This guide has been tested against a fresh install of Fedora 31 and 33, but may work on older versions that also use dnf as the package management tool. This is not an official guide but may be useful for other developers using Fedora. This is largely based on the Ubuntu development guide, with changes for the different packages for dnf. The assumption is that you do not have any of the packages installed already, although most will be skipped by the tooling if it is already installed.
If you’re looking to install Discourse for a production environment, prefer the docker install instructions on github.
Install required system and development packages
sudo dnf update
sudo dnf install -y "@development-tools" git rpm-build zlib-devel ruby-devel readline-devel libpq-devel ImageMagick vips-tools sqlite sqlite-devel nodejs npm curl gcc g++ bzip2 openssl-devel libyaml-devel libffi-devel zlib-devel gdbm-devel ncurses-devel optipng pngquant jhead jpegoptim gifsicle oxipng
Install required npm packages
sudo npm install -g svgo pnpm
Install and setup postgres
sudo dnf install postgresql-server postgresql-contrib
sudo postgresql-setup --initdb --unit postgresql
sudo systemctl enable postgresql
sudo systemctl start postgresql
sudo -u postgres -i createuser -s $USER
Install and setup redis
sudo dnf install redis
sudo systemctl enable redis
sudo systemctl start redis
Installing rbenv, ruby-build, and ruby
git clone https://github.com/rbenv/rbenv.git ~/.rbenv
cd ~/.rbenv && src/configure && make -C src
~/.rbenv/bin/rbenv init
printf 'export PATH="$HOME/.rbenv/bin:$PATH"\n' >> ~/.bashrc
printf 'eval "$(rbenv init - --no-rehash)"\n' >> ~/.bashrc
source ~/.bashrc
git clone https://github.com/rbenv/ruby-build.git "$(rbenv root)"/plugins/ruby-build
# confirm the install is correct
curl -fsSL https://github.com/rbenv/rbenv-installer/raw/main/bin/rbenv-doctor | bash
rbenv install 2.7.1
rbenv global 2.7.1
rbenv rehash
Install Ruby dependencies
gem update --system
gem install bundler mailcatcher rails
Clone Discourse code
git clone https://github.com/discourse/discourse.git ~/discourse
cd ~/discourse
Install Discourse dependencies
bundle install
pnpm install
Create the required databases and load the schema
bundle exec rake db:create db:migrate
RAILS_ENV=test bundle exec rake db:create db:migrate
Test installation by running the tests
bundle exec rake autospec
Run the application
bundle exec rails server
You should now be able to see the Discourse setup page at http://localhost:3000.
For further setup, see the existing official install guides.
This document is version controlled - suggest changes on github.
