עזרה בהתקנת תוסף AI ב-Discourse v3.4.0.beta1
סיכום מבוסס בינה מלאכותית
The user riderdivyanshu is experiencing issues installing the AI Plugin on Discourse v3.4.0.beta1. They are receiving an error message during the rebuilding process, which they have shared in the log file Discourse AI Plugin Install Error.txt. The log file shows errors related to email and domain settings, but riderdivyanshu has already provided these settings.
Further investigation by Jagster and riderdivyanshu reveals errors related to PostgreSQL, including a permission issue with creating the vector extension. Falco asks about the PostgreSQL setup, and riderdivyanshu responds that they are using AWS RDS.
Falco then advises that the vector instance needs to be enabled in the AWS RDS PostgreSQL. riderdivyanshu requests guidance on how to enable this.
Not able to install the AI Plugin in the Discourse v3.4.0.beta1 +352. Can anyone help me out how to solve this
Getting this error while rebuilding the app
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c ‘bundle exec rake db:migrate’ failed with return #<Process::Status: pid 1754 exit 1>
Location of failure: /usr/local/lib/ruby/gems/3.3.0/gems/pups-1.2.1/lib/pups/exec_command.rb:132:in `spawn’
exec failed with the params {“cd”=>“$home”, “tag”=>“migrate”, “hook”=>“db_migrate”, “cmd”=>[“su discourse -c ‘bundle exec rake db:migrate’”]}
Can you please share the whole log?
@Falco Kindly find the attached whole log of the rebuild of the discourse app
Discourse AI Plugin Install Error.txt (51.3 KB)
Kindly check the log and kindly let me know how to solve this.
I don’t know but should you fix first email, domain and CDN?
I have already provided the email and domain name but haven’t configured CDN till now will be configuring it later on. But I don’t think these parameters will impact the Discource AI plugin installation.
I’m not sure if it is matter of AI plugin, but more something else and/or database.
But your error.txt says email and domain are broken. CDN is easy to comment out if you don’t use it.
Well, I’m sure someone who knows, not just make wild guesses, weill chime in at some point.
Hi Jake,
Totally agree with your point about the error it is showing but while setting it up I have entered the AWS SMTP setting and also the domain which is currently working. I haven’t set up CDN currently now.
But I don’t know why both errors related to the email and sub domain are showing in the log.
Also, I have found some error which is present in the log on line no. 432, 479, 526 which as below
on 432
ERROR: current transaction is aborted, commands ignored until end of transaction block
on 479
PG::InFailedSqlTransaction: ERROR: current transaction is aborted, commands ignored until end of transaction block (PG::InFailedSqlTransaction)
on 526
ActiveRecord::StatementInvalid: PG::InsufficientPrivilege: ERROR:  permission denied to create extension "vector" (ActiveRecord::StatementInvalid)
HINT:  Must be superuser to create this extension.
if anyone has an idea why this error is showing kindly let me know how to fix this.
How are you running your PostgreSQL database in this setup?
I am running PostgreSQL on the AWS RDS and setting the path for the database on the docker composer file.
You will need to enable the vector instance there in order to use Discourse AI.
How can I enable it in the AWS RDS PostgreSQL any idea about this
