A user, mjbergman92, seeks to reverse proxy Discourse using Nginx Proxy Manager, facing mixed content errors due to HTTP references. After exploring various solutions, including Docker labels and Unix sockets, they learn that enabling force_https via environment variables (e.g., DISCOURSE_FORCE_HTTPS=true) and setting the X-Forwarded-Proto header in Nginx Proxy Manager resolves the issue. pfaffman, Falco, Jagster, and merefield provide guidance. mjbergman92 confirms success after applying these changes, eliminating mixed content warnings.
I really hate to do something out of the ordinary here. I hate it as much as anyone else, but it’s all I know how to do and how every other self-hosted app I have is running.
I have my wildcard A record pointing to an internal IP on my network which has port 80 and 443 exported by nginx proxy manager, which has my ssl certificates all setup. I have most everything on my existing network setup using docker, so nginx proxy manager is safe to use because it just uses the docker network to proxy over http.
In the case of discourse, i have tried setting up discourse.MYDOMAIN.com to the separate local IP address under a separate A record and got it to resolve; however, however nginx proxy manager has lets encrypt setup works and how discourse has it setup does not for internal IPs.
So… I just want to reverse proxy. I am going to be attempting all sorts of nginx proxy configurations to get this to work. I am slightly concerned about man in the middle attacks, but I would like to figure out why nginx proxy manager lets encrypt config works with internal config and discourse does not.
There has to be a way!
(P.S. I know I am frazzle brained. Please ask specific questions and I can give clarity)
There are some topics about running Discourse behind nginx proxy manager. Basically, you configure Discourse not to bind to any ports and add the requisite labels in a labels: section in your app.yml.
If I go the nginx proxy manager route, which is how i have it setup right now (as opposed to setting up lets encrypt on the discourse VM itself)…
I would need to still bind to port 80 on the discourse VM because it is a separate machine in my case.
My experience currenlty is that I am getting Mixed Content errors with my current configuration of nginx proxy manager with the SSL setup there pointing at the ip address of the discourse VM at port 80.
I do not think this is possible to get rid of since the http:// references in the code are hard coded… or am i wrong? is that what this labels field you referenced would change?
I can not do the Unix socket setup… my discourse VM is on a separate machine. back to the original plan. Let me see if i can figure out the force_https enabling with some other posts on the forum. FYI, this is the step I can not do.
I was able to do so in the GUI as I mentioned before.
@Falco, @pfaffman, @Jagster, @merefield… thanks to you all, I have successfully setup the reverse proxy and I no longer have those Mixed Content errors.
Once I reverse proxied into port 80 of the discourse VM and I was able to register and such, it came down to setting force_https using the GUI and adding the x-forwarded-proto flag in the advanced tab of nginx proxy manager.
