Probleem met overlappende paginakopjes in Horizon Theme (Mobiele Categorie Pagina Stijl)
Hello,
I’m using the Horizon theme for my Discourse forum and have encountered an issue. When the Mobile category page style is set to boxes with featured topics, a layout problem arises on the homepage.
Here are the details of the issue:
  • On the homepage, the category buttons and tag selection buttons are displayed correctly at the top of the page.
  • Below them, the categories and some topics are shown, as expected.
  • However, when scrolling the page up, I expect the content to appear below the fixed header, but the topic titles do not behave as expected.
  • Instead, the topic titles appear underneath the fixed header (sticky header), while the category buttons and tag buttons are correctly positioned below the header.
  • This issue only occurs with the Horizon theme and does not appear with other themes.
Additional Information:
  • I’m using the latest version of Discourse.
  • The Horizon theme was downloaded from the official repository and has not been edited.
  • No specific plugins that could interfere with mobile styling are active.
  • This issue occurs only on mobile devices and has been observed in both Chrome and Edge browsers.
Has anyone else experienced this issue, or does anyone have suggestions for a fix? Thank you for your time!
Are they newly updated iOS mobile devices? This is probably why: iOS 26 bugs with fixed position elements in Discourse
Dit probleem heeft zich in mijn geval niet voorgedaan op iOS-apparaten - het gebeurt op Android, specifiek in mobiele browsers zoals Chrome en Edge.
Ik kan het reproduceren, bedankt voor de melding. Zal het oplossen
Fixed in
https://github.com/discourse/discourse/pull/34902
Bedankt voor de snelle oplossing
Dit onderwerp werd automatisch gesloten na 4 dagen. Nieuwe reacties zijn niet meer toegestaan.
