Setup DiscourseConnect - Official Single-Sign-On for Discourse (sso)
DiscourseConnect is a core Discourse feature that allows you to configure “Single Sign-On (SSO)” to completely outsource all user registration and login from Discourse to another site. Offered to our pro, business and enterprise hosting customers.
:information_source: (Feb 2021) ‘Discourse SSO’ is now ‘DiscourseConnect’. If you are running an old version of Discourse, the settings below will be named sso_... rather than discourse_connect_...
The Problem
Many sites wishing to integrate with a Discourse site want to keep all user registration in a separate site. In such a setup all login operations should be outsourced to that different site.
What if I would like SSO in conjunction with existing auth?
The intention around DiscourseConnect is to replace Discourse authentication, if you would like to add a new provider see existing plugins such as: Discourse VK Authentication (vkontakte)
Enabling DiscourseConnect
To enable DiscourseConnect you have 3 settings you need to fill out:
enable_discourse_connect : must be enabled, global switch
discourse_connect_url: the offsite URL users will be sent to when attempting to log on
discourse_connect_secret: a secret string used to hash SSO payloads. Ensures payloads are authentic.
Once enable_discourse_connect is set to true:
  • Clicking on login or avatar will, redirect you to /session/sso which in turn will redirect users to discourse_connect_url with a signed payload.
  • Users will not be allowed to “change password”. That field is removed from the user profile.
  • Users will no longer be able to use Discourse auth (username/password, google, etc)
What if you check it by mistake?
See: Log back in as admin after locking yourself out with read-only mode or an invalid SSO configuration
Implementing DiscourseConnect on your site
:warning: Discourse uses emails to map external users to Discourse users, and assumes that external emails are secure. IF YOU DO NOT VALIDATE EMAIL ADDRESSES BEFORE SENDING THEM TO DISCOURSE, YOUR SITE WILL BE EXTREMELY VULNERABLE!
Alternatively, if you insist on sending unvalidated emails BE SURE to set require_activation=true, this will force all emails to be validated by Discourse. WE STILL STRONGLY ADVISE THAT YOU DO NOT DO THIS, so if you proceed with that setting enabled, you are assuming substantial risk.
Discourse will redirect clients to discourse_connect_url with a signed payload: (say discourse_connect_url is https://somesite.com/sso)
You will receive incoming traffic with the following
https://somesite.com/sso?sso=PAYLOAD&sig=SIG
The payload is a Base64 encoded string comprising of a nonce, and a return_sso_url. The payload is always a valid querystring.
For example, if the nonce is ABCD. raw_payload will be:
nonce=ABCD&return_sso_url=https%3A%2F%2Fdiscourse_site%2Fsession%2Fsso_login, this raw payload is base 64 encoded.
The endpoint being called must
  1. Validate the signature: ensure that HMAC-SHA256 of PAYLOAD (using discourse_connect_secret, as the key) is equal to the sig (sig will be hex encoded).
  2. Perform whatever authentication it has to
  3. Create a new url-encoded payload with at least nonce, email, and external_id. You can also provide some additional data, here’s a list of all keys that Discourse will understand:
    • nonce should be copied from the input payload
    • email must be a verified email address. If the email address has not been verified, set require_activation to “true”.
    • external_id is any string unique to the user that will never change, even if their email, name, etc change. The suggested value is your database’s ‘id’ row number.
    • username will become the username on Discourse if the user is new or SiteSetting.auth_overrides_username is set.
    • name will become the full name on Discourse if the user is new or SiteSetting.auth_overrides_name is set.
    • avatar_url will be downloaded and set as the user’s avatar if the user is new or SiteSetting.discourse_connect_overrides_avatar is set.
    • avatar_force_update is a boolean field. If set to true, it will force Discourse to update the user’s avatar, whether avatar_url has changed or not.
    • bio will become the contents of the user’s bio if the user is new, their bio is empty or SiteSetting.discourse_connect_overrides_bio is set.
    • title will set the user’s title.
    • website will set the user’s website on their profile.
    • location will set the user’s location on their profile.
    • profile_background_url will be downloaded and set as the user’s profile background if the user is new or SiteSetting.discourse_connect_overrides_profile_background is set.
    • card_background_url will be downloaded and set as the user’s card background if the user is new or SiteSetting.discourse_connect_overrides_card_background is set.
    • locale will set the user’s locale if the user is new and SiteSetting.allow_user_locale is enabled.
    • locale_force_update is a boolean field. If set to true alongside locale, it will force the locale to update for existing users (requires SiteSetting.allow_user_locale).
    • Additional boolean (“true” or “false”) fields are: admin, moderator, suppress_welcome_message, logout
  4. Base64 encode payload
  5. Calculate a HMAC-SHA256 hash of the payload using discourse_connect_secret as the key and Base64 encoded payload as text
  6. Redirect back to the return_sso_url with an sso and sig query parameter (http://discourse_site/session/sso_login?sso=payload&sig=sig)
Discourse will validate that the nonce is valid, and if valid, it will expire it right away so it can not be used again. Then, it will attempt to:
  1. Log the user on by looking up an already associated external_id in the SingleSignOnRecord model
  2. Log the user on by using the email provided (updating external_id) (unless require_activation = true)
  3. Create a new account for the user providing (email, username, name) updating external_id
Security concerns
The nonce (one time token) will expire automatically after 30 minutes. This means that as soon as the user is redirected to your site they have 30 minutes to log in / create a new account.
The protocol is safe against replay attacks as nonce may only be used once. The nonce is tied to the current browser session to protect against CSRF attacks.
Specifying group membership
If the discourse connect overrides groups option is specified, Discourse will consider the comma separated list of groups passed in groups.
Aside from groups, you may also specify group membership in your SSO payload using the add_groups and remove_groups attributes regardless of the discourse connect overrides groups option.
add_groups is a comma delimited list of group names we will ensure the user is a member of.
remove_groups is a comma delimited list of group names we will ensure the user is not a member of.
Reference implementation
Discourse contains a reference implementation of the SSO class:
A trivial implementation would be:
class DiscourseSsoController < ApplicationController
  def sso
    secret = "MY_SECRET_STRING"
    sso = DiscourseApi::SingleSignOn.parse(request.query_string, secret)
    sso.email = "user@email.com"
    sso.name = "Bill Hicks"
    sso.username = "bill@hicks.com"
    sso.external_id = "123" # unique id for each user of your application
    sso.sso_secret = secret
    redirect_to sso.to_url("http://l.discourse/session/sso_login")
Transitioning to and from single sign on.
As long as the require_activation parameter is not set to true in the request payload, the system will trusts emails provided by the single sign on endpoint. This means that if you had an existing account in the past on Discourse with DiscourseConnect disabled, DiscourseConnect will simply re-use it and avoid creating a new account.
If you ever turn off DiscourseConnect, users will be able to reset passwords and gain access back to their accounts.
Real world example:
Given the following settings:
Discourse domain: http://discuss.example.com
DiscourseConnect url : http://www.example.com/discourse/sso
DiscourseConnect secret: d836444a9e4084d5b224a60c208dce14
Email validated: No (add require_activation=true to the payload)
User attempt to login
  • Nonce is generated: cb68251eefb5211e58c00ff1395f0c0b
  • Raw payload is generated: nonce=cb68251eefb5211e58c00ff1395f0c0b
  • Payload is Base64 encoded: bm9uY2U9Y2I2ODI1MWVlZmI1MjExZTU4YzAwZmYxMzk1ZjBjMGI=
  • Payload is URL encoded: bm9uY2U9Y2I2ODI1MWVlZmI1MjExZTU4YzAwZmYxMzk1ZjBjMGI%3D
  • HMAC-SHA256 is generated on the Base64 encoded Payload: 1ce1494f94484b6f6a092be9b15ccc1cdafb1f8460a3838fbb0e0883c4390471
Finally browser is redirected to:
http://www.example.com/discourse/sso?sso=bm9uY2U9Y2I2ODI1MWVlZmI1MjExZTU4YzAwZmYxMzk1ZjBjMGI%3D&sig=1ce1494f94484b6f6a092be9b15ccc1cdafb1f8460a3838fbb0e0883c4390471
On the other end
  1. Payload is validated using HMAC-SHA256, if the sig mismatches, process aborts.
  2. By reversing the steps above nonce is extracted.
User logs in:
external_id: hello123
email: test@test.com
username: samsam
require_activation: true
Unsigned payload is generated:
nonce=cb68251eefb5211e58c00ff1395f0c0b&name=sam&username=samsam&email=test%40test.com&external_id=hello123&require_activation=true
order does not matter, values are URL encoded
bm9uY2U9Y2I2ODI1MWVlZmI1MjExZTU4YzAwZmYxMzk1ZjBjMGImbmFtZT1zYW0mdXNlcm5hbWU9c2Ftc2FtJmVtYWlsPXRlc3QlNDB0ZXN0LmNvbSZleHRlcm5hbF9pZD1oZWxsbzEyMyZyZXF1aXJlX2FjdGl2YXRpb249dHJ1ZQ==
bm9uY2U9Y2I2ODI1MWVlZmI1MjExZTU4YzAwZmYxMzk1ZjBjMGImbmFtZT1zYW0mdXNlcm5hbWU9c2Ftc2FtJmVtYWlsPXRlc3QlNDB0ZXN0LmNvbSZleHRlcm5hbF9pZD1oZWxsbzEyMyZyZXF1aXJlX2FjdGl2YXRpb249dHJ1ZQ%3D%3D
Base64 encoded Payload is signed
3d7e5ac755a87ae3ccf90272644ed2207984db03cf020377c8b92ff51be3abc3
Browser redirects to:
http://discuss.example.com/session/sso_login?sso=bm9uY2U9Y2I2ODI1MWVlZmI1MjExZTU4YzAwZmYxMzk1ZjBjMGImbmFtZT1zYW0mdXNlcm5hbWU9c2Ftc2FtJmVtYWlsPXRlc3QlNDB0ZXN0LmNvbSZleHRlcm5hbF9pZD1oZWxsbzEyMyZyZXF1aXJlX2FjdGl2YXRpb249dHJ1ZQ%3D%3D&sig=3d7e5ac755a87ae3ccf90272644ed2207984db03cf020377c8b92ff51be3abc3
Synchronizing DiscourseConnect records
You can use the POST admin endpoint /admin/users/sync_sso to synchronize a DiscourseConnect record, pass it the same record you would pass to the DiscourseConnect endpoint, nonce does not matter.
If you call admin/users/sync_sso from another site, you will need to include a valid admin api_key and a valid api_username in the request’s headers. See Sync DiscourseConnect user data with the sync_sso route for more details about how to structure the request.
Clearing DiscourseConnect records
If your external_id values from your DiscourseConnect provider have changed (perhaps you changed the generation algorithm, perhaps it’s a different endpoint) you can safely remove all the existing records using the rails console:
SingleSignOnRecord.destroy_all
Logging off users
You can use the POST admin endpoint /admin/users/{USER_ID}/log_out to log out any user in the system if needed.
To configure the endpoint Discourse redirects to on logout search for the logout redirect setting. If no URL has been set here you will be redirected back to the URL configured in discourse connect url.
Search users by external_id
User profile data can be accessed using the /users/by-external/{EXTERNAL_ID}.json endpoint. This will return a JSON payload that contains the user information, including the user_id which can be used with the log_out endpoint.
Existing implementations
  • The discourse_api gem can be used for SSO. Have a look at the SSO code in its examples directory to see a basic implementation.
  • Our WordPress plugin makes it easy to configure SSO between WordPress and Discourse. Details about setting it up are found on the SSO tab of the plugin’s options page.
Future work
  • We would like to gather more reference implementations for SSO on other platforms. If you have one please post to the Dev / SSO category.
Advanced Features
  • You can pass through custom user fields by prefixing the field name with custom. For example custom.user_field_1 can be used to set the value of the UserCustomField that has the name user_field_1.
  • You can pass avatar_url to override user avatar (SiteSetting.discourse_connect_overrides_avatar needs to be enabled). Avatars are cached so pass avatar_force_update=true to force them to update if the url is the same. Right now, you can’t pass an empty url to disable users’ avatar.
  • By default the welcome message will be sent to all new users created through SSO. If you wish to suppress this you can pass suppress_welcome_message=true
  • To configure your Discourse instance as a Discourse connect provider see: Using DiscourseConnect as an identity provider.
Debugging your DiscourseConnect provider
To assist in debugging DiscourseConnect you may enable the site setting verbose_discourse_connect_logging. By enabling that site setting rich diagnostics will show up in YOURSITE.com/logs. Be sure to :white_check_mark: the warnings box at the bottom of YOURSITE.com/logs.
We will log a warning to the logs with a full dump of the SSO payload:
:spiral_notepad: Need to automate user sign-ups? See Auto-provisioning user accounts when SSO is enabled
Discourse SSO + normal login
SSO login & logout issues
Is there a "log_in" SSO API endpoint?
SSO locked me out of Discourse!
What is the SSO login URL
With SSO my user still need to hit the login button
SSO Login page not showing up
How to handle Discourse SSO when the authentication site allows users to change emails?
"User Log out API" return success in response but user session still alive
SSO integration & external profile sync help
Discourse SSO using auth0 via URL
SSO on Discourse using Atlassian Crowd
Mobile (firebase) SSO authentication
Login to Discourse with website account details
Single Sign-Out?
About the SSO category
Shibboleth / SAML / SSO -- Working Implementation for Higher Ed
How to generate nonce from client-side Javascript
Logout POST Request
Advantage and disadvantage of enabling SSO
Customized login auth plugin
Merging users from different forums
User Fields to validate users
Automatic session management with OAuth SSO
SSO and e-mail addresses having a plus sign
Automatically assigning users to a group
Users who register on my site, register also on Discourse Vise Versa
Custom Login / Registration from another API
Using existing RoR application for user auth / signup instead of discourse
Switching out authentication for a passwordless alternative
Enable sso for my site
Hashing Secret + Payload for SSO
SSO with TownNews CMS
Will Discourse ask for a username if it's not provided to /session/sso_login?
A way for admins to edit users' external IDs
Categorizing and tracking users
Discourse Ruby API testing "Unknown attribute 'auth_token' for User
Disable email verification for SSO
[PAID] Setup SSO for self-hosted instance
Getting signed data from the server
SSO and changing email addresses upstream
SSO (maybe) specific issue
Why isn't Discourse more frequently recommended as a "community platform"?
Integration with .NET MVC application for a SaaS platform
Running my own discourse image
How do I make discourse use my platform's autentication system?
Automatic addition of users to group based on email domain
Allowing people to login using accounts from other websites
Seeking Slack Login / SSO for Discourse
Smooth J/K navigation when using keyboard
SSO to Joomla site
Discourse Connect on Local instance is not working
Implementing SSO for dev environment and troubleshoot
Login with FB, google and apple only
SSO provider implementation - Admin, moderator and groups ignored?
How to divide my community into 2 parts
Using Discourse to add a forum feature to our current application?
Shared cookie SSO: Notifying frontend
User auth with website at root and Discourse in subfolder
Can I authenticate to Drupal via Discourse?
Difficulty of Tiered-access forum
Any way to not require email verification with WP as the SSO Provider?
How to enable sso on discourse?
How to auto-login user in application web view
[PAID] automatically change user email
Create apikey for user programmatically as admin
Bug when visiting same thread url
Open source will support customized provider SSO
Is there a way to get all emails of users with the API?
How can generate _forum_session and _t for an user through code/api call or without login to browser?
Show/hide forums based on the domain? (Shared forum via CNAME)
Integrate with DjangoRest and Vue.js
Connect Discourse Auth with my Django user DB?
Disable account confirm emails when creating users via API
Transforming usernames with SSO
Automatically provision accounts with external SSO provider? (skip Create New Account prompt)
Error ArgumentError in DiscourseSsoController#sso, wrong number of arguments (given 1, expected 0)
Embed variables in footer
Need help to setup SSO without emails
Programmatically log users out of discourse
How do I remove people from putting names? I have an API system I want in there
How to detect Discourse user on Ghost Blog?
Problem in sso redirection for compose a new pre-filled topic via URL
How to make default avatars and make sure nobody changes there avatar I want to set them an avatar with my API system
How might we better structure #howto?
Is Roblox Login Possible?
Discourse login with whmcs users
2.7.0.beta4: DiscourseConnect, Topic Timer UI revamp, Login Modal UI revamp, and more
Connecting Discourse invites to Marketo emails
Auto assign member to the certain group
Connecting to an external source of avatars?
Changing avatar_url while sso_overrides_avatar is set?
SSO - User Roles or ACLs to differentiate access levels
Disabling email verification
SSO Isnt working for me
Could Discourse offer a StackExchange-like SSO/Federated login service?
Mandatory username & avatar generation - How can we do this?
Intergrading discoures in to a application
Configure single sign-on (SSO) with WP Discourse and DiscourseConnect
How to connect to an external database running on localhost
Automate User Creation
Login Help - Correct way to login
What happens to my current users after configuring SSO?
SSO groups without completely overriding
JumpCloud LDAP/SSO
Usernames getting modified – numeral “1” being added
Is "partial" SSO possible?
Send an invite to a user but complete their profile programmatically
Magento 2 as SSO Provider?
Discourse SSO Provider doesn't redirect to return_sso_url as user logs in with custom SSO
Force password change after login
Would Discourse meet all of these niche needs to be a video game community forum?
OpenID Connect and SSO
Does `sso overrides groups` work with Oauth2?
Add user to group after purchase
Shibboleth SSO with Discourse
Using discourse forum in a native app (log-in, languages)
Discourse Connect: How implementing Discourse login with an existing database?
Sync group membership with external list of email addresses
Can I use my own Login page instead of discourse's Default login dialog box?
Modify the URL of 'create your account' button to an external site
How to add a custom url text link on the login page
Can discourse delete archived posts automatically and accept registration without email?
SSO is forcibly creating the user as an admin
Onboarding 15k Trial Users/Year: Need Help Streamlining the Process
Is DiscourseConnect available for self-hosted?
How to Disable Required SSO Email Activation
User avatar selection through API no longer working
Wordpress plugin not redirect to discourse login automatically
Discourse login by cookie token
Custom field in discourseconnect
Logging users in through c++ desktop application
Invite only by email from database
Is it possible to autologin discourse via iframe?
Login w/ Discourse w/o SSO?
Discourse Hosting Limits?
DiscourseConnect always returns "Nonce is incorrect, ..."
Has anyone succeeded in using discourse as sso provider for nextcloud? Share recipe?
SSO in C# .NET App
Intergrate Discourse with keycloak
Allow my application users to login to discourse
Feature: create default user name from email's user portion when using Google OAuth2/SSO
SSO login appears to have stopped working
Is there a way to use both local login and discourseConnect?
Changing email addresses not working as an Admin
Populating email field on login page
Problem on SSO Login
SSO Broken - The requested URL or resource could not be found
Adding Discourse to existing Ruby on Rails site
Can I use DiscourseConnect along with Discourse Native Registration?
SSO Login with Discourse
Synchronize SSO login state between Discourse and provider
Connection and discourse account creation without going on discourse
Migrate an IPB 3.1 forum to Discourse
Disable DiscourseConnect
How to use Discourse Connect (SSO) to update avatar, username, name?
Label Sets
Unable to setup discourse in my windows 10
Embed Discourse comments on another website via Javascript
How admin user re-logins after using discourse connect sso and custom domain
How to "intercept" first time SSO usages to let users confirm the SSO action and set a username?
How to create a login on my front-end application to a specific Discourse site?
Use Discourse as an identity provider (SSO, DiscourseConnect)
Connect discourse with magento?
Users allowed to see only some categories
Admin status repeatedly revoked
Plugin to integrate Shopify accounts with Discourse
How to do single sign-on with forum program?
Simple login by email via deep links containing a username
How to set language for SSO users
Want to set internal forum on our reactjs member's platform
New instructions for SSO setup? "enable discourse connect" setting is missing
Add a new user via API
Configure GitHub login for Discourse
Use SSO to auto create Discourse login/password after signed up in my SaaS
How can I change the registration URL?
How do I go about making a very customized theme?
Is it possible to have an automatically updating link to a user's profile picture? Such as by giving each user one "slot" for an avatar?
SSO broken after rebuild with stable v3.3.3
Using Discourse Connect with a mobile app
Missing anchor links in certain TOC topics?
Integration into custom auth system where emails are not unique?
WP-Discourse not connected and admin email not recognized
How to disable SMTP during installation?
Auto Login to my Discourse site / subdomain
How to Disable activation_reminder email sending?
Communities using discourse SSO for their in-app community experience
Auth via Discourse Forum
🧩 How to Build an Android App User Community with Discourse? [HeyApks Project]
Postgres doesn't seem to be running when running Discourse locally using Docker
Discourse sso login redirect to localhost:3000, not 4200 (running via docker)
Cross-Discourse Quoting
Is it Possible to Send Encrypted Email and Password in the Authentication Flow?
Nutzung von Nextcloud aus Discourse heraus
Inherited forum with old Discourse Connect Config and Looking for Some Guidance
Merging user accounts
Understanding PII storage in Discourse
REQUEST: Highly Effective Age Assurance (OneID Phone No. Age Verification) Integration
Auto-sign-in with the OpenId Connect Plugin and AWS Cognito
How can I configure Single Sign On for our App to the Discourse Community Forum
Auto-assign random, anonymous usernames
Extending header buttons
Login to Discourse with custom Oauth2 provider
Can I log into multiple instances of discourse simultaneously?
Upgraded last night and login button no longer works
SSO with Roles translating to Groups
Redirect login possible?
How to disable SSO via SSH
Connect Multiple WP Sites To 1 Discourse Installation?
What is the procedure to obtain CAS between my website and my discourse instance?
Problem logging in using SSO plugin
PAID: Create Open Source SSO plugin to auth with Wild Apricot
Trouble connecting drupal and discourse
About the idea: IDENTITY = EMAIL
Consequences of not validating email addresses
SSO and Restricted Groups
Questions about Discourse on Digital Ocean
Require users to join at least one group at sign-up
Use the same user database and login credentials in multiple discourse instances
How to connect my (existing) User Database?
User group sync with drupal
Options with SSO with another custom application
Issues in Integrating SSO in Discourse
How to implement Discourse with an already built Rails project
Updating SSO documentation
Configuring SSO to Work With SocialEngine
Discourse view file update does not reflect in browser
Trying to set up SSO
Discourse doesn't re-verify an address changed by SSO
SSO and Discourse Consulting
Changing the unique key to identify users
Setting the user title(group?) based on the information that is coming from the sso payload
Advice needed for tailoring Discourse to my organisation
Primary and Discourse Site Integrations
Automatic Table of Contents generation
Questions Regarding Account Authentication Methods
Redirect all users who click on domain.com/signup to a different page
Poll Result Breakdown
Cant update email via API - invalid_access error
Disabling all emails except those registration related?
Can't get avatar overrides to work over SSO
Conflicting email addresses, giving admins more power to resolve issues
Which Discourse hosting tier should I choose?
New users via API if allow new unchecked
How to change login settings without being logged in?
Data explorer query to list the longest "estimated read time" topics?
Create user in discourse by redirecting from another site
HMAC-256 example on Official SSO page
Add links to meta.discourse.org instructions inside admin
How to configure the SSO Authorization URL via config (without using the admin panel)
TeamAndro exploring a migration from phpBB
DiscourseConnect payload hash encoding mismatch
Disabling SSO in development environment
Hello, It’s hard for me to find anywhere, but which protocol does this use? Assume oauth2? The parameters don’t seem to match, and i get an error with the provider that it seems to be accepting an sso= parameter? Help!
thanks
DiscourseConnect is Discourse’s implementation of SSO. It doesn’t use a standard protocol.
If you don’t mind looking at PHP code, there’s an example implementation here: wp-discourse/lib/sso-provider/discourse-sso.php at main · discourse/wp-discourse · GitHub.
Yeah, that’s not going to work. If you have an OAuth2 provider that you’d like to use for authenticating users, have a look at the Discourse OAuth2 Basic plugin.
Thanks @simon. is the PHP code a provider as well, and not consumer? Also saw an OIDC provider as well that may work and also a “middle-man” provider in the plugins area.
If the SSO provider is non-standard, then who/what is it intended for if it doesnt play nice with others?
Thanks again!
The code that I linked to is for using WordPress as the authentication provider for Discourse.
The WordPress plugin also allows WordPress to be used as a DiscourseConnect client: wp-discourse/lib/sso-client at main · discourse/wp-discourse · GitHub.
I’m not sure what the motivation was for adding a custom SSO implementation to Discourse. I’m guessing there was a business case for it.
One benefit it provides is that it allows an external site to be tightly integrated with Discourse. For example, all the user attributes listed here can be synced with Discourse during the auth process: discourse/lib/discourse_connect_base.rb at 7b89fdead98606d4f47ceb0a1d240d0f6e5f589e · discourse/discourse · GitHub.
It also allows sites that aren’t configured to be OAuth2 or OpenID Connect providers to be used for authenticating users on Discourse.
The downside is that it requires adding some custom code to the auth provider site.
Hi, I’m curious what the issues are with not verifying email addresses on an external site that provides SSO. Is it just that it enables automated spamming? Or are there other considerations? Why is it not recommended that Discourse handles email verification if the external site does not?
Thanks for any additional insight.
The worst case scenario I’m aware of requires these conditions:
  • email addresses are not verified on the external site
  • require_activation=true is not set in the SSO payload
  • there are existing accounts on the Discourse site that do not have a SingleSignOnRecord associated with them (the account owner has never logged into Discourse with SSO)
For that case, someone could signup on the external site using the email address of a Discourse user who has never signed in with SSO. This would allow the unverified account from the external site to take over the Discourse account that uses the same email address. This would be especially concerning if it was an admin account on Discourse.
It is recommended that Discourse handles email verification if the external site isn’t handling it:
There are a couple of reasons that it’s better to handle email verification on the external site though:
  • forcing users to receive the confirmation email from Discourse adds some friction when users first attempt to login to Discourse. (Realistically, that friction has to happen somewhere though - either on the Discourse end or on the external site’s end.)
  • Discourse won’t match existing Discourse accounts to external logins based on the email address if require_activation is set to true in the SSO payload. This is an issue if you enable DiscourseConnect after some accounts have been created on Discourse by registering with a username/password. It’s also an issue if for any reason you ever need to delete SingleSignOnRecord entries on Discourse. Discourse won’t automatically create new SingleSignOnRecord entries when users attempt to log back into Discourse.
Thanks, @simon - that’s very helpful!
Hello, I have a question about the groups field in the SSO payload.
Will automated groups (like admins, moderators and the trust levels) also be overwritten? Or will they be retained?
Nope! Assuming the description of that setting is right, it’ll only affect manual groups.
You know what.. I didn’t see the word “manual” in the description. Sounds promising for my use case, I’ll give it a try and report back.
When I read this I thought I was supposed to generate the signature directly from the base64-encoded payload. I didn’t realise you need to generate it from the UTF-8 bytes. Could this be clarified?
I’ve been playing with DiscourseConnect - the documentation is great, thanks.
However i’ve hit a few roadbumps i’m hoping for some help/clarification on.
We are wanting users to be able to login to Wordpress using their Discourse login (that is working fine :slight_smile: ) - however.
  • Is it possible to create a Wordpress User via Discourse Signup (when a user creates a Discourse user account, it automatically creates a wordpress account/profile for them so they can log into wordpress)
  • Is it possible to sync Workpress User Groups and Discourse Groups.
    If a user has both a Wordpress and Discourse user account, DiscourseConnect is able to join them - but doesn’t give the wordpress account the User Groups of the Discourse Groups of the same name, and vis versa (and what about if groups don’t have the same name - how can i tell DiscourseConnect to give the User Group ‘Testing Group’ when the user has the Discourse Group ‘Group for Testing Things’?
What am i missing?
I don’t know the answer, but…
Be cautious with that. It is somewhere unlegal and quite widely counted bad practise (outside site owners, of course :smirking_face:) because that would happen without user’s consent and knowing, and at same time would data moved to somewhere else.
Sure, that is somewhat on gray area and basically, for example, Google is doing that.
But… why? Limit login only to Discourse SSO on Wordpress side and redirect users to Discourse for account creation and that’s it. But AFAIK you can’t sync user accounts automatically out of the box. And why should you, because with SSO it happens when a user needs it.
In our scenario (as a membership organisation)
  • Wordpress is used to manage subscriptions, purchase items on the wordpress store, and we use User Groups to manage what a member can do in the organisation
  • Discourse is our forum/online-community and we use Groups to control what areas of Discourse a user has access to)
Currently a new member needs to setup a Wordpress Account (and setup thier subscription etc.) and also setup a Discourse account, and User Group-Discourse Groups are manually managed/synced.
I’m trying to find a solution where a new user does setup once to create both accounts, and User Group-Discourse Groups are synced automatically - i’m sure i can figure out the Group sync with apis etc. It’s the multi user account setup set i’m trying to resolve/prevent
It sounds like what you are doing is using Discourse as the SSO provider for WordPress. That approach is outlined here: Use Discourse as an identity provider (SSO, DiscourseConnect). The Discourse WordPress plugin has options for either using WordPress as the SSO provider for Discourse, or for using Discourse as an identity provider for WordPress. Using the same name for both approaches leads to some confusion.
I’d be tempted to use WordPress as the identity provider for this case. With that approach, users will create accounts on your WordPress site and then login to Discourse with their WordPress credentials. One thing to be aware of with this approach is that it means that users will only be able to log into Discourse through WordPress, it won’t be possible to create a Discourse account without already having a WordPress account. I think that’s the appropriate setup when integrating Discourse with a WordPress membership site.
When WordPress is used as the identity provider for Discourse, there are a couple of utility functions that are useful for setting user’s Discourse group memberships based on their activity on WordPress. Those functions are outlined here: Manage group membership in Discourse with WP Discourse SSO.
Going back to your original question:
It’s been a while since I looked at the WordPress plugin’s DiscourseConnect Client code, but I think what you are asking for is more or less the way that code is expected to work. If a user has a Discourse account, they just need to click the “Login through Discourse” link on WordPress and an account will be created for them.
This would be technically possible when using WordPress as the DiscourseConnect Client, but unless something has changed, you won’t be able to use the add_user_to_discourse_group and remove_user_from_discourse_group methods that are outlined in the documentation I linked to. You’d need to so something like setup a Discourse Webhook that was triggered when a user was added to a Discourse group, then add some code on WordPress to process that webhook. To sync groups from WordPress to Discourse, you’d need to make an API call to Discourse to update a user’s groups when there was a change on WordPress. So something that would be fairly easy to accomplish if you use Wordpress as the DiscourseConnect provider might be somewhat complicated if you use WordPress as the DiscourseConnect client.
Except if custom login is used, as usually is the situation with WooCommerce/memberships/LLM showing that button and forcing using only Discourse SSO as a provider isn’t happening out of the box and needs some custom work.
There are a couple of possible problems, one related to caching and another related to login redirects that are added by some plugins. Anyone running into those issues should ask about them in the Support > WordPress category. They’re usually easily solved.
I totally forgot to report back: Indeed it works exactly as described, only manual groups are affected.
Hi @simon,
I think I really need some help on the 404 response from my POC explore of this SSO feature. I 've been working on this issue for a whole day, but still can’t figure out the problem is. I was able to
  1. enabled discourse_connect
  2. set the discourse_connect_url to https:/ /localhost:4200/login
  3. discourse-connect secret: 20’s (1) 1111111111111111111 to keep it simple
then in my login page of my angular app I sent this request by following code:
but I got the response 404 not found.
for my understanding, while sending POST request to admin/users/sync_sso endpoint, if the user was not exist in discourse then it should create a new user based on the user_id and email, then the returned result should be a user object shoudn’t be an empty object with status code 404.
I also checked the log it didn’t provide any related information for this failed response.
thanks ahead!
