Discourse scrolt niet meer soepel
Users are reporting that Discourse forums no longer scroll smoothly, with the screen jumping unexpectedly when scrolling through long topics. richb-hanover first noticed the issue on the OpenWrt and Bitwarden forums, using Firefox 131.0.3 on a Mac. merefield comments on a mobile header design change in Bitwarden, suggesting it might be related. awesomerobot confirms experiencing the same problem, possibly on a laptop with a trackpad. sam asks for confirmation and suggests testing in safe mode, while MarcP attempts to reproduce the issue on a Macbook Pro but has not succeeded so far.
Hi folks,
I have noticed that within the last month (or two), that Discourse forums I read no longer “scroll smoothly” through topics. That is, as I scroll through a long topic, my browser screen jumps up to show a post about two or three prior. I can usually fiddle around to scroll to later posts, but I haven’t figured a consistent workaround.
I am moderator on the OpenWrt forum forum.openwrt.org which is using Discourse 3.4.0.beta3-dev
I also see this on the Bitwarden forum (community.bitwarden.com)
I primarily use Firefox 131.0.3 (64-bit) on a Mac.
What other diagnostic info could I provide? Many thanks.
What have bitwarden done with the mobile header :grimacing:. No menus or search?
Update (thanks @Moin):
I think that’s a very ambitious amount of content for a header on mobile.
Might be better as a single drop-down?
is this on a laptop with a trackpad? I’ve been experiencing the same issue
Can you confirm this happens here as well? Does it happen in safe mode?
I’ve been trying to repro on Brave browser on a Macbook Pro using trackpad in this 160+ replies topic - negative so far.
