Kan geen regex voor bekeken woorden invoeren om telefoonnummers te vangen
Hi!
We’re experiencing a lot of spam that’s not caught by Akismet. The messages usually have (international) phone numbers in them which made us think of using a regex to catch them.
After experimenting a bit we found the following expression:
(?:\+|00)?\d{1,3}?[-\s]?\d{2,4}[-\s]?\d{2,4}[-\s]?\d{2,4}|\b\d{10}\b
We’re not able to enter this though as the admin screen breaks it up into separate chunks:
Any suggestions how we should handle this?
I think it’s picking up on the pipes | when the regex is copy-pasted in. I think if you type it in manually it may ignore them as separators and allow you to do it as one entry. :crossed_fingers:
ETA: From a quick test, this seems promising. :+1:
Brilliant, that solved it! :+1:
