a value, and then select another industry so the input becomes hidden again, I can submit the form. And then also the same situation happens as @kravitsjacob pointed out: the value of the “Other Industry” field is saved to the users profile, even though “Industry” is not set to “Other”.
User Admin:
Hi @RGJ , did you manage to solve the issue with required fields? I’ve got same issue.
@isaac is there any workaround for this? I have fields that should be required while the condition for making them visible is made.
Nope, I have not heard back on this nor did I spend any time myself.
@RGJ , thank you for the quick response.
I’ve just created an PR to the original repo with an fix that should solve the issue.
The main challenge here was is the fact that you have two places where the validation runs, which is Frontend and Backend, so I had to implement solution for each separately and to make sure they work as expected.
Hope this helps someone in the future.
I’ve added additional PR that added conditional fields logic per each field Value instead of one value per each field, that means that you can hide an show different fields depending of different values of the field you have.
It also show preview on how it will be stored in the DB for the new column that stores JSONB.
How does this impact searchable fields?
A custom field that has been set to searchable does not come up in the configuration menu on the user directory on my site, but the 3 conditional fields linked to it show up instead. Those three fields are not set to be searchable themselves.
Hi
Sorry, I’m still not aware of all Discourse logic yet regarding User custom fields, so not sure that I understood that question right.
From what I know Searchable marks the field to be indexed and can be used in other parts of the portal, which I haven’t worked with yet and not sure on how to configure this properly.
Theoretically conditional fields shouldn’t effect Searchable fields in any way and while using Autocomeplete to paste an value, the logic still to be working, as you attach an Value for the UserField element.
Maybe you can add maybe more details on your question, maybe attach some screenshots, that might help.
I might not have been clear, my question was for the OP and plugin in general. Sorry if that caused confusion.
The rest of the logic is working properly for the plugin, but I have 3 fields which only appear based on the top field in the first screenshot below. Then in the user directory configuration, only the 3 dependent fields are shown, not the original field which is designated to be searchable:
Screenshots
Would it be possible to use this for age validation and block signups for users under 18? I understand that users can lie about the DOB but I’d like to know if the validation is possible at all.
