The discussion highlights a critical UX issue in Discourse: while math is rendered beautifully in the browser using Discourse-math, it falls back to raw LaTeX in print view and emails, making these outputs unusable for technical communities. Ethsim2 outlines the problem and proposes solutions, including server-side rendering of math to SVG or HTML for emails and print views, with a site setting to control the behavior. Sam confirms the need for server-side rendering, suggesting MathJax in a Node environment to pre-render math expressions into SVG, with caching and fallbacks for reliability. The discussion notes prior fixes for other elements in print view, reinforcing the need to include cooked math for consistency. A key challenge is simulating a DOM for MathJax in a server environment, with potential use of jsdom or mathjax-full. The proposed solution aims to make PDFs and emails fully readable and professional, aligning with user expectations in STEM fields.
Problem
Discourse-math renders beautifully in the browser, but in contexts where JavaScript can’t run, math falls back to raw LaTeX source. Two high-impact cases:
Print view (/print or browser print-to-PDF): math shows as $...$ instead of rendered symbols.
Emails (digests, notifications, subscriptions): math is delivered raw, unreadable to recipients unless they copy-paste into a LaTeX editor.
This breaks important workflows for communities that rely on Discourse for technical content.
Why it matters
STEM educators and researchers often need to print topics or forward emails. If the math isn’t legible, those exports are unusable.
Other gaps in print/emails (spoilers, oneboxes, images) have been fixed — math is a glaring omission.
Supporting cooked math in non-JS contexts would make Discourse a first-class platform for technical communities.
Proposed solution
Lightweight step (print):
Ensure /print view includes cooked math HTML.
Trigger MathJax typesetting before print.
Heavier step (emails):
Explore server-side MathJax rendering, as Sam suggested.
Render math to SVG or pre-cooked HTML so recipients see legible equations directly in email clients.
Optional site setting:
“Use cooked math in print view/emails” → lets admins choose between raw source vs rendered math.
Related issues / prior work
Math inside [details] panes fixed (PR #111, June 2025).
Print view already had fixes for spoilers/oneboxes → precedent for including cooked elements.
Emails: Sam’s comment (#214) identified server-side render as the long-term solution.
Summary / TL;DR
Right now, math in print view and emails falls back to raw LaTeX. Adding cooked math rendering would make PDFs and digests readable, professional, and consistent with what users see in the browser.
Reproduce on Discourse with iOS Safari
Even when Request Desktop Site is enabled in Safari, Discourse still appends ?mobile_view=1 when opening /print, which forces the stripped-down mobile print view.
Workaround: manually change to ?mobile_view=0 for the full desktop print layout.
Example /t/fw-the-email-subject/12345/print?mobile_view=0
Yep, I think Sam’s summary is spot on: if we want emails / print view to show rendered math, we need server-side math rendering (or at least server-side “pre-rendering”), because email clients won’t run MathJax.
A realistic approach would be:
During cooking (or in a background job after cooking), find the math spans (inline + display).
Render each expression to SVG (or MathML as a fallback) using MathJax in a Node environment.
Replace the math in the cooked HTML used for email/print with either:
inline <svg ...> (best fidelity, no external fetch), or
<img src="data:image/svg+xml;base64,..."> (more compatible for some clients, but can get large).
Cache by a stable key (e.g. sha256(latex + display_mode + macros + font_config)), so we only render once per unique formula.
The tricky bits (but manageable if scoped carefully):
DOM simulation: MathJax’s “browser” output wants a DOM; so we’d likely need mathjax-full + jsdom (or use the pure adaptor route).
Performance / timeouts: do it async in a job queue, and degrade gracefully (leave LaTeX as-is if render fails).
Email client quirks: some clients strip SVG; so having a fallback plan matters (e.g. plaintext/LaTeX, or MathML where supported).
If someone wants a quick spike, the first experiment I’d do is:
A tiny Node script using mathjax-full to render $begin:math:text$E\=mc\^2$end:math:text$ to SVG,
See what assumptions it makes (DOM vs adaptor),
Then decide whether MiniRacer is a dead-end and we should treat this as “needs Node available” (or a small service).
If that spike works, then we can talk about where it plugs in (email pipeline vs cooking vs print view), and what we cache/store.
