Cut off "Dismiss ⌄" button
Hi! :blob-wave-reverse:
The Dismiss button has an empty space between the label and the dropdown chevron icon.
It happens on all themes :slight_smile:
This seems intentional from when the component was added, but doesn’t work well on other themes I guess. :slightly_smiling_face:
Yes exactly, it’s an intended design effect. I believe the modernisation changes may have broken it’s design. Will take a look when I have some time.
