התקן Discourse בפרודקשן עם ההוראות הרשמיות שתומכות בכך
Our install guide lives in GitHub alongside Discourse code at discourse/docs/INSTALL-cloud.md at main · discourse/discourse · GitHub.
52 לייקים
How to install discourse in Hosting?
Deploy in heroku
Unable to connect to PostgreSQL despite configuration
Sidekiq not running. Sidekiq heartbeat test failed, restarting
Setup wont send me the email
Install Discourse Docker on Ubuntu 11
How much RAM is required for Discourse?
Why the icon address is localhost when I use an ip as hostname
Not getting activation email
How to install Discourse locally?
Discourse Forum not working with Digital Ocean
How do you scale discourse horizontally?
Install Discourse on Bluehost Sub Domain
Please help me with Discourse installation i am a super newbie
Category Icon Image Issue
Very frequent 500 errors after server reinstallation
Discourse update plugin without docker
Discourse Swap Memory (1GB Warning)
Synology docker installs
Server not listening on IPv6
How do I run Discourse on a folder on my site running PHP on LAMP on DigitalOcean
How much RAM is needed to host discourse along with other services?
Error connecting to Redis on localhost:6379 (Errno::EADDRNOTAVAIL)
Improved Bookmarks with Reminders
Fresh Install gives "Too many redirects" error
Droplet install not working
Docker Maximum Supported Version Number?
Few questions about the software (new comer)
Using Postfix with Discourse
Install going well but now blank white page
How to upgrade if `/var/discourse` has only `shared` and is not git repo
Backup restored and images are broken
Installing Discourse on DigitalOcean - got stuck
PWA (twa, offline)
Access Denied error message when trying to upload images
Application not opening after admin:create
Aws deployed discourse is fetching assets from database url
Can I install discourse on this unmanaged vps? If yes how to?
How to access container app?
Automatic session management with OAuth SSO
WooCommerce Discourse Website newbie help
Assets precompile require redis
Discourse Voting missing table on postgresql
Discourse not working in domain
Uploading Files to Discourse
"Couldn't find IP Address for (my discourse forum link)"
Image upload size/resize question
Fresh Discourse installation ERR_CONNECTION_TIMED_OUT
Docker image update: Redis 6 and 25% smaller image size
Redis Unix Socket, Ubuntu Install
How to install Discourse in WWW
What is the best way to install Discourse Forum on a Proxmox VM and expose it on the internet
Discourse on Debian 10
404 Error after installaton
Votes don't Merge when we combine posts
Install Discourse with plesk on a virtual server
Discourse on Google Cloud port issue?
Nginx to server static files?
Nginx upstream timed out (110: Connection timed out)
Help 503 service unavailable error CyberPanel
DigtalOcean one-click install doesn't finish
Unable to login
Plugins don't show up
Migrating site from Personal vmware server to VPS
Custom discourse with limited features
Error upon installing - failed to register layer: Error processing tar file(exit status 1):
502 Bad Gateway and Discourse version NOT FOUND
How to Install Discourse on CyberPanel?
How do I run Discourse on Pterodactyl Panel?
How do I extract raw data from my discourse community site?
Rebuilding failed 'bundle exec rake db:migrate' failed with return #<Process::Status: pid 4979 exit 1>
Thinking of trying self-hosted and have some questions
Install Discourse on a residential internet with Cloudflare Tunnel
Setup Multisite Configuration with Let's Encrypt and no Reverse Proxy
Discourse-app container starts then silently stops
Install Discourse on macOS for development
Seeking help for discourse installation
Rebuild fails, running 2.8.9
Install Discourse on Ubuntu or Debian for Development
I can't display my policy
Can't rebuild due to failed postgres 12 upgrade
No documentation for Google login for fresh installations
:cn: Installing the Discourse development environment on Ubuntu 在 Ubuntu 上安装 Discourse 开发环境
Vagrantfile in discourse_docker repo - for production?
"No such file or directory" when installing Discourse
Discourse-doctor nagging about swap creation
New to Discourse? Start here!
Site setting is different Every time on Ubuntu development installation
Discourse not opening
How do I create Discourse forum with docker and VPS?
Need help installing Discourse
It Is Necessary to select Discourse?
Cannot open discourse after installation
Error starting userland proxy: listen tcp4 0.0.0.0:443: bind: address already in use
Cannot rebake after setting up CDN
PEM_read_bio_X509_AUX() failed (SSL: error:0909006C:PEM routines:get_name:no start line:Expecting: TRUSTED CERTIFICATE)
2.7.0.beta2 upgrade failed
No information requested on install
Installation Help on namehero.com
Install and hosted related issues
Stop and remove docker container by mistake
Connection timed out when running SSH connection command
Assets:precompile is giving error
Questions about Discourse Forum and Digital Ocean? Hosting?
Some devices can't connect to server
Port issue - Please help
Bootsnap::CompileCache::PermissionError
Let's encrypt SSL certificate expired: `urn:ietf:params:acme:error:rateLimited`
My discourse speed is very slow
Imgur images broken
