Discourse Qingwa Timelines - Custom BBCode for Beautiful Timeline Layouts
:information_source: Summary A Discourse theme component for creating beautiful timeline layouts
:eyeglasses: Preview https://meta.appinn.net/t/topic/76953
:hammer_and_wrench: Repository https://github.com/scavin/discourse-qingwa-timelines
:question: Install Guide How to install a theme or theme component
:open_book: New to Discourse Themes? Beginner’s guide to using Discourse Themes
Install this theme component
I’m excited to share a new theme component that adds elegant timeline layouts to your Discourse community!
This is my first theme component, built with the assistance of LLM.
What is it?
Discourse Timelines is a theme component that implements custom BBCode [timelines]...[/timelines] for creating beautiful, minimalist timeline layouts. Perfect for project roadmaps, step-by-step guides, company histories, chapter divisions, and more.
Published Timeline Effect
Composer Toolbar Button
Markdown Editor View
Key Features
:white_check_mark: Custom BBCode - Simple [timelines] syntax
:white_check_mark: Composer Toolbar Button - No need to type tags manually (solves the new editor bracket escaping issue!)
:white_check_mark: Beautiful Design - Vertical gradient line with clean, minimalist aesthetic
:white_check_mark: Markdown Support - Preserves all formatting inside timelines
:white_check_mark: Multilingual - Built-in translations for 9 languages (EN, ZH_CN, ZH_TW, DE, ES, FR, JA, KO, RU)
:white_check_mark: Theme Compatible - Works with both light and dark modes
:white_check_mark: Customizable - Easily change colors via admin settings
:white_check_mark: Responsive - Mobile-friendly layout
:white_check_mark: Safe - XSS protection built-in
:white_check_mark: No Dependencies - Uses only Discourse native APIs
Usage
Using the Toolbar Button (Easiest!)
  1. Open the composer
  2. Click the “+”(options) menu button
  3. Select “Insert Timeline”
  4. Edit your content
  5. Publish!
The toolbar button solves the issue where the new Discourse editor auto-escapes manually typed square brackets.
Example Syntax
[timelines]
## January 2024 - Project Launch
The project was officially initiated, and the team was formed.
## March 2024 - First Release
Core functionality development completed and beta testing began.
## June 2024 - Version 2.0
Major update with new features:
- Feature A
- Feature B
- Feature C
[/timelines]
Customization
All colors can be customized via theme settings:
  • timeline_gradient_start - Top gradient color (default: #ff7a18)
  • timeline_gradient_end - Bottom gradient color (default: #ffb800)
  • timeline_heading_color - Heading text color (default: #d96d14)
  • timeline_dot_color - Timeline dot color (default: #ff7a18)
  • timeline_heading_color_dark - Dark mode heading color (default: #ff9854)
  • timeline_dot_border_color_dark - Dark mode dot border (optional)
I hope you find this component useful! Please let me know if you have any questions, feedback, or suggestions. :blush:
This is a very nice component! Very useful.
Does this also support pics/video?
Yes, it supports both images and videos.
Here is a quick demo[DEMO LINK]
Very sweet indeed. Awesome work!
Does this work with the DiscoTOC?
It seems to rely on the larger headers, which makes it a little more inflexible with the TOC hierarchy.
I tested it with DiscoTOC and didn’t find any issues.
I’ve added a TOC on the demo page — feel free to open it and see how it works.
Thanks for that reference.
When using it in a post with the autoTOC, it stands out by relying on the header 2 and 3 markdown. Is there any way to shift it to using headers 4 or 5 instead/in addition for more flexibility?
If the timeline appears further down in the TOC hierarchy, like after a header 2 or 3, it causes the TOC to look visually unordered.
EDIT: I can wrap this in [details] tags and it removes the Timeline headers from showing up on the TOC. Reasonable workaround for my purposes fwiw.
Thanks for the suggestion! I’ll look into how to improve this.
You can now keep your timeline headings out of the TOC without workarounds:
use pseudo-headings inside [timelines] by prefixing with ##! (for H2 styling) or ###! (for H3 styling).
Example:
[timelines]
##! 2020 – Foundation
Content…
[/timelines]
These render like H2/H3 inside the timeline but are not treated as real headings, so autoTOC stays tidy regardless of where the timeline sits.
If you want a timeline’s headings to stay in the TOC, keep using normal ##/###.
Right now, if there’s even a single ##! (or ###!) inside [timelines], the TOC will skip the entire timeline.
Mixing both styles in the same timeline isn’t supported yet.
You can mix them now: ##/### still show up in the TOC, while ##!/###! render only inside the timeline and stay out of the TOC.
Please update the component and give it a try.
That’s a clever workaround idea!
This seemed to work fine for
[timelines]
##! 2020 - Foudnation
Content...
###! March
Content
[/timelines]
But not for a pseudo-header following another formatting item like a list:
[timelines]
##! 2020 - Foundation
* Listicle
###! March
Dooooooom!
[/timelines]
The first pseudo-header also prefers to be inline with the opening [timelines] tag to avoid formatting an empty line above. Like:
[timelines]##! 2020 - Foundation
Content...
[/timelines]
Otherwise there’s a gap above the first pseudo-header as if it was a regular, non-header, timeline block line.
Thanks for your work on this, it’s getting incredibly flexible to use now.
Thanks for flagging it.
I’m seeing the same. Right now these render correctly:
  Content...
  [/timelines]
and
  [timelines]
  Content...
  [/timelines]
But this does not work:
  [timelines]
  Content...
  [/timelines]
I’m looking into it but haven’t settled on the right fix yet. :joy:
The code also appears to activate anywhere [timelines] is present in the post, even if it is enclosed in code backticks like above. Escaping with backslash \[timelines] does not appear to make a difference, either.
ETA: the [timelines] and [/timelines] tags appear to escape linebreaks and appear on the same line as the closest text in code blocks with three backticks ```
So
[timelines]
Blah
Blah
[/timelines]
Appears as
[timelines]Blah
Blah[/timelines]
Encountered this while writing up a guide to use it, so it’s probably just an edge case.
