Discourse Livestream
:information_source: Summary Discourse Livestream allows you to create Livestream topics that let your users join and participate in chat
:hammer_and_wrench: Repository Link https://github.com/discourse/discourse-livestream
:open_book: Install Guide How to install plugins in Discourse
Features
Open any topic to start a livestream event.
A livestream event includes
  • a video stream (using Youtube, for example)
  • a calendar event using Discourse Calendar (and Event)
  • and also an accompanying chat channel automatically created for the event
Configuration
There are some pre-requisite plugins and settings
  1. The chat plugin and calendar plugin need to be installed.
    • Chat comes pre-installed in Discourse, and Calendar is included in business tier and above, or for self-hosters, you can install it separately.
  2. These site settings need to be enabled
    • discourse livestream enabled
    • chat enabled
    • discourse post event enabled
    • calendar enabled
  3. Ensure embeddable chat allowed paths includes the default value of “/t”. You should not need to modify this value.
Creating a livestream topic
To create a livestream topic, you’d want to fill in something like the following – adding the link to the livestream and event details.
Use the create event option in the composer
Here is an excerpt you can use
https://www.youtube.com/watch?v=dQw4w9WgXcQ&ab_channel=RickAstley
[event start="2024-10-23 22:00" status="public" timezone="Asia/Singapore" allowedGroups="trust_level_0"]
[/event]
Before you hit Create Topic, adding the livestream tag is crucial.
You will then see that the event and livestream has been created, along with an accompanying chat channel on the right side.
Screenshot of new livestream event
Once any user hits Going on the event, they will automatically join the chat channel, allowing them to participate in the conversation!
Troubleshooting
Chat does not show up on my livestream topic
This looks like a very useful plugin! I just have a few questions:
  1. When the user presses on ‘Going’, will the chat open on the screen automatically?
  2. Is it compulsory to make a tag ‘livestream’ and use it on livestream topics?
  3. Is the channel closed or deleted automatically after the livestream is finished?
Thanks @NateDhaliwal!
The chat screen (on the right hand side of the screen) will be present on topic load. Meaning it will be there whether a user is “going” or not. The user is granted access to the chat channel once they select “going”, which also updates the chat channel by removing a CTA blocking the input to message (for non “going” users).
Currently, yes.
Currently, the channel is neither deleted nor closed after the livestream has ended or the livestream topic was closed.
This plugin would also be useful for appointments, such as meetings. During meeting preparation, topics often include discussions about better time slots or announcements of delays, etc. This clutters the thread with short-lived information.
Offering a linked chat for these kinds of topics could allow for easier housekeeping (chatter would be automatically removed after some time).
For this kind of functionality, it would suffice to add a setting for a list of tags where an accompanying chat should be enabled.
In addition, the button captions for different tags could be made customizable.
It seems this plugin support Youtube live and running OK in our forum. But we need some other livestream source like bilibili, does the plugin support those livestream source?
How well does this work on mobile?
@xish have you tried on mobile? I am guessing if bilibili has a player that works on discourse it will likely work. Easy test is to create a private category with a test group and test function
Hello and thanks for the plugin. I tried to install it and everything when ok. After I enabled the plugin I’ve made a new topic where I chose the livestream tag but the problem is when I try to find and press the Create Event I don’t see it at the dropdown menu. I tried to just add the code like you shared with dates etc but after posting code does nothing. I see the chat and everything but nowhere to press Going.
Thanks in advance!
As Natalie wrote, you must turn this on
You also have to reload the browser before it starts to appear in the editor.
Yeap! You’re absolutely right and I’m blind. I’ve read that we need the chat enabled, discourse post event enabled & calendar enable but my bad I thought It was included in the install. Now I took the time to reed what’s installed in the self-hosted and what’s not.
Thanks for your answer <3
Very cool! Has anyone tried this plugin with Owncast or PeerTube?
is this correct?
I don’t see the chat embedded and I clicked going in the event
The video is scheduled for tomorrow morning. Maybe the chat doesn’t appear until the stream is live?
edit to remove link to past stream
update:
The chat did not embed into the live stream topic as described in the op. Can someone help me figure out why this does not work?
I included livestream tag (I had to make one - is that right?)
chat is enabled and works in the main window
discourse post event enabled is set to /t (as shown above)
Calendar enabled (and works otherwise)
any hints?
This all sounds correct. You should be able to see chat show up even before the event starts.
Did you get it to work?
No, I’ve not been able to get the chat to appear in the post like shown in the original post.
Are you able to share a screenshot of what your topic looks like?
Thanks Natalie, I didn’t have the theme enabled :roll_eyes: :blush:
Edit to add:
I just want to thank Natalie and all the folks who make this such a great project!!! Discourse is awesome and the team and volunteers in this community make it great!!!
After a quick chat it looks like the plugin was not enabled, so we’re good here now.
I’ll update OP to make sure folks also make sure the livestream plugin is turned on.
What is the purpose of the option Minimal event: Hide Going/Not going buttons and invitees status ?
I edited an event and selected that, then it only showed the Interested button so there was no way to participate in the chat.
Recent topic on Monday map event
Can someone remind me how to hide content behind a Going RSVP status?
Do you have an example of what you mean here? You want to show content when someone hits “Going”?
