Solved improvements: Allowing members to indicate they're experiencing a reported issue
When a member finds an unsolved topic that describes an issue they’re also facing, there’s been no easy way for them to signal that or get updates about solutions to the topic. To address this, we’ve added a Me too button to unsolved topics in support categories, which members can click to indicate that they’re impacted by the reported problem and opt-in to receive a notification about the solution.
In this topic, we’ll review the major changes and share how you can start using this today.
:microscope: What’s changed
An unsolved topic in a support category now shows a Me too button in the first post. Members can click it to indicate they’re experiencing the same issue.
When a member clicks Me too, a few things happen:
  • The counter within the button ticks up. The counter always starts at 1 to represent the topic author.
  • The topic tracking will be set to Tracking, which means they’ll receive a notification when the topic is solved.
If a user that’s not logged in (i.e. an anonymous visitor) clicks Me too, they’ll be prompted to log in or create an account. The Me too button disappears once a topic is solved.
:gear: Turning on the “Me too” button in your community
For now, this is considered an experimental change! We’re welcoming your feedback, which will help us make improvements and roll this out further.
To turn this on, head to the Upcoming changes page in your admin area (/admin/config/upcoming-changes) and find the Enable solved shared issues item. Update the Enabled for… field to opt your site in to this new design:
:warning: You must also turn on the Enable support type category setup upcoming change to use this feature.
:mega: What do you think?
We’re eager to hear how this is working in your community — please share your feedback here and let us know how we can continue to improve support categories for you and your members.
28 לייקים
This is neat!
I’d be interested in seeing an option (or perhaps with Data explorer) to be notified as an Admin if X amount of people choose “Me too”.
This seems like a strong way to signal high pain points - and ideal for marking the solution, providing one, or escalating internally for us. Seems especially useful for prior conversations from months ago that I’m not regularly reading now, but people may still be experiencing issues with
8 לייקים
Is it possible for such topics to be bumped when a Me too is clicked? Otherwise topics from years ago could get high counts, but with little visible effect. (Perhaps behind a setting to not create noise for some communities)
לייק 1
Right now, this feature is more focused on the member side (making it easy for members to opt-in to notifications about the topic’s solution), but there are definitely ways we can make it more useful to admins/staff, as well, like reporting on the “Me too” counts or helping those surface in other ways.
Keep the ideas coming!
9 לייקים
Do you have a designated test topic to see this? Not sure if it’s cool to create one in Support just for this.
This may be the nudge that has me convert my existing question/support categories to the “support” type.
This feature is not enabled on Meta.
Let me enable it on https://try.discourse.org/
EDIT
It’s enabled in support - Discourse Demo
4 לייקים
just tried it, it’s working
Thanks!
2 לייקים
While I was setting it up, the power went out in the whole neighborhood and the internet connection went down. Try again now.
5 לייקים
Is this the same as a “boost” with the words “Me too”, or something else?
(P.S. Just checked and it seems to be different.)
לייק 1
It’s completely independent from the boost feature (which is still experimental). By clicking “me too” you opt in to receive a notification when there’s a solution selected. If you used a boost to do that instead, you would not be notified when the topic is solved.
8 לייקים
Not finding this on my forum have all needed things enabled
Have you looked under Admin > Upcoming Changes? For the TWA forum, this is what I see:
So it hasn’t been enabled yet.
לייק 1
I think the “Me too” idea is great.
This is something that has been needed for years. That said, the way I would ideally like to see it implemented may not dovetail with how I understand the current design.
My understanding is that this feature is scoped to the world of Discourse topics. On the OpenAI forum, for example, there is often a broader need for a “Me too” signal when users are affected by outages or service issues, such as OpenAI servers being down, a specific API endpoint not responding, or a Codex regression affecting multiple users.
However, those cases are often tied to systems outside Discourse, such as:
From what I understand, this update does not interact with those external systems. It helps members indicate that they are experiencing the same issue in a Discourse topic and opt in to receive a notification when that topic is solved, but it does not appear to connect that signal to an external status page, GitHub issue, or incident tracker.
A recent OpenAI forum example is this topic:
https://community.openai.com/t/realtime-api-sip-inbound-calls-failing-again-before-webhook-dispatch/1380763
That topic collected multiple user reports and was later linked to this OpenAI Status incident:
https://status.openai.com/incidents/01KRG0AZKH41DV4D9SNJSXM33Q
So, is my understanding correct that the current “Me too” feature is limited to Discourse topics themselves, and does not currently provide a way to connect or synchronize that signal with external systems such as status pages or GitHub issues?
לייק 1
For real-time issues that attract many “Me Too” replies, users often begin reporting that the issue is resolved before it is officially confirmed solved, sometimes even an hour or more earlier.
It might be useful to have a companion option such as “Works for me now” or “Resolved for me” that is also tracked and signaled.
The idea would be that “Me Too” helps show how many users are affected, while “Works for me now” helps show when the issue may be clearing up in practice.
Here is a real world example of this:
לייק 1
I had just updated the forum after posting here but i did look there let me check again
cause when i searched for it i did not find it
Ok now i see it and was able to enable it thank you nate
לייק 1
Nice idea, I like it!
Two things
No. It says “me too”. It should start at no counter ie. 0.
Additionally, it would be nice to be able to see who clicked “me too” in a topic.
8 לייקים
The counter represents how many people are impacted by the issue, so it starts at one to reflect the topic author.
4 לייקים
I think I’m with @RGJ on this one. Having seen it in action on this topic, I thought “wow, kinda interesting to see someone else experiencing this seemingly niche issue” to then realise it was still just the OP.
“too” is additional. It implies additional to the OP, not inclusive of
7 לייקים
In that case the button should be called “I have this issue”.
But “too” indicates additional users.
8 לייקים
I really like this idea! I’ve been seeing it on Meta and was fairly confused when I noticed every topic had at least one and thought that somebody must have gone down the list and voted for everything but I learned that wasn’t the case when I went to the sandbox, made a topic, and noticed I had automatically voted for it.
It seems weird to me that the “me too” button is automatically selected for the reporter. I’m not sure how other platforms implement it but I would have figured it’s more similar to liking where you can’t select it on your own posts. Obviously this is a nonissue but I’m just a little confused as to why I’m automatically saying “me too” to my own problems.
Edit: oops.. this was a discussion already, should have scrolled down a little more. I’ll leave this up though because what I said still stands :sweat_smile:
2 לייקים
