סיכום מבוסס בינה מלאכותית
In a support thread titled “How can I add image in login and register box,” Devran_Öztürk shared screenshots indicating a desire to add an image to the green section of the login interface. NateDhaliwal asked for clarification on placement, and Devran_Öztürk specified the green area. Canapin suggested using the after-login-buttons plugin outlet — which can be repositioned via CSS — or creating a theme component for more flexibility, linking to beginner guides on theme development. They also noted CSS-only solutions (e.g., background-image or ::after) are possible but less clean. NateDhaliwal agreed CSS could suffice and questioned whether a full theme component is overkill. Canapin countered that while CSS works for simple cases (like a background image), a theme component is cleaner, more versatile, and educational for future customizations — especially if more complex needs arise.
Where in here would you like to add an image?
Green section
There’s a after-login-buttons plugin outlet at the bottom of this section that can be used for adding content. I suppose it can be moved to the top with CSS, or an outlet above can be asked.
You can create a new theme component that makes use of it.
You can also probably add an image only with CSS in a less clean way.
Could you post a picture of what you’d like your login modal to look like?
Yep,
I was thinking of ::after or background-image with CSS. Didn’t know there were plugin outlets there. I think it’s overkill to write a full TC just to put an image there?
I’d say it cleaner and more versatile to make a theme component using the plugin outlet, plus you’ll learn useful things if you want to customize further your installation. ![]()
Using a pseudo element from existing HTML to add your image will work and it’s a valid way to achieve this. ![]()
That said, it depends on what result you want exactly.
For example, if the goal is simply to have a background image at the bottom or top of the login buttons block with no additional requirements, then CSS could be perfectly fine.
