ספרייה /var/discourse בשטח 70G?
סיכום מבוסס בינה מלאכותית
The discussion revolves around a Discourse forum’s directory /var/discourse consuming 70G of space. nwnuyhs initially reported the issue, which led to a 502 Bad Gateway error due to insufficient space. The problem persisted despite attempts to rebuild the app and clean up docker images and containers.
Upon investigation, it was discovered that the /var/discourse/shared/standalone directory was consuming 70G of space, with the majority being taken up by log files. nwnuyhs suspected that these log files might be related to a DDOS attack on the website.
Suggestions to resolve the issue include:
  • Running ./launcher cleanup to delete old and unused containers and images, as suggested by Jagster.
  • Deleting leftover backups in the /var/discourse/shared/standalone/backups/default directory, as suggested by omarfilip.
  • Removing the log files in the /var/discourse/shared/standalone/logs/ directory, as suggested by RGJ.
My website is a new website ,and users less than 200, and the VPS ROM is 90G,but today ,my websiete502 Bad Gateway nginx
afternoon I received an email:
The download_remote_images_to_local setting is disabled because the disk space limit of download_remote_images_threshold is reached.
finaly I find its because no enough space,here are some information:
root@kehan:/var/discourse# ./launcher rebuild app
x86_64 arch detected.
You have less than 5GB of free space on the disk where /var/lib/docker is located. You will need more space to continue
/dev/vda1        88G   84G     0 100% /
Would you like to attempt to recover space by cleaning docker images and containers in the system? (y/N)y
If the cleanup was successful, you may try again now
WARNING: We are about to start downloading the Discourse base image
This process may take anywhere between a few minutes to an hour, depending on your network speed
Please be patient
2.0.20240825-0027: Pulling from discourse/base
Digest: sha256:6de68cb49198b5281f79ed9401b3fe818c854d220dcf0238549fe2f2adb19146
Status: Downloaded newer image for discourse/base:2.0.20240825-0027
docker.io/discourse/base:2.0.20240825-0027
root@kehan:/var/discourse# du -sh /* | sort -h
du: cannot access '/proc/8758/task/8758/fd/4': No such file or directory
du: cannot access '/proc/8758/task/8758/fdinfo/4': No such file or directory
du: cannot access '/proc/8758/fd/3': No such file or directory
du: cannot access '/proc/8758/fdinfo/3': No such file or directory
0	/bin
0	/dev
0	/initrd.img
0	/initrd.img.old
0	/lib
0	/lib32
0	/lib64
0	/libx32
0	/proc
0	/sbin
0	/sys
0	/vmlinuz
0	/vmlinuz.old
4.0K	/home
4.0K	/mnt
4.0K	/srv
8.0K	/media
16K	/lost+found
16K	/opt
36K	/tmp
48K	/root
568K	/run
3.8M	/etc
56M	/boot
1.4G	/usr
2.1G	/swapfile
87G	/var
root@kehan:/var/discourse# du -sh /var/* | sort -h
0	/var/lock
0	/var/run
4.0K	/var/local
4.0K	/var/mail
4.0K	/var/opt
12K	/var/spool
20K	/var/tmp
408K	/var/backups
114M	/var/log
290M	/var/cache
17G	/var/lib
70G	/var/discourse
root@kehan:/var/discourse# du -sh /var/discourse/* | sort -h
4.0K	/var/discourse/bin
4.0K	/var/discourse/cids
4.0K	/var/discourse/LICENSE
8.0K	/var/discourse/scripts
12K	/var/discourse/discourse-doctor
12K	/var/discourse/README.md
20K	/var/discourse/containers
24K	/var/discourse/launcher
24K	/var/discourse/tests
28K	/var/discourse/discourse-setup
32K	/var/discourse/samples
180K	/var/discourse/launcher_go
180K	/var/discourse/templates
232K	/var/discourse/image
70G	/var/discourse/shared
root@kehan:/var/discourse# ^C
root@kehan:/var/discourse# du -sh /var/discourse/shared/* | sort -h
70G	/var/discourse/shared/standalone
root@kehan:/var/discourse# du -sh /var/discourse/shared/standalone
root@kehan:/var/discourse# cd /var/discourse/shared/standalone
du -sh *
5.8M	backups
1.8M	letsencrypt
70G	log
4.0K	postgres_backup
110M	postgres_data
180K	postgres_run
11M	redis_data
20K	ssl
28K	state
12K	tmp
11M	uploads
My website may have been DDOSed this afternoon. Could these log files be DDOS logs?
Can anyone tell me how to sove the problem?
You can try ./launcher cleanup but I don’t understand why it would help. It will delete old and unused containers and images, that will eat up all the space at some point AFAIK, but yours is new one. But it doesn’t cost anything to try.
To be on safe side don’t stop your now-in-use container, because then it will be saved — if it is started after your rebuilding try.
Check to see if you have leftover backups here and delete them:
Yes
Just rm /var/discourse/shared/standalone/logs/*
