DMenu drop down selected/hover/focus states are a bit confusing
:information_source: Overview
The gist button in desktop view doesn’t seem filled in a consistent way in expanded gists mode for active, enabled and disabled states. for example, here on Meta, it looks and behaves as expected in the default compact view, but the fill properties don’t match on hover and when the expanded view is enabled.
:woman_walking: Repro
In latest view:
  1. when compact is enabled click/tap to drop down (default) - compact button is filled enabled and expanded unfilled disabled, as expected
compact enabled
  1. hover over to select expanded and it fills - but is that the correct hover color?
compact enabled, hover over expanded
  1. go to expanded gists enabled mode. click/tap the gist button to show dropdown - 2 different fill colors when compact should be unfilled like expanded in first screenshot
expanded enabled
  1. hover over to select compact nothing happens, but if you hover over expanded (which is already enabled) it changes to same fill color as compact, which is very confusing. again, i would expect compact button to be unfilled here and then filled when hovered over. i suspect the slightly different fill color above may be the active state (i didn’t look in the console)
expanded enabled, hover over expanded
:white_check_mark: Expected Result
Active, enabled, and disabled button fill colors should be consist for both compact and expanded gists view
Notes
Desktop view only. Safari and Chrome on Macbook, in safe-mode too.
Thanks @Lilly In light theme it is a tiny bit clearer. But I agree it is very odd at the moment.
@interrupt-designer any thoughts?
This is present on any DMenu drop down to my knowledge. The first item is always “focused” for the keyboard.
There were some recent changes here so I’ll take a look.
Should be fixed here:
https://github.com/discourse/discourse/pull/36891
Other DMenus not appropriately assigning --selected to the currently selected option may exist but I will wait until they surface naturally.
