Database access issues after upgrade v3.5.2 -> v3.6.0.beta2
  • v3.5.2 → v3.5.2
  • v3.6.0.beta2 → v3.6.0.beta2
This thread got me to this point: Upgrade failed. Database stopped. (multisite install)
I now have database access issues:
2025-11-02 17:13:51.212 UTC [1975] postgres@c_discourse LOG:  provided user name (postgres) and authenticated user name (discourse) do not match
2025-11-02 17:13:51.212 UTC [1975] postgres@c_discourse FATAL:  Peer authentication failed for user "postgres"
2025-11-02 17:13:51.212 UTC [1975] postgres@c_discourse DETAIL:  Connection matched pg_hba.conf line 89: "local   all             postgres
                        peer"
postgres=# \l
List of databases
Name     |  Owner   | Encoding | Locale Provider |   Collate   |    Ctype    | ICU Locale | ICU Rules |   Access privileges
b_discourse | postgres | UTF8     | libc            | en_US.UTF-8 | en_US.UTF-8 |            |           | =Tc/postgres          +
|          |          |                 |             |             |            |           | postgres=CTc/postgres +
|          |          |                 |             |             |            |           | discourse=CTc/postgres
c_discourse | postgres | UTF8     | libc            | en_US.UTF-8 | en_US.UTF-8 |            |           | =Tc/postgres          +
postgres    | postgres | UTF8     | libc            | en_US.UTF-8 | en_US.UTF-8 |            |           |
template0   | postgres | UTF8     | libc            | en_US.UTF-8 | en_US.UTF-8 |            |           | =c/postgres           +
template1   | postgres | UTF8     | libc            | en_US.UTF-8 | en_US.UTF-8 |            |           | =c/postgres           +
(6 rows)
The multisite.yaml changed between these versions.
Original:
secondsite:
adapter: postgresql
database: b_discourse
pool: 25
timeout: 5000
db_id: 2
host_names:
- ``forum.domain.com
New:
mlp:
adapter: postgresql
database: discourse_mlp
username: discourse_mlp
password: applejack
host: dbhost
pool: 5
timeout: 5000
host_names:
- discourse.nudderdomain.com
- discourse.nudderdomain.internal
I never set any of the passwords or users for the multisite because it wasn’t required or listed in the original template when I set them up.
Initially I couldn’t upgrade because the multi site failed because of permissions on the two sites listed in multisite.yml. Adding postres as the user to multisite.yml didn’t work for the migration. Now I see maybe I should have tried discourse?
Will simply changing owner to discourse fix it? Do I need to add users and passwords for the multisite to make it match the current?
What is the best LONG TERM FIX here.
Your post is super hard to read, so I have unlisted it Please fix the formatting and I can list it again.
Sadly I went to great lengths to make is as comprehensible/coherent as I could.
I know what I mean. :wink:
EDIT: OK, got it. The other forum I use is a tad different. I use triple tics on the line before and after the block. Now I see what is going on. This one the first set of tics inserts a window to paste into. I couldn’t understand why the triple tics wasn’t working and </> wasn’t giving me what I really wanted.
You can toggle to the markdown editor if you need to do lots of markdown things in your post.
Your database password issues are strange. Have you considered moving to a new server? That might be quicker and easier than battling with this issue.
Did you follow these instructions? (It doesn’t seem like it?)
It’s a pretty good bet, but make sure that you’ve got stuff like in the multisite install topic.
If your sites are working now then I too would encourage you to do a clean multisite install and backup/restore the databases over. You can copy all the other stuff as described in Move a Discourse site to another VPS with rsync
I wondered why I named my databases b_discourse and c_discourse. Now I know why. :wink:
## Plugins go here
hooks:
  after_postgres:
     - exec: sudo -u postgres createdb b_discourse || exit 0
     - exec:
          stdin: |
            grant all privileges on database b_discourse to discourse;
          cmd: sudo -u postgres psql b_discourse
          raise_on_fail: false
     - exec: sudo -u postgres createdb c_discourse || exit 0
     - exec:
          stdin: |
            grant all privileges on database c_discourse to discourse;
          cmd: sudo -u postgres psql c_discourse
     - exec: /bin/bash -c 'sudo -u postgres psql b_discourse <<< "alter schema public owner to discourse;"'
     - exec: /bin/bash -c 'sudo -u postgres psql b_discourse <<< "create extension if not exists hstore;"'
     - exec: /bin/bash -c 'sudo -u postgres psql b_discourse <<< "create extension if not exists pg_trgm;"'
I don’t fully understand how privileges are granted so I wondered about these. (screen shot from above for two problematic databases):
Well, good news bad news. :frowning:
Now we want :frowning:
2025-11-07 18:05:41.555 UTC [4724] discourse@b_discourse ERROR:  must be owner of extension vector
2025-11-07 18:05:41.555 UTC [4724] discourse@b_discourse STATEMENT:  ALTER EXTENSION vector UPDATE TO '0.8.0';
2025-11-07 18:05:41.752 UTC [4725] discourse@c_discourse ERROR:  must be owner of extension vector
2025-11-07 18:05:41.752 UTC [4725] discourse@c_discourse STATEMENT:  ALTER EXTENSION vector UPDATE TO '0.8.0';
instead of
ALTER EXTENSION vector UPDATE TO ‘0.7.0’;
But:
b_discourse=# ALTER EXTENSION vector UPDATE TO '0.8.0';
ERROR:  extension "vector" has no update path from version "0.7.4" to version "0.8.0"
I’ve been leery about just changing owners on the databases but I guess that might be next.
EDIT: OK. That didn’t work. It seems the extension owner is key here, not the database owner. As of now 0.8.0 doesn’t exist on my container. it tops out at the 0.7.4 :frowning: The ‘base’ seems to have gotten updated during the attempt at installing version 15.
Is there a way to get ./launcher to connect as the user postgres? That seems like it would cure all my upgrade issues here.
b_discourse=# select e.extname, u.usename
             from pg_extension e
             join pg_user u on e.extowner = u.usesysid;
 extname  |  usename
 plpgsql  | postgres
 hstore   | postgres
 pg_trgm  | postgres
 unaccent | discourse
 vector   | postgres
(5 rows)
It seems there are ‘issues’ just trying to change the extension owner. First reference I found was in 2017 and in 2022 still not implemented.
I used apt to install the new extention and got it to work. Geez. Now to do proper backups and update to Postges 15. But, not tonight. :wink:
My history seemed to get wiped so I can’t tell you exactly how I did that but beware. It requires postgres 13 and will try and reinstall that.
PS: Turns out I had turned on automatic backups but had forgotten about them. Not that I knew where they were. I’ll set up an rsync process to put them in the directory I do my other server backups too.
