1.9.0.beta11 Updates Not Showing Up with `git pull`
#1
Hey everyone, my forum emailed me about an update. I’m on 1.9.0.beta10. I entered /var/discourse and tried to run a git pull but it says I’m up to date… yet I’m not!
I’m currently (and always) on the master branch, and when I do git log, the most recent thing I have is commit ee9a607677106603ace3e90f3c5bd9ca84a11ef7 from Fri Sep 15 08:27:27 2017 +0800 (Upgrade to Ruby 2.4.2).
Is my repository busted? Github having issues?
Thanks!
(Jay Pfaffman) #2
That updates discourse_docker, not discourse.
./launcher rebuild app
(Neil Lalonde) #3
You should try using the upgrade web UI instead of doing it that way, assuming you’re using a Docker install.
#4
Ahhh, thanks gentlemen!
Regarding the upgrade Web UI, it’s always stuck at this:
I’m pretty sure it’s a CloudFlare issue, which I still haven’t configured perfectly (that’s on my agenda right now).
Here’s what’s in my console:
Failed to load resource: the server responded with a status of 403 ()
docker-manager-vendor-69993a2….js:6 Request was rejected because user is not permitted to perform this operation.
Error
Anyway, will rebuild app, which no longer brings the whole thing down for 10+ minutes thanks to @pfaffman setting up my separate containers!!
