Probleem met Chat Icoon Badge Aantal Niet Weergegeven voor Directe Berichten (DM's)
Users serkhelesheyi and Moin reported an intermittent bug where Direct Message (DM) notifications and chat icon badges fail to update when a new message is sent as a reply to an existing thread. While email notifications for the initial message appear, subsequent replies often go unnoticed in the UI, requiring manual checking to see new content. Moin identified the pattern after several months of investigation, confirming that replies in DMs (where threading is disabled by default) do not trigger badge updates. zogstrip confirmed the root cause: the system incorrectly counts unread messages in threaded DMs because it internally creates threads to track reply chains. A fix has been implemented and merged in pull request #36918 zogstrip.
Hello,
I’ve encountered an issue with Direct Messages (DMs) in my Discourse forum and would appreciate some guidance.
Problem Description
Sometimes when another user sends me a direct message:
  • I correctly receive a browser push notification.
  • However, the chat icon in the top navigation bar does not display any badge count (e.g., “1”).
  • To see the new message, I have to manually click on the chat icon and open the conversation.
This issue does not happen consistently—it occurs intermittently.
Environment and Details
  • Discourse version: Latest stable release
  • Browser: Microsoft Edge (latest version) on Windows 10
  • Plugins: No plugins installed that affect chat or notifications
  • Multiple devices: I am logged into my account on several devices
  • Observed pattern:
    • On one occasion, I received a new DM but the chat icon did not show any badge.
    • When I logged in with another account and sent myself a test message from a different browser, the chat icon suddenly updated and displayed the correct badge count for both messages (the earlier one and the new one).
    • The user whose message did not trigger the badge was a newly registered account (only a few hours old). I am not sure if this is related.
I’ve attached screenshots showing the notification behavior and my settings for clarity.
Expected Behavior
Whenever I receive a new DM, I expect the chat icon to always display the correct badge count, regardless of whether the sender is a newly registered user or whether I’m logged in on multiple devices.
Is this a known bug, or could it be related to a specific configuration?
03
I also sometimes find new DMs in my messages here even though there is no dot displayed in the sidebar and no number at the top on the chat icon. Nevertheless, the “last visit” line clearly indicates that these messages are new to me.
But I have not yet been able to identify when this happens. The only thing I know for sure is that I was always logged out when this happened.
In my case, the user whose message didn’t trigger a notification is an admin, so I don’t think the fact that you encountered it with a new user is relevant.
Do you use the DiscourseHub app? I wondered if that is involved. If you don’t use the app, I could probably rule it out.
Thank you very much for joining the discussion and sharing your experience :folded_hands:
I’ve had exactly the same issue, except that I was not logged out when it happened. Still, the new message appeared without any badge on the chat icon—I only noticed it after manually opening the chat section.
I’ve installed the DiscourseHub app on my phone just for testing purposes, but I don’t actively use it. The issue I described occurred on Windows, using the Edge browser.
Happy to provide more details if needed.
Not sure if this is helpful, but it just happened again in a DM here on Meta. I was not online when the message was sent. It did not show in Discourse Hub. No indicator after logging in. I only noticed that a different user was at the top of the DM chats in my sidebar.
Some more missed direct messages later, JammyDodger and I were able to spot a pattern :partying_face:
The notification is missing when the message is a reply to another message.
An example:
These are 3 chat messages Nat sent me:
In the morning I had 2 email notifications
There is no email for the second message, which is the one that was the reply to an earlier message.
I also have a screenshot showing notifications about 2 new chat messages on the icon in the header. (I was pleased that there was no notification about badges, so I took a screenshot of my notifications. It’s a happy coincidence that the number of chat notifications is included.)
So the problem is: whenever Nat replies to another message in our chat, I am not notified :confused:
Easy solution: @nat should stop replying to your chat messages :sweat_smile:
Will have a look :eyes:
That one was quite complicated :exploding_head:
https://github.com/discourse/discourse/pull/36918
The gist of it, is that in DMs where threading is disabled (which is the default), a reply would not be correctly counted towards “unread” because we internally create a thread to keep track of the reply chain.
No one said it would be easy :wink: It took more than 4 months to find out what the messages where the notifications were missing had in common.
It would have been nice if this fix had made it into the ESR.
Better late than never?! :sweat_smile:
The PR has been approved :white_check_mark: and merged :git_merged:
This topic was automatically closed after 2 days. New replies are no longer allowed.
