Observer on "controller:edit-category.tabs" model not triggered
Hello,
I’m trying to observe changes to the model of the EditCategoryTabs controller but for some reasons, nothing happens:
import { observes } from "@ember-decorators/object"
import { withPluginApi } from "discourse/lib/plugin-api"
function initialize(api) {
  api.modifyClass(
    "controller:edit-category.tabs",
    (Superclass) =>
      class extends Superclass {
        @observes("model.parent_category_id")
        onParentCategoryChange() {
          console.log("Apply some logic here when parent category changes");
export default {
  initialize() {
    withPluginApi(initialize);
I tried many things but I’m still not able to trigger the observer callback when the model changes. Anything I missed that might explain how to this correctly?
For the context, I’m using Discourse 3.5.1 built with official launcher.
Thanks for your help!
I was looking at your link, and the controller has been moved to /admin: https://github.com/discourse/discourse/blob/main/app/assets/javascripts/admin/addon/controllers/edit-category/tabs.js
I’m not sure why it doesn’t trigger. Maybe @observes doesn’t work well in modifyClass?
As an alternative, what do you think of:
@action
saveCategory(data) {
  const oldParentId = this.model.parent_category_id;
  super.saveCategory(data);
  const newParentId = this.model.parent_category_id;
  if (oldParentId !== newParentId) {
Thanks @Arkshine for having a look! I can’t edit the post to reflect the new file location.
I thought about overriding saveCategory too but in that case I would like to apply the logic as soon as the form is modified. I even tried to observe change on the formData (without success).
