Supported way of adding "IncludeSubdomain" to STS headers
tanya_byrne seeks a supported method to add IncludeSubDomains to STS headers in self-hosted Discourse instances, as their internal scanners require it. Previously, they used sed and replace commands in app.yml, but this stopped working. They tried adding a new 90-hsts.conf file via hooks, but it resulted in duplicate STS headers. supermathie suggested using set_header, but this caused SSL errors and was incorrect since nginx doesn’t support it. pfaffman recommended editing templates/web.ssl.template.yml directly, which is the simplest solution, and advised copying the file to avoid git conflicts. tanya_byrne thanks both for their input.
Hi all,
for our current self hosted Discourse instances, we need to add “IncludeSubDomains” to our STS headers due to this being an expectation of our internal scanners.
Previously I achieved this by using some sed commands in app.yml in custom commands after build to update /etc/nginx/conf.d/discourse.confto include 'add_header Strict-Transport-Security “max-age=31536000; includeSubDomains” always;
as well as:
 - replace:
      filename: "/etc/nginx/conf.d/outlets/discourse/20-https.conf"
      to: add_header Strict-Transport-Security "max-age=31536000; includeSubDomains" always;
      global: true
  - replace:
      filename: "/etc/nginx/conf.d/outlets/server/20-https.conf"
      global: true
This previously worked. However, this has stopped working. I read that creating a new outlet file should allow me to add this using:
hooks:
  after_code:
    - file:
        path: /etc/nginx/conf.d/outlets/server/90-hsts.conf
        chmod: 444
        contents: |
However, this ends up in there being two STS headers present (one from the SSL template and one from my new template). Is there a better way of doing this so I don’t end up with two STS headers? I would have thought that nginx would respect the last header added, and ignore the SSL template header which just contains max-age=31536000; , so is this a defect? Thanks for any guidance you can provide.
Does using set_header instead of add_header solve the problem?
I’ll give this a go and report back :slight_smile:
If I use set_header I get an SSL error on rebuild, with the cert not being recognized and “connection refused” message when attempting to load the forum page.
Some further information, we use our own SSL cert.
These two errors are mutually exclusive…
Sorry, nginx doesn’t have set_header - I misremembered and it’s from another tool.
The easiest option is probably editing templates/web.ssl.template.yml with the new values you want.
I would do that first since it’s easiest. Once you figure it out, the next easiest thing is to copy that file somewhere else so that you don’t have issues with git conflicting with it. The best solution would be to combine your current strategy with another line to remove the other conflicting setting.
Thanks for your help both!
