הרץ שאילתות Data Explorer עם API של Discourse
:bookmark: This guide explains how to use the Discourse API to create, run, and manage queries with the Data Explorer plugin.
:person_raising_hand: Required user level: Administrator
Virtually any action that can be performed through the Discourse user interface can also be triggered with the Discourse API.
This document provides a comprehensive overview for utilizing the API specifically in conjunction with the Data Explorer plugin.
For a general overview of how to find the correct API request for an action, see: Reverse engineer the Discourse API .
Running a Data Explorer query
To run a Data Explorer query via the API, make a POST request to /admin/plugins/discourse-data-explorer/queries/<query-id>/run. You can find the query ID by visiting it through your Discourse site and checking the id parameter in the address bar.
Below is an example query with an ID of 20 that returns topics by views on a specified date:
--[params]
-- date :viewed_at
SELECT
topic_id,
COUNT(1) AS views_for_date
FROM topic_views
WHERE viewed_at = :viewed_at
GROUP BY topic_id
ORDER BY views_for_date DESC
This query can be run from a terminal with:
curl -X POST "https://your-site-url/admin/plugins/discourse-data-explorer/queries/20/run" \
-H "Content-Type: multipart/form-data;" \
-H "Api-Key: <api-key>" \
-H "Api-Username: system" \
-F 'params={"viewed_at":"2019-06-10"}'
Note that you’ll need to replace the <api-key>, <your-site-url> with your API key and domain.
Handling large datasets
The Data Explorer plugin limits JSON results to 1000 rows by default (controlled by the hidden data_explorer_query_result_limit site setting). You can override this per-request by passing a limit parameter, up to a maximum of 10,000:
-F "limit=5000"
For datasets larger than 10,000 rows, you’ll need to paginate at the SQL level. You can use the example query below:
--[params]
-- integer :limit = 100
-- integer :page = 0
SELECT *
FROM generate_series(1, 10000)
OFFSET :page * :limit
LIMIT :limit
To fetch the results page-by-page, increment the page parameter in the request:
curl -X POST "https://your-site-url/admin/plugins/discourse-data-explorer/queries/27/run" \
-F 'params={"page":"0"}'
Stop when result_count is zero.
For additional information about handling large datasets, see: Result Limits and Exporting Queries
Removing relations data from the results
When Data Explorer queries are run through the user interface, a relations object is added to the results. This data is used for rendering the user in UI results, but you are unlikely to need it when running queries via the API.
To remove that data from the results, add a download=true parameter with your request:
-F 'params={"page":"0"}' \
-F "download=true"
API authentication
Details about generating an API key for the requests can be found here: Create and configure an API key .
If the API key is only going to be used to run Data Explorer queries, you can select “Granular” from the Scope drop down menu, then select the “run queries” scope.
FAQs
Is there any api endpoint I can use to get the list of reports and the ID numbers? I want to build a dropdown with the list in it?
Yes, you can make an authenticated GET request to /admin/plugins/discourse-data-explorer/queries.json to get a list of all queries on the site.
Is it possible to create queries through the api?
Yes. Documentation on how to do that are at Create a Data Explorer query using the API
Is it possible to send parameters with the post request?
Yes, include SQL parameters using the -F option, as shown in the examples.
Is CSV export for queries supported by the API?
Yes. Append .csv to the run endpoint URL to get results in CSV format:
curl -X POST "https://your-site-url/admin/plugins/discourse-data-explorer/queries/20/run.csv" \
CSV responses default to returning up to 10,000 rows. You can pass a limit parameter to reduce this.
Additional resources
40 לייקים
Watching API
"DataExplorer::ValidationError: Missing parameter end_date of type string
Get total list of topics and their view counts from Discourse API
Reports by Discourse
Passing params to Data Explorer using API requires enclosing a value
Category API request downloads all topics
Best API for All First Posts in a Category
Get Latest topic for Current user
TimeStamp of Tag
How can I get the list of Discourse Topic IDs dynamically
How to get a full list of badges of all users
API rate limits
Getting recently updated posts using the REST API
`DataExplorer::ValidationError: Missing parameter` when running Data Explorer queries with [params] via API
Validation error even when parameter passed while running data explorer API with Curl
Backend data retrieve for analytics
Discourse-user-notes API
Admin dashboard report reference guide
How to query the topics_with_no_response.json API with filters
Use API to get topics for a period using js
Access Discourse database with n8n
Why getUserById doesn't return the user's email?
Grant a custom badge through the API
Is there an API endpoint for recently edited posts
How to query gamification score via the API?
1.5X cheers on specific TL's or groups
Page Publishing
Identifying users in multiple groups using AND rather than OR?
How to fetch posts/topics by multiple usernames
Restrict moderator access to only the stats panel on the admin dashboard?
How to change the response default_limit in data explorer?
Order/Filter searched topics by latest update to First Post
API Filter users by emails, including secondary emails
Download a user's posting history via Discourse API?
Ability to have granular scope for data explorer?
Discourse forum traffic query data
Interact with discourse from Python?
Daily, weekly, or total stats by user over a specified time range
Looking for help posting automating data explorer reports to my forum
How to get all topics from a specific category using offset/page param in the API query?
Discourse 有哪个接口能直接获取某个帖子的最后一条评论信息
想得到活跃的用户——通过api
API endpoint to create invite links has moved to /invites.json
How to get a password from database?
Can I send an external URL to the Discourse API for it to return topics linking to that URL?
How to get all the deleted posts for a specific topic
Discourse Data Explorer Query Response to Slack
Filter topics in category containing file attachments
Discord Integration with Webhooks
Download result of queries into Google Spreadsheet
Who's online "API"?
Is there any endpoint that would provide a user's external account IDs from their Discourse ID?
API post request without an Accept header returns 406
Best way to get (via API) a list of users from a group, and their bios
Automate the syncing of Discourse queries to Google Sheets
This comment seems to imply that you can do CSV export from the API. Is that possible? Just curious because I need the data as CSV. I can always get it as JSON and convert to CSV but if there is a built-in way to get CSV that would be a little easier.
Is it possible to do a query ‘like created or updated the last 50 seconds’?
:robot: AI says
-- [params]
-- int :seconds = 50
SELECT
    p.id AS post_id,
    p.created_at,
    p.updated_at,
    p.raw AS post_content,
    p.user_id,
    t.title AS topic_title,
    t.id AS topic_id
FROM posts p
INNER JOIN topics t ON t.id = p.topic_id
WHERE
    (EXTRACT(EPOCH FROM (NOW() - p.created_at)) <= :seconds
    OR EXTRACT(EPOCH FROM (NOW() - p.updated_at)) <= :seconds)
    AND p.deleted_at IS NULL
    AND t.deleted_at IS NULL
ORDER BY p.created_at DESC
LIMIT 50
Did a quick test, it seems to work :slight_smile:
לייק 1
I don’t see the “like :heart:” I added to a post using your query.
I think you need to use post_actions
--[params]
--string :timespan = 50 seconds
SELECT post_id,
       user_id,
       created_at,
       updated_at,
       deleted_at
FROM  post_actions
WHERE post_action_type_id=2 AND updated_at > NOW() - INTERVAL :timespan
Version with more beautiful results
--[params]
--boolean :include_in_timespan_deleted = false
SELECT
  post_id,
  user_id,
  CASE
    WHEN EXTRACT(EPOCH FROM (NOW() - created_at)) < 60 THEN CONCAT(ROUND(EXTRACT(EPOCH FROM (NOW() - created_at))), ' seconds ago')
    WHEN EXTRACT(EPOCH FROM (NOW() - created_at)) < 3600 THEN CONCAT(ROUND(EXTRACT(EPOCH FROM (NOW() - created_at)) / 60), ' minutes ago')
    WHEN EXTRACT(EPOCH FROM (NOW() - created_at)) < 86400 THEN CONCAT(ROUND(EXTRACT(EPOCH FROM (NOW() - created_at)) / 3600), ' hours ago')
    ELSE CONCAT(ROUND(EXTRACT(EPOCH FROM (NOW() - created_at)) / 86400), ' days ago')
  END AS relative_created_at,
  CASE
    WHEN EXTRACT(EPOCH FROM (NOW() - updated_at)) < 60 THEN CONCAT(ROUND(EXTRACT(EPOCH FROM (NOW() - updated_at))), ' seconds ago')
    WHEN EXTRACT(EPOCH FROM (NOW() - updated_at)) < 3600 THEN CONCAT(ROUND(EXTRACT(EPOCH FROM (NOW() - updated_at)) / 60), ' minutes ago')
    WHEN EXTRACT(EPOCH FROM (NOW() - updated_at)) < 86400 THEN CONCAT(ROUND(EXTRACT(EPOCH FROM (NOW() - updated_at)) / 3600), ' hours ago')
    ELSE CONCAT(ROUND(EXTRACT(EPOCH FROM (NOW() - updated_at)) / 86400), ' days ago')
  END AS relative_updated_at,
  CASE
    WHEN deleted_at IS NULL THEN 'no'
    WHEN EXTRACT(EPOCH FROM (NOW() - deleted_at)) < 60 THEN CONCAT(ROUND(EXTRACT(EPOCH FROM (NOW() - deleted_at))), ' seconds ago')
    WHEN EXTRACT(EPOCH FROM (NOW() - deleted_at)) < 3600 THEN CONCAT(ROUND(EXTRACT(EPOCH FROM (NOW() - deleted_at)) / 60), ' minutes ago')
    WHEN EXTRACT(EPOCH FROM (NOW() - deleted_at)) < 86400 THEN CONCAT(ROUND(EXTRACT(EPOCH FROM (NOW() - deleted_at)) / 3600), ' hours ago')
    ELSE CONCAT(ROUND(EXTRACT(EPOCH FROM (NOW() - deleted_at)) / 86400), ' days ago')
  END AS relative_deleted_at
FROM
  post_actions
WHERE
  post_action_type_id = 2
  AND (
    OR (deleted_at IS NOT NULL AND deleted_at > NOW() - INTERVAL :timespan)
2 לייקים
Oooh I misread! I read the sentence as "Is it possible to do a query like ‘created or updated the last 50 seconds’?
(notice the single quote position)
לייק 1
Thanks all,
I posted here because that is where ask.discourse pointed me to.
What I’m looking for is if the API is providing this capability.
לייק 1
Yes, of course.
You create the query in data explorer, then you run the query through the API as described in this guide.
I just ran Moin’s query via the API and it properly returned the expected results.
4 לייקים
I was wondering about this too. Is JSON the only way of exporting data via the API or is CSV export also supported for Data Explorer?
Thanks all,
Sorry for the late response - was offline for a bit.
What I’m currently doing is to search for all topics/posts created today, and filter out the topics/posts updated before the timestamp.
לייק 1
If you don’t want to get your hands dirty, you can ask the bot at ask.discourse.com. It’s usually pretty accurate regarding Discourse-related SQL queries (but don’t assume it’s right, check the code to be sure).
לייק 1
Is the Content-Type header correct?
In the developer tools, when inspecting a Data Explorer query with params , the Content-Type header appears as:
Content-Type: application/x-www-form-urlencoded; charset=UTF-8
However, the current cURL command includes:
לייק 1
  • multipart/form-data
  • application/x-www-form-urlencoded
  • application/json
are all valid content-types you can use when making an api request.
לייק 1
@blake
language python
library requests
Could you provide a API sample Data Explorer query that includes three parameters
refer
[Topic]( Passing params to Data Explorer using API requires enclosing a value ) which says params need to be strictly in double quotes
Sure, here is an example using python:
import json
import requests
API_KEY      = "YOUR_API_KEY"
API_USERNAME = "system"
QUERY_ID     = 20
SITE_URL     = "https://your-site-url"
# all values must be strings
params = {
    "user_id":   "2",
    "viewed_at": "2019-06-10",
    "limit":     "5"
# Data Explorer expects params as a JSON‐encoded string
payload = {
    "params": json.dumps(params)
url = f"{SITE_URL}/admin/plugins/explorer/queries/{QUERY_ID}/run"
headers = {
    "Api-Key":       API_KEY,
    "Api-Username":  API_USERNAME,
    "Content-Type":  "application/json"
r = requests.post(url, headers=headers, json=payload)
r.raise_for_status()
print(r.json())
3 לייקים
