Waar kan ik DUIDELIJKE stap-voor-stap instructies vinden om naar de sectie te gaan waar ik mensen kan uitnodigen?
Users are seeking explicit, step-by-step instructions to access the invite section on Discourse. Lilly directs them to the avatar user menu in the top right corner and shares helpful links and screenshots showing the Create Invite dialog, including fields like “arrival at topic”. tobiaseigen notes upcoming UI improvements, including a direct invite link in the sidebar and a simplified popup focused on “copy link to share”. cogdog asks whether the “arrival at topic” option was removed, since they no longer see it. Lilly confirms it’s still available, and Moin suggests checking the must approve users site setting. cogdog confirms they had enabled that setting — and discovered it hides the “arrival at topic” option. They plan to disable it to restore functionality, despite preferring approval for suspicious signups.
I can not find the section to invite people?
The avatar user menu on the top right corner has the link
Here are some topics to help
We will soon be putting a link directly to the invite popup in the sidebar. It will be displayed above the … on new sites, then hidden behind the … once bootstrap mode has ended.
The invite popup is also getting an update, to hide all the options except the easy-to-use and now more commonly recognized “copy link to share” method.
I’ve not seen this option for quite some time on my site. I can see its part of invitations I created a while ago (I keep extending the date).
Was it removed?
It is still there
Did you enable the must approve users site setting?
Yes I did! And I see if I toggle it off, the arrive at topic returns! I had not idea these were connected. I set the must approve setting on seeing an increase of new accounts that looked a bit suspicious. I can live without it, just helpful to see new accounts at the door.
