Verschillende inhoud tonen voor mobiele weergave in een .gjs-bestand
Trying to update our custom theme component to the new standard after the deprecation notice and I can’t figure out how to show different stuff for mobile users in this setting.
The theme guide doesn’t mention anything about this, the only relevant post I found is api.renderInOutlet not rendering? - #3 by NateDhaliwal which uses this.site.mobileView so I assumed something like the following should work:
export default apiInitializer("1.8.0", (api) => {
  api.renderInOutlet(
    "composer-after-save-or-cancel",
    <template>
      {{#if this.site.mobileView}}
      Mobile!
      {{else}}
      Normal!
      {{/if}}
    </template>
But I only ever see the normal content… I am obviously missing something basic…
Thanks for any hints!
Oh, het moet waarschijnlijk gewoon de site-service handmatig importeren.
  const site = api.container.lookup("service:site");
  api.renderInOutlet(
      {{#if site.mobileView}}
      Mobiel!
      {{else}}
      Normaal!
      {{/if}}
Zou @service site; ook werken?
No. The @service decorator is only available in Ember classes like Components or Services. If the <template>...</template> was refactored as a separate component, then you can use the decorator. As the apiInitializer() is only a function, the service has to be accessed like normal JS.
You can see Ember object ownership (getOwner, service injections, etc.)
If you like, you can put an entire class inside the renderInOutlet call:
import Component from "@glimmer/component";
import { service } from "@ember/service";
export default apiInitializer((api) => {
  api.renderInOutlet(
    class extends Component {
      @service site;
      <template>
          Mobile!
        {{else}}
          Normal!
        {{/if}}
      </template>
But the .lookup() solution is also reasonable - that’s what @service is doing behind-the-scenes anyway :ok_hand:
Thanks, this works!
Also funny how (at lest this flavor of) modern JS increasingly looks like enterprise Java when I used to work in that world (early 2010s) :smiley:
