I have two duplicate posted topics, each titled the same as the category they’re in, and each with a -1 reply count. If clicked, neither topic has content, and there isn’t a wrench to delete the topic.
Two questions: (1) how do I delete these topics? (2) how did this happen? I’d like to avoid this happening in the future.
Thank you in advance!
Joshua_Kogan:
How did you create these two topics? By any chance, did they show up after a migration of some sort? Are you running any unofficial plugins?
Does this happen for all new topics you create or just these two?
$ rails c
> Topic.find(id).destroy
Where id
is the topic_id in your browser url.
rishabh:
I have no idea how these were created, actually. No migration, and yes, (several) unofficial plugins.
Just these two.
I will try your method of destroying g the topics. Thank you!
You’re confident these are not the required “About {category}” category description topics? Deleting those will cause bad things to happen, so I want to make sure.
The “about” topic is there:
Can I simply destroy the category? I’m not invested in it, and it would be easy to set it back up.
I see -1 reply counts when a topic that was in the review queue gets deleted eg. “?status=deleted”
AFAIK non-staff members would not see any -1 counts so I’ve not considered it to be a high priority concern.
Related, "1"s can go to "0"s
Dax
(Daniela)
August 19, 2019, 4:42pm
#8
@Joshua_Kogan take a look here
I am trying to remove some categories in favor of using tags, but I end up with one system created topic that I cannot delete (it is Technical in the screenshot, notice the -1 replies). If I try to visit this topic the page freezes and I have to close the tab and start over. Any idea how to delete this, possibly in rails?
[image]
you should be able to solve the issue.
Thank you, @Dax . That was a really big help!
