Component tests render a single component in isolation and assert on the DOM it produces. They are faster and more focused than acceptance tests, which boot the whole application and visit a route. To run them, see Run test suites.
Where tests live
| Code under test | Test location |
| Core | frontend/discourse/tests/integration/components/** |
Core ui-kit |
frontend/discourse/tests/integration/ui-kit/** |
| Plugin | plugins/<name>/test/javascripts/integration/** |
Name the file after the component with a -test.gjs suffix. The .gjs format lets the test import the component and invoke it in an inline <template>, the same way production code does.
A first test
import { render } from "@ember/test-helpers";
import { module, test } from "qunit";
import { setupRenderingTest } from "discourse/tests/helpers/component-test";
import DPageSubheader from "discourse/ui-kit/d-page-subheader";
module("Integration | Component | DPageSubheader", function (hooks) {
setupRenderingTest(hooks);
test("renders the title", async function (assert) {
await render(
<template><DPageSubheader @titleLabel="Settings" /></template>
assert
.dom(".d-page-subheader__title")
.hasText("Settings", "shows @titleLabel");
- Import
setupRenderingTestfromdiscourse/tests/helpers/component-test, not fromember-qunit. The Discourse wrapper also sets upthis.siteSettings,this.siteand a logged-inthis.currentUser. Pass{ anonymous: true }as the second argument to render as a guest. - The module title ends with the component’s invocation name in PascalCase (
DPageSubheader, notd-page-subheader). - Assert with qunit-dom (
assert.dom(...)), and give every assertion a description so a failure says what broke. - Plugin components are imported from
discourse/plugins/<name>/discourse/components/....
Interacting with the component
The helpers in @ember/test-helpers (click, fillIn, triggerKeyEvent, …) dispatch real DOM events and wait for the resulting render. Always await them.
To check what the component reports back, pass a function that records its calls with assert.step:
import { click, render } from "@ember/test-helpers";
import DButton from "discourse/ui-kit/d-button";
test("calls @action on click", async function (assert) {
const onClick = () => assert.step("clicked");
await render(
<template><DButton @action={{onClick}} @translatedLabel="Save" /></template>
await click(".btn");
assert.verifySteps(["clicked"], "calls @action once");
Changing arguments after render
To test how a component reacts when its arguments change, hold the value in a standalone tracked() from @glimmer/tracking. Pass its .value to the component, then assign a new .value:
import { tracked } from "@glimmer/tracking";
import { render, rerender } from "@ember/test-helpers";
test("follows @titleLabel", async function (assert) {
const title = tracked("First");
await render(
<template><DPageSubheader @titleLabel={{title.value}} /></template>
title.value = "Second";
await rerender();
assert
.hasText("Second", "shows the new title");
- Use one
tracked()per argument, instead ofthis.set(...)on the test context or a test-only class with@trackedfields. Values that don’t change can be local constants, or native assignments to the test context (this.title = "a") before render. - When the component writes a value back through a callback, such as
@onChange, the callback assigns the tracked value:const onChange = (newValue) => (value.value = newValue). A value a callback only records for the test to assert on is a plain locallet. - When the test changes properties of an object it passes in, such as a model, make that object a
trackedObject(from@ember/reactive/collections) and assign its properties instead. await rerender()before the next assertion or interaction: unlikethis.set, a tracked write does not re-render synchronously. Useawait settled()instead when the change starts async work, such as a request.- Start with the first value the test asserts. To start empty, use
tracked(undefined): a baretracked()returns a decorator, and so does a single plain object whose keys are all option names (value,initializer,equals,description). Passing options as well forces the value form:tracked({}, {}). - Assigning a value that is
Object.is-equal to the current one does not re-render. Pass{ equals: () => false }as the second argument if a test relies on that.
Stubbing requests
A default Pretender server answers common endpoints. Add or override a route inside the test:
import pretender, { response } from "discourse/tests/helpers/create-pretender";
test("shows the loaded items", async function (assert) {
pretender.get("/admin/things.json", () => response({ things: [] }));
// render and assert...
response(body) replies with a 200; response(status, body) sets the status. Stub the network boundary like this rather than stubbing the component’s own collaborators.
This document is version controlled - suggest changes on github.
