תפריט נפתח של תגיות אוטומטי בעת שימוש בתגיות הורה/ילד בנושאים
סיכום מבוסס בינה מלאכותית
Autopopulating Tag Dropdown with Parent/Child Tags
jenmck is seeking a solution to enable the autopopulation of the tag dropdown menu when using parent/child tags in a topic. After selecting a child tag, the dropdown menu with parent tags no longer appears, requiring users to manually type in the tag.
The desired behavior is:
  1. User selects parent tag from dropdown menu
  2. Dropdown menu with child tags appears
  3. User selects child tag
  4. Dropdown menu with list of parent tags appears again to allow selection of an additional parent tag
This functionality is not currently available, and jenmck is searching for a workaround or theme component to achieve this.
Hello,
I have setup a category to use parent/child tag groups, similar to Set up structured tagging with tag groups and category tag restrictions .
Once the user selects the child tag, I’d like the users to be able to essentially “go back to the start” and select a new parent tag and resulting child tag. However, the main list of parent tags no longer autopopulate (nor do any other tags), and it’s left to the user to manually type in the tag. I’ve searched around for possible theme components or workarounds, but can’t seem to find anything. In the category settings, I do not have the option checked to allow other tags. Even if I were to require more than 1 tag from the parent group, the parent’s tag group doesn’t appear again after selecting a tag.
Here’s what I’m hoping can be done:
In the topic composer, the user clicks on the tags field → dropdown menu appears with list of parent tags → user selects parent tag → dropdown menu with child tags appears → user selects child tag → dropdown menu appears with list of parent tags once again
This is what I currently see:
selecting parent tags
selecting child tag
parent and child tags selected, nothing is in the dropdown - but would like to select an additional parent tag
Is this possible?
2 לייקים
