Add crop feature for avatars
Can we add a crop feature to discourse so my photoshopped pikachu’s ear won’t be cut off?
לייק 1
Not on the current roadmaps; try cropping it in a paint program for now, then uploading the cropped version.
3 לייקים
This won’t help you on meta but in your Discourse, you can go back to square avatars using CSS.
4 לייקים
Almost 10 years later and this is still not implemented, which is a bit weird, because most platforms allow this.
Any plans to do it? Any plugins/components out there that allow this?
Not all users want to add this extra step of editing an image beforehand. I like to remove all the friction, as much as possible, and this is one of them for sure.
There’s another request for this:
2 לייקים
There’s also a third topic about it :slight_smile:
2 לייקים
Yes, something along these lines where the crop would be fixed to a square, where we could zoom in/out and drag:
Also, even though not fully on topic, a way to drag and drop an image. There are other places where we can do that, using it for the avatar as well would be great.
3 לייקים
