Bot enter button fix for Discourse AI
:information_source: Summary Reverts the Enter button to it’s usual new line behaviour for the post conversation with Discourse AI Bot
:hammer_and_wrench: Repository https://github.com/Lillinator/bot-enter-button-fix.git
:question: Install Guide How to install a theme or theme component
Install this theme component
:warning: this component is deprecated and should not be used. there is now a core setting in user → preferences → interface which allows users to toggle the feature on and off. the repo has been archived.
This simple theme component reverts the annoying Enter button submission behaviour on the post messages in conversations with the Bot in the Discourse AI plugin (messages, not chat). Hitting Enter goes to a new line, while submitting the post message to the Discourse AI bot will require clicking/tapping the paper-plane icon.
There are no settings. Simply install the theme component as usual, add it to your selected themes, and refresh your browser.
This component works whether you have the docked composer enabled or not.
Check out my other Discourse stuff
this component is deprecated because the ai team added a user preferences setting to control this behavior
