Index File Contents for Search
The discussion addresses the current limitation where Discourse indexes file names but not the contents of attachments like PDFs, TXT, or DOC files. ahuling initiated the request for content indexing, which codinghorror and sam confirmed has no immediate timeline, noting it is primarily an enterprise feature with potential database performance concerns regarding large files. While sam stated native support is not yet available, he suggested it is feasible to build as a plugin. Community members like DDo and Craig_Robben expressed strong interest in this capability for documentation-heavy forums. mjbergman92 proposed developing a plugin integrating with external tools like Paperless, highlighting the complexity of leveraging the Discourse API for external document handling and referencing existing solutions like the discourse-algolia plugin. dennisjbr suggested technical approaches, such as using pdftotext in Linux to extract text for PostgreSQL full-text search, or utilizing AI vision to describe images. Further exploring these ideas, dennisjbr outlined a potential solution using Apache Tika for self-hosted OCR or Gemini Flash 1.5 for advanced image analysis and text extraction, acknowledging the significant token investment required to reprocess existing uploads.
Right now, file names are indexed for search but the contents are not. It would be nice if the contents of files were also indexed, at least for the most common text-based files types, e.g. txt, pdf, doc, xls, csv, etc.
Any plans for this?
No plans for this at the moment.
“Me, too”
We’d like to have attachments (in our case, PDF’s) indexed for the search engine, too.
This is very much an enterprise customer type feature. We don’t have concrete plans here with a timeline, I am uncertain what would happen to Postgres with huge PDF documents.
Certainly something we have thought about over the years and may get to over the next few years.
Curious if Discourse added the capability to index and search PDF’s yet?
Not yet, very feasible to build though in a plugin.
When developing such a plugin: Where would you start? Being totally new to the discourse code I’d probably try to hook in UploadCreator, but that might be very wrong.
Developing a Discourse plugin that integrated with Paperless would be a good start.
Such a plugin would be involved to say the least, as stated before.
A plugin like this would require that the Discourse API allows for external handling of documents. Is that currently available?
This plugin would require integration with the search capabilities offered by the Discourse API. While this is not trivial, this has been done by several existing plugins, namely the discourse/discourse-algolia plugin.
Other Areas to Consider
  • Backups
This would be something I would personally be interested in cutting my teeth on. I have started by looking at the Paperless API along with reverse engineering the discourse/discourse-algolia project… but there are others that integrate with search.
Any thoughts as to the choice of Paperless? I like how active the project is and the amount of issues they have closed in addition to the number of issues they have (currently 0).
Dit zou een ENORME verbetering zijn, vooral voor forums die veel documentatie bevatten in de vorm van pdf’s, scans of afbeeldingen. Als de reikwijdte hiervan beperkt is tot zoeken, dan hoeft u idealiter alleen tekst te extraheren/maken en die tekst vervolgens op te slaan in een kolom in postgres. Wanneer u dat doet, kunt u de reeds aanwezige full-text search van postgres benutten.
In Linux kunt u bijvoorbeeld pdftotext gebruiken om tekst uit een pdf te extraheren en op te slaan in de database. Een ander (duurder) idee is om AI-vision te gebruiken om de pdf of afbeelding te verklaren/extraheren voor opslag in de database.
Gedachten?
So, I’ve been looking into this, and putting a wireframe together (with AI) on how to best achie this. There are a couple of ideas that come to mind. Using Apache TIKA would allow us to OCR almost any file type with text, including images. It would be a self-hosted option. And/Or: Use Gemini Flash 1.5 (for example) to not only perform OCR, but also describe images being seen and analyzed, then post that data in a PostgreSQL table/column for search. Of course, this requires a sizable investment of tokens upfront to rebake all posts with attachments/uploads, but it would be most useful. I suppose you get what you pay for?
