שנה מ-example.com ל-community.example.com
Hello, I already have Discourse on example.com, what do I have to do to change it to community.example.com?
Hello, you can follow this guide: Change the domain name or rename your Discourse.
An additional useful site after completing the guide above
Will let you see DNS servers update progress.
yes, i’ve used that before
When i first hosted a domain on namecheap, it was a while till realising that
  • in the record’s host column, for A record example.com host would be @
  • for community.example.com host would be community
From my recall yes. At first was trying to put sub name with domain name. In the A record just need the sub name prefix.
yes, it’s differnet with the CNAME and TXT records from the SMTP provider into namecheap. However the MX (recieving at SMTP provider) records either need @ or sub name prefix, as the host.
