Forum Onderzoeker AI Persona gids
:bookmark: This guide explains the Forum Researcher agent in Discourse AI, how it works, and how to configure it for in-depth forum content analysis.
:person_raising_hand: Required user level: Administrator (to enable and configure), All users (to interact, if granted access)
Understanding and using the Forum Researcher agent
The Discourse AI plugin includes the Forum Researcher agent, a powerful tool designed for conducting in-depth research on the content within your forum. This agent can help you uncover insights, summarize discussions, and analyze trends across your community.
Summary
This document will cover:
  • How the Forum Researcher agent functions.
  • Steps to configure the Forum Researcher.
  • Best practices for interacting with the agent.
  • The distinction between the Forum Researcher and standard forum helper tools.
  • Guidance on selecting an appropriate Large Language Model (LLM).
  • Debugging tips for research tasks.
  • Current limitations of the agent.
How it works
The Forum Researcher agent uses a dedicated Researcher tool. This tool is engineered to:
  1. Access forum content: It can read through various sections of your forum.
  2. Apply advanced filters: A flexible filter system allows the tool to target relevant information precisely. You can specify content by:
    • Specific categories (e.g., category:support or categories:support,feedback)
    • Tags (e.g., tag:bug or tags:bug,regression)
    • Users or groups (e.g., username:sam, usernames:sam,jane, group:moderators, groups:moderators,admins)
    • Keywords in posts or topic titles (e.g., keywords:regression,bug, topic_keywords:feature,request)
    • Date ranges for posts (e.g., after:2024-01-01 before:2024-06-30)
    • Date ranges for topics (e.g., topic_after:2024-01-01 topic_before:2024-06-30)
    • Specific topics by ID (e.g., topic:123 or topics:123,456)
    • Topic status (e.g., status:open, status:closed, status:archived, status:noreplies, status:single_user)
    • Post type (e.g., post_type:first, post_type:reply)
    • Sort order (e.g., order:latest, order:oldest, order:latest_topic, order:oldest_topic, order:likes)
    • Inline result limit (e.g., max_results:50)
    • Assigned topics (if the Assign plugin is enabled, e.g., assigned_to:username, assigned_to:user1,user2, assigned_to:*, assigned_to:nobody)
    • Filters can be combined using AND logic (space-separated) or OR logic (using OR between filter groups). For example: category:bugs status:open after:2024-05-01 OR tag:critical usernames:sally.
  3. Analyze content with Large Language Models (LLMs): After retrieving the filtered content, it uses an LLM to analyze the information, extract insights, and answer your specific questions or achieve your research goals.
  4. Follow a structured process: To ensure efficiency and accuracy, especially considering potential costs, the Forum Researcher is designed to:
    • Understand: It will work with you to clarify your research goals at the beginning.
    • Plan: Based on your goals, it designs a comprehensive research approach using the available filters.
    • Test (Dry Run): Before executing the full analysis, the agent typically performs a “dry run.” This involves calculating how many posts match your filter criteria without immediately processing them with the LLM. The agent will then inform you of this count.
    • Refine: Based on the dry run results, if the number of posts is too large (risking high costs or overly broad results) or too small (potentially missing key information), the agent can help you adjust the filters.
    • Execute: Once you confirm the scope is appropriate (after the dry run), the agent runs the final analysis, sending the content to the LLM.
    • Summarize: It presents the findings, typically using Discourse Markdown, with links back to the original forum posts and topics as supporting evidence.
This methodical approach means you can ask the researcher to perform tasks like:
  • “Summarize the most frequently discussed unresolved bugs in the ‘mobile-app’ category from the last quarter, and identify any proposed solutions or workarounds mentioned in the discussions.”
  • “Help me identify the main arguments for and against the ‘New User Onboarding’ proposal topic (link), and list the key proponents of each side.”
  • “Review activity by the ‘documentation-team’ group in the past year and provide a report on their key contributions to how-to articles, highlighting any tutorials that received significant positive feedback.”
Configuring the Forum Researcher
The Forum Researcher is disabled by default because its usage can incur LLM costs.
  1. Enable Agent: Activate it by navigating to Admin → AI → Agents.
  2. Control Access: It is strongly recommended to limit this agent to specific groups to manage LLM costs. You can also use AI quotas for finer control.
Once enabled, the tool has several configuration options:
  • LLM: Select a specific LLM for research. This defaults to the current agent’s LLM. This option allows you to balance quality and cost.
  • Maximum number of results: This limits the number of posts processed per query to control costs. The default is 1000.
  • Include private: This allows searching in secure categories, using the interacting user’s permissions.
  • Maximum tokens per post: This truncates long posts to save token costs. It defaults to 2000 tokens, with a minimum of 50.
  • Maximum tokens per batch: This controls the data chunk size sent to the LLM. It’s useful for LLMs with large context windows or to maintain focus. If set to 8000 or below, it defaults to the LLM’s maximum prompt tokens minus a 2000 token buffer.
Best practices for interaction
To get the most out of the Forum Researcher while managing costs:
  • Be specific with goals: Clearly define what you want to find out before you start. The agent works best when it has precise objectives.
  • Confirm scope after dry run: The agent will typically perform a ‘dry run’ first and inform you how many posts it found based on your request. Pay close attention to this number. If it’s too high (risking high costs or unfocused results) or too low (potentially missing crucial information), discuss refining your filters with the agent before committing to the full analysis.
  • Iterate on filters: If the initial dry run isn’t targeting the right information, work with the agent to adjust filter criteria. Add more specific keywords, narrow date ranges, or specify categories/tags.
  • Consolidate queries: The agent is designed to handle multiple related goals in a single research execution. Try to group related questions into one comprehensive research request to the agent.
Relationship to standard forum helper and related tools
The Forum Researcher agent is distinct from a general Forum Helper that uses standard tools like Search and Read.
  • Standard Search and Read Tools:
    • The Search tool primarily identifies relevant topics. It does this by matching keywords against post content and other criteria (tags, categories, etc.). For each matching topic, it returns a link and a brief snippet from a relevant post, not the full post content.
    • The Read tool is used to access the full content of a specific topic (or selected posts within it) that Search has identified.
    • These tools work in tandem for targeted retrieval: Search finds topics, Read digests their content.
  • Forum Researcher’s researcher Tool:
    • Direct, deep content analysis: The researcher tool doesn’t just identify topics; it directly processes and analyzes the full content of potentially many posts (up to its configured Maximum number of results) that match its comprehensive filter criteria.
    • Advanced filtering and synthesis: It uses a more complex filtering language to build a dataset of posts from across the forum (potentially spanning hundreds of topics), and then synthesizes information from this entire dataset to answer complex questions. This is fundamentally different from reading individual topics one by one.
In essence, while a Forum Helper uses Search to pinpoint topics (presenting snippets) and Read to delve into one, the Forum Researcher conducts broad analysis across the actual text of many posts simultaneously to uncover deeper, synthesized insights.
What LLM should I use?
LLM technology is rapidly evolving, with models continually improving in capability and cost-effectiveness. During the development of the Forum Researcher, models like Gemini 2.5 Flash, Gemini 2.5 Pro, GPT-4.1, and Claude 4 Sonnet provided excellent results for complex research plans.
The best choice depends on your specific needs:
  • High-quality, nuanced analysis: More advanced models might be preferable, though they usually come with higher costs.
  • Broad overviews or cost-sensitive tasks: Faster, more economical models can be very effective.
Here are some point-in-time examples from internal testing at Discourse for a very specific, complex query:
Look at the top 1000 open topics in the feature category - ordered by like (first post only) - all time … make me an executive report of the:
  • Top 20 features CDCK should build
  • Easiest 20 features CDCK could build
  • Obvious duplicates
  • Things that are very poorly defined
ask me no more questions, just run the research
  1. Gemini 2.0 Flash Example
  2. Gemini 2.5 Flash (with thinking) Example
  3. GPT-4.1 Example
  4. Claude 4 Sonnet Example
  5. Gemini 2.5 Pro Example
Hybrid example: Driver is Gemini 2.5 Pro and Researcher LLM is Gemini 2.0 Flash
Hybrid example
Debugging research
In Discourse, you can enable advanced AI debugging by adding groups to the ai_bot_debugging_allowed_groups site setting. With that in place, you are able to see the actual payloads sent to the LLM.
Limitations
Currently, there is no option to send images to the research LLM. This will be considered in future versions.
FAQs
  • Is the Forum Researcher available on all Discourse plans?
    The Forum Researcher is part of the Discourse AI plugin, which is available for self-hosted sites and on our Enterprise hosting plan.
  • Can the Forum Researcher access content from secure categories?
    Yes, if the “Include private” option is enabled in its configuration and the user interacting with the agent has the necessary permissions to access those categories.
  • How can I control the cost of using the Forum Researcher?
    • Limit access to specific, trusted groups.
    • Use the “Maximum number of results” and “Maximum tokens per post” settings to cap processing.
    • Choose cost-effective LLMs.
    • Pay close attention to the “dry run” estimates before executing full research.
    • Utilize AI quotas.
Additional resources
sam Great work and many thanks for the steady progress on Discourse AI personas— truly impressive work.
When several personas are enabled, the composer’s dropdown can feel crowded and confusing for users. I’m looking for some guidance:
  • Is the correct use to have numerous personas in the dropdown for users to select from?
  • Can that a default persona tap specialized personas behind the scenes?
  • I think controlling visibility through permissions, so helper personas stay hidden from regular users view and used with an automation will result in multiple response posts. It would be great if these could be used as tools.
Any configuration tips, or deployment guideline examples would be helpful.
Hallo allemaal,
Allereerst, fantastisch werk! Dit is iets waar we echt op hebben gewacht, om alle kennis op het forum te kunnen samenstellen.
Een klein probleem dat we hebben gevonden:
  • Aangezien ons forum in het Duits draait, lijkt het erop dat de LLM’s soms probeerden te zoeken met de Duitse aanhalingstekens die er zo uitzien: „dit“, wat resulteert in lege zoekresultaten.
Welke LLM gebruik je? Het is misschien de moeite waard om de persona te kopiëren en de systeemprompt in het Duits opnieuw te doen met hints
I actually did that already, even gave it an extra instruction:
- Für verfeinerte Suchparameter im Forum, verwende ausschließlich die Anführungszeichen ``"`` und nicht ``„“``.
But the issue still persists. Happend with gpt 4.1 and occasionally with gemini 2.5 pro and flash.
BTW where can I find more info how to use the topic_keywords: and keywords: parameters? I could not find anything in meta nor on ask.discourse.com. I want to try and replicate the search that the LLM is trying to perform. I get no search results when I use them in my forum search (we are on 3.5.0.beta8-dev)
Net een vreemd gedrag ondervonden met gemini 2.5 researcher:
LLM reageert:
Ik zal nu de informatie uit deze en andere bijdragen samenstellen om de rasbeschrijving te maken. Dit zal even duren. Ik neem opnieuw contact met u op zodra ik klaar ben.
Maar de reactie is eigenlijk voltooid en gaat niet verder vanaf hier en moet handmatig opnieuw worden geactiveerd om verder te gaan.
Zou dit te maken kunnen hebben met snelheidslimieten?
The researcher persona does not use the Discourse core search implementation, it uses a custom implementation, this is parsed and then we call fulltext search directly.
Ah, begrepen. Het zou fijn zijn om wat documentatie te hebben over de implementatie van aangepast zoeken om meer gedetailleerde controle te hebben over het zoekgedrag via prompts.
This is 1000% a hallucination by an LLM.
In the corpus of training data this is a “common” response, so if we are not careful it can make this kind of stuff up :frowning:
If you enable debugging and press the (i) button, it will show the section of the prompt where we specify the full researcher language to the LLM.
Hoewel ik het geweldig vind dat het onderzoeker-persona aangepaste en geavanceerde zoekparameters krijgt, maakt dit omstandigheden het moeilijk om de zoekopdrachten handmatig te reproduceren en vervolgens het systeemprompt aan te passen of te verfijnen of de zoekopdracht te debuggen wanneer deze nul resultaten oplevert, aangezien ik niet dezelfde zoekparameters en waarden op de front-end kan gebruiken.
Is er een manier om de aangepaste zoekopdracht te reproduceren, misschien via API?
Niet op dit moment, maar het is een goed idee, in wezen is dit een soort filter
Great write up, Sam, and really impressive that we can now use Discourse AI to build something like our own Deep Research agent so easily!
There’s just one thing that worries me:
image :open_mouth:
