App.yml에 지정하신 코드를 추가했습니다. 결과는 다음과 같습니다.
app
2.0.20240708-0023: Pulling from discourse/base
Digest: sha256:025e9c1f6848c4726544c6ae873d710c62f547b72afb7f537aaa44eb5377cb5c
Status: Image is up to date for discourse/base:2.0.20240708-0023
docker.io/discourse/base:2.0.20240708-0023
/usr/local/lib/ruby/gems/3.3.0/gems/pups-1.2.1/lib/pups.rb
/usr/local/bin/pups --stdin
I, [2024-09-23T17:25:36.977586 #1] INFO -- : Reading from stdin
I, [2024-09-23T17:25:36.994568 #1] INFO -- : File > /etc/service/postgres/run chmod: +x chown:
I, [2024-09-23T17:25:37.001154 #1] INFO -- : File > /etc/service/postgres/log/run chmod: +x chown:
I, [2024-09-23T17:25:37.007785 #1] INFO -- : File > /etc/runit/3.d/99-postgres chmod: +x chown:
I, [2024-09-23T17:25:37.013765 #1] INFO -- : File > /root/install_postgres chmod: +x chown:
I, [2024-09-23T17:25:37.019599 #1] INFO -- : File > /root/upgrade_postgres chmod: +x chown:
I, [2024-09-23T17:25:37.020380 #1] INFO -- : Replacing data_directory = '/var/lib/postgresql/13/main' with data_directory = '/shared/postgres_data' in /etc/ postgresql/13/main/postgresql.conf
I, [2024-09-23T17:25:37.021325 #1] INFO -- : Replacing (?-mix:#?listen_addresses *=.*) with listen_addresses = '*' in /etc/postgresql/13/main/postgresql.con f
I, [2024-09-23T17:25:37.021843 #1] INFO -- : Replacing (?-mix:#?synchronous_commit *=.*) with synchronous_commit = $db_synchronous_commit in /etc/postgresql /13/main/postgresql.conf
I, [2024-09-23T17:25:37.022369 #1] INFO -- : Replacing (?-mix:#?shared_buffers *=.*) with shared_buffers = $db_shared_buffers in /etc/postgresql/13/main/pos tgresql.conf
I, [2024-09-23T17:25:37.022884 #1] INFO -- : Replacing (?-mix:#?work_mem *=.*) with work_mem = $db_work_mem in /etc/postgresql/13/main/postgresql.conf
I, [2024-09-23T17:25:37.023426 #1] INFO -- : Replacing (?-mix:#?default_text_search_config *=.*) with default_text_search_config = '$db_default_text_search_ config' in /etc/postgresql/13/main/postgresql.conf
I, [2024-09-23T17:25:37.023953 #1] INFO -- : Replacing (?-mix:#?checkpoint_segments *=.*) with checkpoint_segments = $db_checkpoint_segments in /etc/postgre sql/13/main/postgresql.conf
I, [2024-09-23T17:25:37.024436 #1] INFO -- : Replacing (?-mix:#?logging_collector *=.*) with logging_collector = $db_logging_collector in /etc/postgresql/13 /main/postgresql.conf
I, [2024-09-23T17:25:37.024941 #1] INFO -- : Replacing (?-mix:#?log_min_duration_statement *=.*) with log_min_duration_statement = $db_log_min_duration_stat ement in /etc/postgresql/13/main/postgresql.conf
I, [2024-09-23T17:25:37.025738 #1] INFO -- : Replacing (?-mix:^#local +replication +postgres +peer$) with local replication postgres peer in /etc/postgresq l/13/main/pg_hba.conf
I, [2024-09-23T17:25:37.026194 #1] INFO -- : Replacing (?-mix:^host.*all.*all.*127.*$) with host all all 0.0.0.0/0 md5 in /etc/postgresql/13/main/pg_hba.con f
I, [2024-09-23T17:25:37.026611 #1] INFO -- : Replacing (?-mix:^host.*all.*all.*::1\/128.*$) with host all all ::/0 md5 in /etc/postgresql/13/main/pg_hba.con f
I, [2024-09-23T17:25:37.027087 #1] INFO -- : > [ -f /root/install_postgres ] && /root/install_postgres && rm -f /root/install_postgres
I, [2024-09-23T17:25:38.629039 #1] INFO -- : Generating locales (this might take a while)...
Generation complete.
I, [2024-09-23T17:25:38.629571 #1] INFO -- : > HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main
I, [2024-09-23T17:25:38.641057 #1] INFO -- : File > /usr/local/bin/create_db chmod: +x chown:
I, [2024-09-23T17:25:38.650536 #1] INFO -- : File > /var/lib/postgresql/take-database-backup chmod: +x chown: postgres:postgres
I, [2024-09-23T17:25:38.654268 #1] INFO -- : File > /var/spool/cron/crontabs/postgres chmod: chown:
I, [2024-09-23T17:25:38.655031 #1] INFO -- : > sleep 5
2024-09-23 17:25:38.675 UTC [36] LOG: starting PostgreSQL 13.15 (Debian 13.15-1.pgdg110+1) on x86_64-pc-linux-gnu, compiled by gcc (Debian 10.2.1-6) 10.2.1 20210110, 64-bit
2024-09-23 17:25:38.675 UTC [36] LOG: listening on IPv4 address "0.0.0.0", port 5432
2024-09-23 17:25:38.675 UTC [36] LOG: listening on IPv6 address "::", port 5432
2024-09-23 17:25:38.680 UTC [36] LOG: listening on Unix socket "/var/run/postgresql/.s.PGSQL.5432"
2024-09-23 17:25:38.685 UTC [45] LOG: database system was shut down at 2024-09-23 17:25:26 UTC
2024-09-23 17:25:38.692 UTC [36] LOG: database system is ready to accept connections
I, [2024-09-23T17:25:43.658647 #1] INFO -- :
I, [2024-09-23T17:25:43.658891 #1] INFO -- : > /usr/local/bin/create_db
2024-09-23 17:25:43.779 UTC [55] postgres@postgres ERROR: database "discourse" already exists
2024-09-23 17:25:43.779 UTC [55] postgres@postgres STATEMENT: CREATE DATABASE discourse;
createdb: error: database creation failed: ERROR: database "discourse" already exists
2024-09-23 17:25:43.879 UTC [58] postgres@discourse ERROR: role "discourse" already exists
2024-09-23 17:25:43.879 UTC [58] postgres@discourse STATEMENT: create user discourse;
NOTICE: extension "hstore" already exists, skipping
NOTICE: extension "pg_trgm" already exists, skipping
NOTICE: extension "vector" already exists, skipping
I, [2024-09-23T17:25:44.581740 #1] INFO -- : GRANT
ALTER SCHEMA
CREATE EXTENSION
CREATE EXTENSION
CREATE EXTENSION
CREATE EXTENSION
CREATE EXTENSION
CREATE EXTENSION
UPDATE 0
I, [2024-09-23T17:25:44.582045 #1] INFO -- : > echo postgres installed!
I, [2024-09-23T17:25:44.585928 #1] INFO -- : postgres installed!
I, [2024-09-23T17:25:44.593592 #1] INFO -- : File > /etc/service/redis/run chmod: +x chown:
I, [2024-09-23T17:25:44.600459 #1] INFO -- : File > /etc/service/redis/log/run chmod: +x chown:
I, [2024-09-23T17:25:44.608243 #1] INFO -- : File > /etc/runit/3.d/10-redis chmod: +x chown:
I, [2024-09-23T17:25:44.609721 #1] INFO -- : Replacing daemonize yes with in /etc/redis/redis.conf
I, [2024-09-23T17:25:44.610503 #1] INFO -- : Replacing (?-mix:^pidfile.*$) with in /etc/redis/redis.conf
I, [2024-09-23T17:25:44.611371 #1] INFO -- : > install -d -m 0755 -o redis -g redis /shared/redis_data
I, [2024-09-23T17:25:44.617733 #1] INFO -- :
I, [2024-09-23T17:25:44.618114 #1] INFO -- : Replacing (?-mix:^logfile.*$) with logfile "" in /etc/redis/redis.conf
I, [2024-09-23T17:25:44.618956 #1] INFO -- : Replacing (?-mix:^bind .*$) with in /etc/redis/redis.conf
I, [2024-09-23T17:25:44.620091 #1] INFO -- : Replacing (?-mix:^dir .*$) with dir /shared/redis_data in /etc/redis/redis.conf
I, [2024-09-23T17:25:44.621308 #1] INFO -- : Replacing (?-mix:^protected-mode yes) with protected-mode no in /etc/redis/redis.conf
I, [2024-09-23T17:25:44.622425 #1] INFO -- : Replacing # io-threads 4 with io-threads $redis_io_threads in /etc/redis/redis.conf
I, [2024-09-23T17:25:44.623349 #1] INFO -- : > echo redis installed
I, [2024-09-23T17:25:44.626833 #1] INFO -- : redis installed
I, [2024-09-23T17:25:44.627487 #1] INFO -- : > cat /etc/redis/redis.conf | grep logfile
I, [2024-09-23T17:25:44.633214 #1] INFO -- : logfile ""
I, [2024-09-23T17:25:44.633615 #1] INFO -- : > exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf
I, [2024-09-23T17:25:44.635902 #1] INFO -- : > sleep 10
98:C 23 Sep 2024 17:25:44.646 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
98:C 23 Sep 2024 17:25:44.646 # Redis version=7.0.7, bits=64, commit=00000000, modified=0, pid=98, just started
98:C 23 Sep 2024 17:25:44.646 # Configuration loaded
98:M 23 Sep 2024 17:25:44.647 * monotonic clock: POSIX clock_gettime
98:M 23 Sep 2024 17:25:44.648 * Running mode=standalone, port=6379.
98:M 23 Sep 2024 17:25:44.648 # Server initialized
98:M 23 Sep 2024 17:25:44.649 * Loading RDB produced by version 7.0.7
98:M 23 Sep 2024 17:25:44.649 * RDB age 18 seconds
98:M 23 Sep 2024 17:25:44.649 * RDB memory usage when created 1.92 Mb
98:M 23 Sep 2024 17:25:44.655 * Done loading RDB, keys loaded: 312, keys expired: 0.
98:M 23 Sep 2024 17:25:44.655 * DB loaded from disk: 0.006 seconds
98:M 23 Sep 2024 17:25:44.655 * Ready to accept connections
I, [2024-09-23T17:25:54.639834 #1] INFO -- :
I, [2024-09-23T17:25:54.640262 #1] INFO -- : > thpoff echo "thpoff is installed!"
I, [2024-09-23T17:25:54.648131 #1] INFO -- : thpoff is installed!
I, [2024-09-23T17:25:54.648937 #1] INFO -- : > /usr/local/bin/ruby -e 'if ENV["DISCOURSE_SMTP_ADDRESS"] == "smtp.example.com"; puts "Aborting! Mail is not c onfigured!"; exit 1; end'
I, [2024-09-23T17:25:54.759170 #1] INFO -- :
I, [2024-09-23T17:25:54.759278 #1] INFO -- : > /usr/local/bin/ruby -e 'if ENV["DISCOURSE_HOSTNAME"] == "discourse.example.com"; puts "Aborting! Domain is no t configured!"; exit 1; end'
I, [2024-09-23T17:25:54.870271 #1] INFO -- :
I, [2024-09-23T17:25:54.870627 #1] INFO -- : > /usr/local/bin/ruby -e 'if (ENV["DISCOURSE_CDN_URL"] || "")[0..1] == "//"; puts "Aborting! CDN must have a pr otocol specified. Once fixed you should rebake your posts now to correct all posts."; exit 1; end'
I, [2024-09-23T17:25:54.981151 #1] INFO -- :
I, [2024-09-23T17:25:54.981527 #1] INFO -- : > rm -f /etc/cron.d/anacron
I, [2024-09-23T17:25:54.985044 #1] INFO -- :
I, [2024-09-23T17:25:54.989219 #1] INFO -- : File > /etc/cron.d/anacron chmod: chown:
I, [2024-09-23T17:25:54.996114 #1] INFO -- : File > /etc/runit/1.d/copy-env chmod: +x chown:
I, [2024-09-23T17:25:55.002341 #1] INFO -- : File > /etc/service/unicorn/run chmod: +x chown:
I, [2024-09-23T17:25:55.008199 #1] INFO -- : File > /etc/service/nginx/run chmod: +x chown:
I, [2024-09-23T17:25:55.015197 #1] INFO -- : File > /etc/runit/3.d/01-nginx chmod: +x chown:
I, [2024-09-23T17:25:55.022373 #1] INFO -- : File > /etc/runit/3.d/02-unicorn chmod: +x chown:
I, [2024-09-23T17:25:55.022533 #1] INFO -- : Replacing # postgres with if [ -f /root/install_postgres ]; then
rm /root/install_postgres
fi
sv start postgres || exit 1
in /etc/service/unicorn/run
I, [2024-09-23T17:25:55.024272 #1] INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse git reset --hard
Updating files: 100% (34584/34584), done.
I, [2024-09-23T17:26:00.129770 #1] INFO -- : HEAD is now at 52a047a8b UX: plugins may have underscore in the name (#27749)
I, [2024-09-23T17:26:00.129895 #1] INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse git clean -f
I, [2024-09-23T17:26:00.306823 #1] INFO -- :
I, [2024-09-23T17:26:00.307054 #1] INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse bash -c '
set -o errexit
if [ $(git rev-parse --is-shallow-repository) == "true" ]; then
git remote set-branches --add origin main
git remote set-branches origin tests-passed
git fetch --depth 1 origin tests-passed
else
git fetch --tags --prune-tags --prune --force origin
fi
From https://github.com/discourse/discourse
- [deleted] (none) -> origin/0-a-bread-path
- [deleted] (none) -> origin/0-a-pullrequests-merefield-add_irv_to_poll
- [deleted] (none) -> origin/0-a-unresolv-bread
- [deleted] (none) -> origin/0-fast-edit-end
- [deleted] (none) -> origin/2.8-stable
- [deleted] (none) -> origin/Update-Custom-Header-Links-preview-link
- [deleted] (none) -> origin/a-dejq-click
- [deleted] (none) -> origin/a-move-mobile
- [deleted] (none) -> origin/a-move-state
- [deleted] (none) -> origin/a-pnpm
- [deleted] (none) -> origin/a-smokes
- [deleted] (none) -> origin/add_mechanism_to_redeliver_all_webhook_events
- [deleted] (none) -> origin/allow-staff-to-tag
- [deleted] (none) -> origin/asyncify-preload-store
- [deleted] (none) -> origin/backup-restore-v2
- [deleted] (none) -> origin/dependabot/bundler/irb-1.14.0
- [deleted] (none) -> origin/dependabot/bundler/libv8-node-21.7.2.0
- [deleted] (none) -> origin/dependabot/bundler/mini_racer-0.12.0
- [deleted] (none) -> origin/dependabot/bundler/omniauth-google-oauth2-1.1.2
- [deleted] (none) -> origin/dependabot/bundler/sassc-embedded-1.77.7
- [deleted] (none) -> origin/dependabot/npm_and_yarn/ember-source-5.8.0
- [deleted] (none) -> origin/dependabot/npm_and_yarn/ember/string-4.0.0
- [deleted] (none) -> origin/dependabot/npm_and_yarn/glob-10.4.3
- [deleted] (none) -> origin/dependabot/npm_and_yarn/highlight.js-11.10.0
- [deleted] (none) -> origin/dependabot/npm_and_yarn/highlightjs/cdn-assets-11.10.0
- [deleted] (none) -> origin/dependabot/npm_and_yarn/jsdoc-4.0.3
- [deleted] (none) -> origin/dependabot/npm_and_yarn/markdown-it-14.1.0
- [deleted] (none) -> origin/detect-default-readonly
- [deleted] (none) -> origin/dev/add-behavior-transformers
- [deleted] (none) -> origin/dev/always-load-problem-checks
- [deleted] (none) -> origin/dev/fix-flaky-sidebar-category-test
- [deleted] (none) -> origin/dev/notification-avatar-size-getter
- [deleted] (none) -> origin/dev/promote-inline-checks-to-problem-checks
- [deleted] (none) -> origin/dev/promote-inline-problem-checks
- [deleted] (none) -> origin/dev/stylesheet_importer_categories_with_background_images-modifier
- [deleted] (none) -> origin/discuz-importer
- [deleted] (none) -> origin/feature/absolute-number-in-poll
- [deleted] (none) -> origin/feature/allow-kbd-chat-html
- [deleted] (none) -> origin/feature/disable-failing-auth-methods
- [deleted] (none) -> origin/feature/locale-telemetry
- [deleted] (none) -> origin/feature/private-github-onebox
- [deleted] (none) -> origin/feature/shift-auto-upload-dropped-files-chat
- [deleted] (none) -> origin/fix-ensure-post-and-topic-user-id-is-always-set
- [deleted] (none) -> origin/fix-missing-color-sidebar-dots
- [deleted] (none) -> origin/fix-vb5-script
- [deleted] (none) -> origin/fix_destroy_drafts
- [deleted] (none) -> origin/fix_rack_logger_info_being_logged
- [deleted] (none) -> origin/font-awesome-6
- [deleted] (none) -> origin/formtoolkit
- [deleted] (none) -> origin/grant-admin-fetch-user
- [deleted] (none) -> origin/group-inbox-label
- [deleted] (none) -> origin/hinted_associations
- [deleted] (none) -> origin/hsluv-experiment
- [deleted] (none) -> origin/i18n/count-lint
- [deleted] (none) -> origin/i18n/email-templates
- [deleted] (none) -> origin/improve-discourse-hub-no-trust-level-error-messages
- [deleted] (none) -> origin/loic-use-messageformat-gem
- [deleted] (none) -> origin/mt/converter
- [deleted] (none) -> origin/prevent-header-cls
- [deleted] (none) -> origin/raw-hbs-to-glimmer
- [deleted] (none) -> origin/relative-sourcemap
- [deleted] (none) -> origin/rename_topics_section_to_community
- [deleted] (none) -> origin/sidebar-perf-v2
- [deleted] (none) -> origin/skip-topic-bookmark-sync-user-destroy
- [deleted] (none) -> origin/support-query-string
- [deleted] (none) -> origin/tobiaseigen-patch-1
- [deleted] (none) -> origin/topic-list-refactor-nohtml
- [deleted] (none) -> origin/truffleruby
- [deleted] (none) -> origin/update-base-urls-to-respect-subfolder
- [deleted] (none) -> origin/update-chat-allowed-groups-default
52a047a8b..ed4791d0b main -> origin/main
* [new branch] 0-a-dl -> origin/0-a-dl
* [new branch] 0-a-gjs-unread-ind -> origin/0-a-gjs-unread-ind
* [new branch] add-shortcuts -> origin/add-shortcuts
* [new branch] again-support-load-more-btn -> origin/again-support-load-more-btn
* [new branch] agc_plugin_analytics_job_errors -> origin/agc_plugin_analytics_job_errors
* [new branch] burning-uppy-mixins -> origin/burning-uppy-mixins
* [new branch] cat-mod-groups -> origin/cat-mod-groups
* [new branch] category-experts-approved-webhook-event-wip -> origin/category-experts-approved-webhook-event-wip
* [new branch] chat-desktop-sound-updates -> origin/chat-desktop-sound-updates
+ bfdeae4f4...488081d93 coco/generic-importer -> origin/coco/generic-importer (forced update)
* [new branch] conditional-summary-box -> origin/conditional-summary-box
* [new branch] defer-button-action -> origin/defer-button-action
* [new branch] dependabot/bundler/jwt-2.9.0 -> origin/dependabot/bundler/jwt-2.9.0
* [new branch] dependabot/bundler/omniauth-google-oauth2-1.2.0 -> origin/dependabot/bundler/omniauth-google-oauth2-1.2.0
* [new branch] dependabot/bundler/rubocop-rails-2.26.2 -> origin/dependabot/bundler/rubocop-rails-2.26.2
* [new branch] dependabot/bundler/sass-embedded-1.79.3 -> origin/dependabot/bundler/sass-embedded-1.79.3
* [new branch] dependabot/bundler/sassc-embedded-1.78.0 -> origin/dependabot/bundler/sassc-embedded-1.78.0
* [new branch] dependabot/bundler/selenium-devtools-0.129.0 -> origin/dependabot/bundler/selenium-devtools-0.129.0
* [new branch] dependabot/bundler/selenium-webdriver-4.25.0 -> origin/dependabot/bundler/selenium-webdriver-4.25.0
* [new branch] dependabot/bundler/uglifier-4.2.1 -> origin/dependabot/bundler/uglifier-4.2.1
* [new branch] dependabot/npm_and_yarn/content-tag-2.0.2 -> origin/dependabot/npm_and_yarn/content-tag-2.0.2
* [new branch] dependabot/npm_and_yarn/ember-auto-import-2.8.1 -> origin/dependabot/npm_and_yarn/ember-auto-import-2.8.1
* [new branch] dependabot/npm_and_yarn/embroider-4f8c6802a1 -> origin/dependabot/npm_and_yarn/embroider-4f8c6802a1
* [new branch] dependabot/npm_and_yarn/esbuild-0.24.0 -> origin/dependabot/npm_and_yarn/esbuild-0.24.0
* [new branch] dependabot/npm_and_yarn/sass-1.79.3 -> origin/dependabot/npm_and_yarn/sass-1.79.3
* [new branch] dev-bigint-sequences -> origin/dev-bigint-sequences
* [new branch] dev-faster-tests -> origin/dev-faster-tests
* [new branch] dev-migrate-user-password -> origin/dev-migrate-user-password
* [new branch] dev-migrate-user-passwords -> origin/dev-migrate-user-passwords
* [new branch] dev-nginx-conf -> origin/dev-nginx-conf
* [new branch] dev/add-skeleton-of-section-landing-page-and-items -> origin/dev/add-skeleton-of-section-landing-page-and-items
* [new branch] dev/advanced-search-custom-in-special -> origin/dev/advanced-search-custom-in-special
* [new branch] dev/bulk-import-chats -> origin/dev/bulk-import-chats
+ 344d0eda8...f060538a8 dev/ember-source-5.9.0-upgrade -> origin/dev/ember-source-5.9.0-upgrade (forced update)
* [new branch] dev/glimmer-post-menu -> origin/dev/glimmer-post-menu
* [new branch] dev/port-outlet-wrapper-to-stable -> origin/dev/port-outlet-wrapper-to-stable
* [new branch] dev/remove-deprecated-respect-plugin-positional-argument -> origin/dev/remove-deprecated-respect-plugin-positional-argument
* [new branch] dev/sidebar-sections-collapse-expand-transformer-events -> origin/dev/sidebar-sections-collapse-expand-transformer-events
* [new branch] dev/sidebar-subsections -> origin/dev/sidebar-subsections
* [new branch] dev/use-new-filestore-download-method -> origin/dev/use-new-filestore-download-method
* [new branch] devcontainer -> origin/devcontainer
* [new branch] drop-old-notification-id-columns -> origin/drop-old-notification-id-columns
* [new branch] ember-cli-terser-tweak -> origin/ember-cli-terser-tweak
* [new branch] ember-native-class -> origin/ember-native-class
* [new branch] ensure_default_timeouts_for_net_http -> origin/ensure_default_timeouts_for_net_http
* [new branch] experimental_async_css_loading -> origin/experimental_async_css_loading
* [new branch] feature/add-user-to-topic_tags_changed-event -> origin/feature/add-user-to-topic_tags_changed-event
* [new branch] feature/bulk-dismiss-buttons-confirmation -> origin/feature/bulk-dismiss-buttons-confirmation
* [new branch] feature/enable-chat-with-dms-only -> origin/feature/enable-chat-with-dms-only
* [new branch] feature/show-note-bookmark-notif -> origin/feature/show-note-bookmark-notif
* [new branch] fix-import-polls -> origin/fix-import-polls
+ 8ed724634...d58449475 fix-search-context-delete-key -> origin/fix-search-context-delete-key (forced update)
* [new branch] full-width-login-modal-mobile -> origin/full-width-login-modal-mobile
* [new branch] glint -> origin/glint
* [new branch] group_and_tag_group_permission_change_notification -> origin/group_and_tag_group_permission_change_notification
* [new branch] history-store-methods -> origin/history-store-methods
* [new branch] loic-rails-7.2 -> origin/loic-rails-7.2
* [new branch] loic-upgrade-miniracer -> origin/loic-upgrade-miniracer
* [new branch] preload_stylesheets_links -> origin/preload_stylesheets_links
* [new branch] prune-old-transpilers -> origin/prune-old-transpilers
* [new branch] reenable_webpack_minimization_2 -> origin/reenable_webpack_minimization_2
ddf53c129..2f4c621a2 remove-x-count -> origin/remove-x-count
* [new branch] remove_unused_file -> origin/remove_unused_file
* [new branch] render-glimmer-example -> origin/render-glimmer-example
* [new branch] render-glimmer-granular -> origin/render-glimmer-granular
* [new branch] revert-28587-revert-28321-dev/remove-create_post_for_category_and_tag_changes-setting -> origin/revert-28587-revert-28321-dev/remove -create_post_for_category_and_tag_changes-setting
* [new branch] revert-location-change -> origin/revert-location-change
473248381..25514419e stable -> origin/stable
* [new branch] support-load-more-btn -> origin/support-load-more-btn
* [new branch] tag-name-transformer -> origin/tag-name-transformer
* [new branch] temp-pr-28024 -> origin/temp-pr-28024
* [new branch] testing_debian_12 -> origin/testing_debian_12
52a047a8b..ed4791d0b tests-passed -> origin/tests-passed
* [new branch] theme-cards -> origin/theme-cards
* [new branch] tobiaseigen-patch-4 -> origin/tobiaseigen-patch-4
* [new branch] trace-objects -> origin/trace-objects
* [new branch] translations-from-crowdin-main -> origin/translations-from-crowdin-main
* [new branch] translations-from-crowdin-stable -> origin/translations-from-crowdin-stable
* [new branch] update-composer-media-optimization-requirements -> origin/update-composer-media-optimization-requirements
* [new branch] ux-fix-review-delete-label -> origin/ux-fix-review-delete-label
* [new branch] ux/simplification-invite-modal -> origin/ux/simplification-invite-modal
t [tag update] beta -> beta
t [tag update] latest-release -> latest-release
* [new tag] v3.2.4 -> v3.2.4
* [new tag] v3.2.5 -> v3.2.5
* [new tag] v3.3.0 -> v3.3.0
* [new tag] v3.3.0.beta4 -> v3.3.0.beta4
* [new tag] v3.3.0.beta5 -> v3.3.0.beta5
* [new tag] v3.3.0.beta6 -> v3.3.0.beta6
* [new tag] v3.3.1 -> v3.3.1
* [new tag] v3.4.0.beta1 -> v3.4.0.beta1
I, [2024-09-23T17:26:03.742189 #1] INFO -- :
I, [2024-09-23T17:26:03.742316 #1] INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse bash -c '
set -o errexit
if [[ $(git symbolic-ref --short HEAD) == tests-passed ]] ; then
git pull
else
git -c advice.detachedHead=false checkout tests-passed
fi
Switched to a new branch 'tests-passed'
I, [2024-09-23T17:26:09.115457 #1] INFO -- : Branch 'tests-passed' set up to track remote branch 'tests-passed' from 'origin'.
I, [2024-09-23T17:26:09.115559 #1] INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse git config user.discourse-version tests-passed
I, [2024-09-23T17:26:09.133494 #1] INFO -- :
I, [2024-09-23T17:26:09.133568 #1] INFO -- : > cd /var/www/discourse && mkdir -p tmp
I, [2024-09-23T17:26:09.137301 #1] INFO -- :
I, [2024-09-23T17:26:09.137393 #1] INFO -- : > cd /var/www/discourse && chown discourse:www-data tmp
I, [2024-09-23T17:26:09.143626 #1] INFO -- :
I, [2024-09-23T17:26:09.143716 #1] INFO -- : > cd /var/www/discourse && mkdir -p tmp/pids
I, [2024-09-23T17:26:09.148769 #1] INFO -- :
I, [2024-09-23T17:26:09.148858 #1] INFO -- : > cd /var/www/discourse && mkdir -p tmp/sockets
I, [2024-09-23T17:26:09.153691 #1] INFO -- :
I, [2024-09-23T17:26:09.153877 #1] INFO -- : > cd /var/www/discourse && touch tmp/.gitkeep
I, [2024-09-23T17:26:09.158063 #1] INFO -- :
I, [2024-09-23T17:26:09.158151 #1] INFO -- : > cd /var/www/discourse && mkdir -p /shared/log/rails
I, [2024-09-23T17:26:09.163009 #1] INFO -- :
I, [2024-09-23T17:26:09.163193 #1] INFO -- : > cd /var/www/discourse && bash -c "touch -a /shared/log/rails/{production,production_errors,unicorn. stdout,unicorn.stderr,sidekiq}.log"
I, [2024-09-23T17:26:09.169934 #1] INFO -- :
I, [2024-09-23T17:26:09.170122 #1] INFO -- : > cd /var/www/discourse && bash -c "ln -s /shared/log/rails/{production,production_errors,unicorn. stdout,unicorn.stderr,sidekiq}.log /var/www/discourse/log"
I, [2024-09-23T17:26:09.177448 #1] INFO -- :
I, [2024-09-23T17:26:09.177638 #1] INFO -- : > cd /var/www/discourse && bash -c "mkdir -p /shared/{uploads,backups}"
I, [2024-09-23T17:26:09.184377 #1] INFO -- :
I, [2024-09-23T17:26:09.184575 #1] INFO -- : > cd /var/www/discourse && bash -c "ln -s /shared/{uploads,backups} /var/www/discourse/public"
I, [2024-09-23T17:26:09.192049 #1] INFO -- :
I, [2024-09-23T17:26:09.192140 #1] INFO -- : > cd /var/www/discourse && bash -c "mkdir -p /shared/tmp/{backups,restores}"
I, [2024-09-23T17:26:09.199757 #1] INFO -- :
I, [2024-09-23T17:26:09.199952 #1] INFO -- : > cd /var/www/discourse && bash -c "ln -s /shared/tmp/{backups,restores} /var/www/discourse/tmp"
I, [2024-09-23T17:26:09.206229 #1] INFO -- :
I, [2024-09-23T17:26:09.206324 #1] INFO -- : > cd /var/www/discourse && chown -R discourse:www-data /shared/log/rails /shared/uploads /shared/backups /share d/tmp
I, [2024-09-23T17:26:09.222255 #1] INFO -- :
I, [2024-09-23T17:26:09.222441 #1] INFO -- : > cd /var/www/discourse && [ ! -d public/plugins ] || find public/plugins/ -maxdepth 1 -xtype l -delete
I, [2024-09-23T17:26:09.226321 #1] INFO -- :
I, [2024-09-23T17:26:09.226608 #1] INFO -- : Replacing # redis with sv start redis || exit 1 in /etc/service/unicorn/run
I, [2024-09-23T17:26:09.227410 #1] INFO -- : > cd /var/www/discourse/plugins && sudo -E -u discourse git clone https://github.com/discourse/docker_manager.g it
Cloning into 'docker_manager'...
warning: unable to access '/root/.config/git/attributes': Permission denied
I, [2024-09-23T17:26:10.680586 #1] INFO -- :
I, [2024-09-23T17:26:10.680745 #1] INFO -- : > cd /var/www/discourse/plugins && sudo -E -u discourse git clone https://github.com/discourse/discourse-whos-o nline.git
Cloning into 'discourse-whos-online'...
I, [2024-09-23T17:26:11.733230 #1] INFO -- :
I, [2024-09-23T17:26:11.733327 #1] INFO -- : > cd /var/www/discourse/plugins && sudo -E -u discourse git clone https://github.com/discourse/discourse-data-e xplorer.git
Cloning into 'discourse-data-explorer'...
I, [2024-09-23T17:26:12.881012 #1] INFO -- :
I, [2024-09-23T17:26:12.882337 #1] INFO -- : > cp /var/www/discourse/config/nginx.sample.conf /etc/nginx/conf.d/discourse.conf
I, [2024-09-23T17:26:12.888353 #1] INFO -- :
I, [2024-09-23T17:26:12.888592 #1] INFO -- : > rm /etc/nginx/sites-enabled/default
I, [2024-09-23T17:26:12.892703 #1] INFO -- :
I, [2024-09-23T17:26:12.893443 #1] INFO -- : > mkdir -p /var/nginx/cache
I, [2024-09-23T17:26:12.898119 #1] INFO -- :
I, [2024-09-23T17:26:12.899172 #1] INFO -- : Replacing pid /run/nginx.pid; with daemon off; in /etc/nginx/nginx.conf
I, [2024-09-23T17:26:12.899760 #1] INFO -- : Replacing (?m-ix:upstream[^\}]+\}) with upstream discourse { server 127.0.0.1:3000; } in /etc/nginx/conf.d/disc ourse.conf
I, [2024-09-23T17:26:12.900169 #1] INFO -- : Replacing (?-mix:server_name.+$) with server_name _ ; in /etc/nginx/conf.d/discourse.conf
I, [2024-09-23T17:26:12.900543 #1] INFO -- : Replacing (?-mix:client_max_body_size.+$) with client_max_body_size $upload_size ; in /etc/nginx/conf.d/discour se.conf
I, [2024-09-23T17:26:12.900932 #1] INFO -- : Replacing (?-mix:worker_connections.+$) with worker_connections $nginx_worker_connections ; in /etc/nginx/nginx .conf
I, [2024-09-23T17:26:12.901413 #1] INFO -- : > echo "done configuring web"
I, [2024-09-23T17:26:12.904114 #1] INFO -- : done configuring web
I, [2024-09-23T17:26:12.904616 #1] INFO -- : > cd /var/www/discourse && gem install bundler --conservative -v $(awk '/BUNDLED WITH/ { getline; gsub(/ /,""); print $0 }' Gemfile.lock)
I, [2024-09-23T17:26:14.790751 #1] INFO -- : bundler-2.5.18 설치 성공
1 gem 설치됨
I, [2024-09-23T17:26:14.790947 #1] INFO -- : > cd /var/www/discourse && find /var/www/discourse ! -user discourse -exec chown discourse {} \+
I, [2024-09-23T17:26:19.630299 #1] INFO -- :
I, [2024-09-23T17:26:19.631279 #1] INFO -- : > cd /var/www/discourse && su discourse -c 'yarn config set network-timeout 600000 -g'
I, [2024-09-23T17:26:20.307972 #1] INFO -- : yarn config v1.22.22
success "network-timeout"을 "600000"(으)로 설정했습니다.
0.09초 만에 완료.
I, [2024-09-23T17:26:20.308765 #1] INFO -- : > cd /var/www/discourse && if [ "tests-passed" != "tests-passed" ]; then
rm -rf app/assets/javascripts/node_modules
fi
I, [2024-09-23T17:26:20.311751 #1] INFO -- :
I, [2024-09-23T17:26:20.311933 #1] INFO -- : > cd /var/www/discourse && su discourse -c 'yarn install --frozen-lockfile && yarn cache clean'
error discourse@: 이 모듈과 호환되지 않는 엔진 "yarn"입니다. 예상 버전은 "please-use-pnpm"입니다. 현재 버전은 "1.22.22"입니다.
warning discourse@: 엔진 "pnpm"이(가) 잘못된 것 같습니다.
error 호환되지 않는 모듈을 찾았습니다.
I, [2024-09-23T17:26:20.764069 #1] INFO -- : yarn install v1.22.22
info lockfile을 찾을 수 없습니다.
[1/5] package.json 검증 중...
info 이 명령에 대한 문서는 https://yarnpkg.com/en/docs/cli/install 을 참조하세요.
I, [2024-09-23T17:26:20.764877 #1] INFO -- : 비동기 프로세스 종료
I, [2024-09-23T17:26:20.764934 #1] INFO -- : HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:post gres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main pid: 36 에 INT 전송
I, [2024-09-23T17:26:20.765087 #1] INFO -- : exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 98 에 TERM 전송
2024-09-23 17:26:20.765 UTC [36] LOG: 빠른 종료 요청 수신
98:signal-handler (1727112380) SIGTERM 수신, 종료 예약 중...
2024-09-23 17:26:20.767 UTC [36] LOG: 활성 트랜잭션 중단 중
2024-09-23 17:26:20.770 UTC [36] LOG: 백그라운드 워커 "logical replication launcher" (PID 51)가 종료 코드 1과 함께 종료됨
2024-09-23 17:26:20.771 UTC [46] LOG: 종료 중
2024-09-23 17:26:20.793 UTC [36] LOG: 데이터베이스 시스템이 종료되었습니다
98:M 23 Sep 2024 17:26:20.818 # 사용자가 종료를 요청했습니다...
98:M 23 Sep 2024 17:26:20.818 * 종료 전 최종 RDB 스냅샷 저장 중.
98:M 23 Sep 2024 17:26:20.836 * 디스크에 DB 저장됨
98:M 23 Sep 2024 17:26:20.836 # Redis는 이제 종료 준비가 되었습니다. 안녕...
실패
Pups::ExecError: cd /var/www/discourse && su discourse -c 'yarn install --frozen-lockfile && yarn cache clean' 실행 실패, 반환 #<Process::Status: pid 324 exit 1>
실패 위치: /usr/local/lib/ruby/gems/3.3.0/gems/pups-1.2.1/lib/pups/exec_command.rb:132:in `spawn'
exec 실행 실패, 매개변수 {"cd"=>"$home", "hook"=>"yarn", "cmd"=>["if [ \"$version\" != \"tests-passed\" ]; then\n rm -rf app/assets/javascripts/node_modu les\nfi", "su discourse -c 'yarn install --frozen-lockfile && yarn cache clean'"]}
bootstrap 실행 코드 1과 함께 실패
