안녕하세요,
앱을 다시 빌드하려고 했을 때 PostgreSQL 시작 문제 때문에 어려움을 겪고 있어 도움을 요청합니다.
아래는 로그입니다. 이 상태로 30분 이상 멈춰 있습니다.
Status: Image is up to date for discourse/base:2.0.20240825-0027
docker.io/discourse/base:2.0.20240825-0027
/usr/local/lib/ruby/gems/3.3.0/gems/pups-1.2.1/lib/pups.rb
/usr/local/bin/pups --stdin
I, [2024-08-26T17:16:15.344712 #1] INFO -- : Reading from stdin
I, [2024-08-26T17:16:15.357924 #1] INFO -- : File > /etc/service/postgres/run chmod: +x chown:
I, [2024-08-26T17:16:15.362740 #1] INFO -- : File > /etc/service/postgres/log/run chmod: +x chown:
I, [2024-08-26T17:16:15.367767 #1] INFO -- : File > /etc/runit/3.d/99-postgres chmod: +x chown:
I, [2024-08-26T17:16:15.372845 #1] INFO -- : File > /root/install_postgres chmod: +x chown:
I, [2024-08-26T17:16:15.377501 #1] INFO -- : File > /root/upgrade_postgres chmod: +x chown:
I, [2024-08-26T17:16:15.377876 #1] INFO -- : Replacing data_directory = '/var/lib/postgresql/13/main' with data_directory = '/shared/postgres_data' in /etc/postgresql/13/main/postgresql.conf
I, [2024-08-26T17:16:15.378854 #1] INFO -- : Replacing (?-mix:#?listen_addresses *=.*) with listen_addresses = '*' in /etc/postgresql/13/main/postgresql.conf
I, [2024-08-26T17:16:15.379386 #1] INFO -- : Replacing (?-mix:#?synchronous_commit *=.*) with synchronous_commit = $db_synchronous_commit in /etc/postgresql/13/main/postgresql.conf
I, [2024-08-26T17:16:15.379835 #1] INFO -- : Replacing (?-mix:#?shared_buffers *=.*) with shared_buffers = $db_shared_buffers in /etc/postgresql/13/main/postgresql.conf
I, [2024-08-26T17:16:15.380263 #1] INFO -- : Replacing (?-mix:#?work_mem *=.*) with work_mem = $db_work_mem in /etc/postgresql/13/main/postgresql.conf
I, [2024-08-26T17:16:15.380761 #1] INFO -- : Replacing (?-mix:#?default_text_search_config *=.*) with default_text_search_config = '$db_default_text_search_config' in /etc/postgresql/13/main/postgresql.conf
I, [2024-08-26T17:16:15.381203 #1] INFO -- : Replacing (?-mix:#?checkpoint_segments *=.*) with checkpoint_segments = $db_checkpoint_segments in /etc/postgresql/13/main/postgresql.conf
I, [2024-08-26T17:16:15.381901 #1] INFO -- : Replacing (?-mix:#?logging_collector *=.*) with logging_collector = $db_logging_collector in /etc/postgresql/13/main/postgresql.conf
I, [2024-08-26T17:16:15.382352 #1] INFO -- : Replacing (?-mix:#?log_min_duration_statement *=.*) with log_min_duration_statement = $db_log_min_duration_statement in /etc/postgresql/13/main/postgresql.conf
I, [2024-08-26T17:16:15.382802 #1] INFO -- : Replacing (?-mix:^#local +replication +postgres +peer$) with local replication postgres peer in /etc/postgresql/13/main/pg_hba.conf
I, [2024-08-26T17:16:15.383231 #1] INFO -- : Replacing (?-mix:^host.*all.*all.*127.*$) with host all all 0.0.0.0/0 md5 in /etc/postgresql/13/main/pg_hba.conf
I, [2024-08-26T17:16:15.383604 #1] INFO -- : Replacing (?-mix:^host.*all.*all.*::1\/128.*$) with host all all ::/0 md5 in /etc/postgresql/13/main/pg_hba.conf
I, [2024-08-26T17:16:15.384079 #1] INFO -- : > if [ -f /root/install_postgres ]; then
/root/install_postgres && rm -f /root/install_postgres
elif [ -e /shared/postgres_run/.s.PGSQL.5432 ]; then
socat /dev/null UNIX-CONNECT:/shared/postgres_run/.s.PGSQL.5432 || exit 0 && echo postgres already running stop container ; exit 1
fi
2024/08/26 17:16:15 socat[28] E connect(, AF=1 "/shared/postgres_run/.s.PGSQL.5432", 36): Connection refused
I, [2024-08-26T17:16:15.452500 #1] INFO -- : Generating locales (this might take a while)...
Generation complete.
I, [2024-08-26T17:16:15.453058 #1] INFO -- : > HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main
I, [2024-08-26T17:16:15.455944 #1] INFO -- : Terminating async processes
2024-08-26 17:16:15.500 UTC [30] LOG: starting PostgreSQL 13.16 (Debian 13.16-1.pgdg120+1) on x86_64-pc-linux-gnu, compiled by gcc (Debian 12.2.0-14) 12.2.0, 64-bit
2024-08-26 17:16:15.501 UTC [30] LOG: listening on IPv4 address "0.0.0.0", port 5432
2024-08-26 17:16:15.501 UTC [30] LOG: listening on IPv6 address "::", port 5432
2024-08-26 17:16:15.507 UTC [30] LOG: listening on Unix socket "/var/run/postgresql/.s.PGSQL.5432"
2024-08-26 17:16:15.516 UTC [31] LOG: database system was interrupted; last known up at 2024-08-26 17:10:28 UTC
2024-08-26 17:16:15.769 UTC [31] LOG: database system was not properly shut down; automatic recovery in progress
2024-08-26 17:16:15.774 UTC [31] LOG: redo starts at 18F/E62D1458
2024-08-26 17:16:15.774 UTC [31] LOG: invalid record length at 18F/E62D1490: wanted 24, got 0
2024-08-26 17:16:15.774 UTC [31] LOG: redo done at 18F/E62D1458
2024-08-26 17:16:15.809 UTC [30] LOG: database system is ready to accept connections```
