Wijzigingen in de response structuur van de /admin/users/list/all.json API?
Currently running Discourse 3.5.0.beta5-dev (eff31e0d42).
Would anyone know if the API response from the /admin/users/list/all.json endpoint has changed in the last week or so? :thinking:
Specifically:
GET /admin/users/list/all.json?email=email@example.com
:thinking:
I think this endpoint used to return a flat JSON object directly representing a single user when queried with an exact email address.
However, the current response structure now appears to wrap the user object inside a new users array, which has broken a few existing SSO integrations at our end.
Here is an anonymised pseudo example of the response of what I think has changed “before” and “after” for reference.
Old:
  "id": 1,
  "username": "sampleuser",
  "name": "",
  "avatar_template": "/user_avatar/example.com/sampleuser/{size}/avatar.png",
  "active": true,
  "admin": false,
  "moderator": false,
  "last_seen_at": "2025-05-11T08:27:28.578Z",
  "created_at": "2020-01-01T12:00:00.000Z",
  "suspended": false,
  "trust_level": 1
New:
  "users": [
      "id": 1,
      "name": "",
      "email": "someone@example.com",
      "active": true,
      "admin": false,
      "moderator": false,
      "last_seen_at": "2025-05-11T09:34:35.900Z",
      "suspended": false,
      "trust_level": 1
  "meta": {
    "message_bus_last_ids": {
      "bulk_delete": 0
Would anyone know of a recent commit that may have caused this change? :thinking:
It indeed changed and the commit is this
diff --git a/app/controllers/admin/users_controller.rb b/app/controllers/admin/users_controller.rb
index 92d906f161..70406efce5 100644
--- a/app/controllers/admin/users_controller.rb
+++ b/app/controllers/admin/users_controller.rb
@@ -32,7 +32,16 @@ class Admin::UsersController < Admin::StaffController
   def index
     users = ::AdminUserIndexQuery.new(params).find_users
-    opts = { include_can_be_deleted: true, include_silence_reason: true }
+    opts = {
+      include_can_be_deleted: true,
+      include_silence_reason: true,
+      root: :users,
+      meta: {
+        message_bus_last_ids: {
+          bulk_delete: MessageBus.last_id("/bulk-user-delete"),
     if params[:show_emails] == "true"
       StaffActionLogger.new(current_user).log_show_emails(users, context: request.path)
       opts[:emails_desired] = true
No amount of searching through the 73x commits I updated with yesterday found this DEV: replace selenium driver with playwright breaking change.
Thanks for the link @RGJ
My approach:
  • load /admin/users/list/all.json?email=email@example.com
  • check the x-discourse-route header
  • look up the corresponding file (app/controllers/admin/users_controller.rb)
  • look up the corresponding method (index)
  • press “Blame”
  • spot the commit
Nooooo way… :scream:
Well, that’s what I learnt today!
Thanks @RGJ :clap:t2::star_struck:
I managed to find that commit somehow, but couldn’t (and still don’t) see where it changed the data structure (I was on my phone, making things a bit more difficult).
I’m guessing this was the breaking change in the API response :confused:
In /app/assets/javascripts/admin/addon/controllers/admin-users-list-show.js
It’s the line root: :users that was added.
We’ve now recovered from the impact of this change.
Perhaps going a bit off topic here but is there a way I can track these types of updates so I can notify myself when an API response changes from “X”, after being “Y” for so many years? :thinking:
Some kind of scripted local unit tests that I could run on a daily basis perhaps?
Although now I’ve said that out loud, that wouldn’t notify me until after I’d updated my Discourse and it had broken the integrations.
A staging environment I guess…
You could have a staging environment. You might also create a github action for your code that starts discourse and runs a test against the latest discourse each day.
Ah-ha! Perfect, that’d work, thanks :grin:
I think a plugin that called the endpoint and rendered it could be an easy way to test. And then change the default github action to run daily instead of only on push.
Seems the documentation needs an update as well https://docs.discourse.org/#tag/Admin/operation/adminListUsers
In an ideal world, the documentation would be auto generated from the source and we could just look at the commit history for the documentation, which would only contain the changes in the interface.
This is what caught me out too when trying to resolve the issues caused by this change :confused:
this has also broken an integration we have - is this something that we should anticipate being reverted?
Hi, yes sorry this shouldn’t have been merged, it was my mistake.
But the good news is that I already reverted it 8 hours ago: DEV: revert admin users list change (#32723) · discourse/discourse@7558e2c · GitHub
Nooooooooo… (repeat to fade)
This is terrible news :cry:
We’ll have to change all our integrations yet again :exploding_head:
sorry about that, sadly I had no choice but to revert, you got caught on an infortunate timing.
A good reason to PR @Richie because then hopefully there’s a simple revert button.
This is the risk we take and the price we pay for living on the bleeding edge :blush:
It still blows me away that Discourse is open source, it really does. Who am I to complain :person_shrugging:
Thank you for fixing the issue @j.jaffeux :clap: :person_bowing:
