Why default to converting PNG to JPG?
סיכום מבוסס בינה מלאכותית
The discussion revolves around the default behavior of Discourse converting uploaded PNG images to JPG format. mbauman expresses disappointment with this feature, highlighting the loss of transparency and text quality in the conversion process. codinghorror acknowledges the configurability of this setting but emphasizes the space savings of JPG conversion. JimPas and mbauman discuss the settings to adjust this behavior, with mbauman advocating for a change in the default to preserve PNG quality, especially for screenshots. Falco and codinghorror discuss the trade-offs between cost savings and image quality, with codinghorror dismissing the idea of changing the default. notriddle suggests using optipng for optimization before converting to JPG, but codinghorror points out performance issues with large images. marianord proposes using WebP format for better quality and smaller size, but Falco notes browser compatibility issues. Remah supports the current default, citing the average administrator’s priorities. Falco mentions future plans for user-side image optimization. mbauman suggests disabling JPG conversion for transparent PNGs, with Falco confirming its detectability. riking advises on screenshot settings to prevent conversion. simon and codinghorror discuss the need for clearer documentation on the settings’ effects. CodesInChaos reports issues with the quality setting not working as expected, prompting Falco to request further details.
I fully understand (and appreciate!) that this is exposed as a site setting for administrators to toggle, but I find this “feature” to be very misguided in the first place.
There are two hugely important features of PNGs: its lossless (and readable!) representation of text and support for transparency. Both of these are important reasons to use PNGs. As a user of a discourse site, I uploaded an image (of text with transparency) to my board and was highly disappointed to see it auto-convert to a JPG. No matter, I’ll just host it elsewhere. Well, that worked great until @system came along and downloaded and converted my image and edited my post out from underneath me, breaking the transparency and making it look worse. Thankfully I’m also an admin and was able to search the web to find one of the threads below that guided me to the png to jpg quality setting that I could change.
At a minimum, it seems prudent to turn off this feature if there is transparency in the GIF.
Do folks actually like this feature on their boards? It’s been brought up twice before, both times with folks confused/frustrated that PNGs were getting converted. It seems worthwhile to reconsider this default.
3 לייקים
This means the image was much smaller as a JPG. I believe there are site settings to tweak this threshold. Have a look, search through your site settings.
4 לייקים
In Settings/Files, scroll down to the 3rd item from the bottom. Uncheck Strip image metadata. Just above that is the png to jpg quality. Adjust setting as necessary.
5 לייקים
Yes, I totally get that this is configurable (I’ve already disabled it on my site) and I understand the motivation. I still think that the feature is misguided in the first place and that it’d make sense to change the default.
Here’s an example — PNGs are the default file format for screenshots and rightfully so. If I just take a screenshot of this window and try to upload it, it gets converted to a JPG.
The original file was 361KB, your compressed JPG is 218KB. Sure, it’s smaller, but we’ve also lost the transparency — it looks awful for folks using a dark theme — and there’s artifacting around the text.
If, instead, I use optipng locally to optimize the PNG, I end up with a file that has transparency and sharp text that’s only 219KB. This will now remain a PNG when I upload it:
Converting PNG to JPG is a very lossy conversion. It’s one thing to do this on upload; it’s yet another to edit posts to do it automatically to external images after posting. There are other ways to save on bandwidth and storage, including PNG optimizers and even resizing (with the click-to-view-full-size feature it seems sensible to embed the smaller image in the post and only show the full-size image on click).
4 לייקים
It’s a balancing act.
There are a bunch of topics of people trying to host their forums for as cheap as possible and complaining that images are taking too much space. This type of admin doesn’t care about quality of the images, all they want is to cut every corner and reduce costs.
On the other side of the spectrum you have people who are really invested on their communities and will leverage object storage and be able to provide a good quality with reasonable costs.
The discussion here is about defaults right? Or maybe we could try to measure the jpg size against the png post optimization? If I remember correctly the png optimization can be quite expensive…
9 לייקים
You will not win this debate, my friend. Best to stop now. The site setting exists so you can tweak to taste.
2 לייקים
Eliminating this feature isn’t happening. But this post seems interesting:
What would it take to have Discourse try using optipng first, and then use the resulting “optimized” size to determine whether it wants to go to JPG? Or would that be too slow?
4 לייקים
Try running optipng on a 6000x6000 png and see what happens. We already do a form of this but it falls off an algorithmic cliff quickly. And real badly.
5 לייקים
I’m not at all after eliminating the feature — sorry if I was overly bombastic in calling it a misfeature. It’s about the defaults. I just found the behavior surprising and unhelpful (especially after I had worked around it with an external link and had it automatically edited back). So I came here because I thought it’d be beneficial to others if the default were different… but as with all default choices subjective preferences on the tradeoffs rapidly come into play.
Thanks for the well-reasoned post, Rafael. I appreciate the discussion — as I initially said, I was earnestly asking if folks liked this feature.
3 לייקים
I think it would be interesting to change from .jpg to .webp, it’s lossless but still smaller than .png.
My understanding is that that’s the new web standard to use for media, especially for images were transparency is desirable.
3 לייקים
We can’t as older / incompatible browsers (IE and Safari) don’t support.
11 לייקים
I’m hating Safari right now, but thanks for the quick reply. I hope they get the support soon.
Specially as IE11 will be less important as the time continues to pass.
2 לייקים
It’s worth saying that the current default to optimized JPEG is not a misguided decision! I love PNG :smile_cat: and abhor JPG :grumpycat: for graphics but for this issue I totally support the current regime (both meanings: authority and system).
The Discourse team have made a realistic assessment of what will make Discourse successful out of the box:
  • The average site owner-administrator will not be looking for image quality options. They don’t have image quality as a goal and they will not be consider the default image file format to be an issue. So defaulting to optimised JPG produces the least grief and the greatest benefit for the most people.
  • PNG-ophiles like myself are always looking for site options to preserve image quality and information. Likewise photo- and image-driven sites will have image quality as a central decision.
A practical consequence of the current approach is likely to be a seamless transition to lossy WebP. Then the issue of lossy vs lossless WebP will probably arise in further topics here. :laughing:
If you’ve ever optimized a lot of PNG files then you’d know that the likely outcome is unattractive. PNG optimizers take forever compared to JPG optimizers. It also takes more smarts to create PNG images that can be most effectively optimized, e.g. https://medium.com/@duhroach/reducing-png-file-size-8473480d0476 or How To Optimize PNG — Smashing Magazine
5 לייקים
One thing, that we will eventually have is the ability for users to optimize their image before uploading.
By spawning the compression work into another thread (using web workers) and using the same algorithms we use on the server (using WASM) the user experience isn’t bad.
15 לייקים
What would you think about disabling this behavior if the PNG has transparency? That’s the most visible loss in the conversion process.
4 לייקים
Looks like it’s detectable using
5 לייקים
If you tell your screenshot program to stop inserting drop shadows, Discourse will probably stop converting it because it’ll actually be text and solid colors.
5 לייקים
I was looking into this today for a site that wants all uploaded PNG files to be kept in the PNG format. What I was finding is that after setting png to jpg quality to 100, Discourse will still convert large PNGs to JPGs unless the recompress original jpg quality setting is also set to 100. Is this the expected behaviour? If so, the description for the recompress original jpg quality setting needs to be updated to describe how it affects PNG uploads.
8 לייקים
Hmm, I’m not sure, @sam did you want to make that call next week? We should at least update copy.
3 לייקים
I am not sure … deferring to @zogstrip here…
4 לייקים
