Aanpassingen aan de sidekiq initialisatieconfiguratie
As discussed, I’m trying to take advantage of this but have hit a snag, because I’m customising:
/config/initializers/100-sidekiq.rb
Here’s my altered code, I’m:
  • Giving each job an accessible retry count attribute which I’m using in a plugin to change workflow logic depending on the amount of times a job has been retried
In the file I’m amending it to
  • Create a custom Middleware class to retrieve the value
  • Adding the class to the chain so it is included
require "sidekiq/pausable"
require "sidekiq/discourse_event"
require "sidekiq_logster_reporter"
require "sidekiq_long_running_job_logger"
require "mini_scheduler_long_running_job_logger"
 module Sidekiq::Middleware::Server #<-- NEW
   class SetRetryCountMiddleware
     def call(worker, job, queue)
       worker.retry_count = job["retry_count"] if worker.respond_to?(:retry_count=)
       yield
Sidekiq.configure_client { |config| config.redis = Discourse.sidekiq_redis_config }
Sidekiq.configure_server do |config|
  config[:skip_default_job_logging] = false
  config.server_middleware do |chain|
    chain.add Sidekiq::Pausable
    chain.add Sidekiq::Middleware::Server::SetRetryCountMiddleware #<-- NEW
    chain.add Sidekiq::DiscourseEvent
Presently I’m achieving that with a file edit script in app.yml using sed
This breaks the hygeine of the repo, so I can’t use the bundled compiled assets.
Any suggestions on how to make these modifications from a plugin?
Does the specific position in the stack matter? I tried this in a plugin.rb and it seemed to add the middleware :crossed_fingers:
class BreakEverythingMiddleware
    puts "The middleware worked!"
    raise "THE MIDDLEWARE WORKED"
Sidekiq.default_configuration.server_middleware { |chain| chain.add BreakEverythingMiddleware }
Zou niet moeten!
Geweldig idee, ik ga dat proberen! Bedankt!
