התקן את Discourse לפיתוח על Fedora Linux
This guide has been tested against a fresh install of Fedora 31 and 33, but may work on older versions that also use dnf as the package management tool. This is not an official guide but may be useful for other developers using Fedora. This is largely based on the Ubuntu development guide, with changes for the different packages for dnf. The assumption is that you do not have any of the packages installed already, although most will be skipped by the tooling if it is already installed.
If you’re looking to install Discourse for a production environment, prefer the docker install instructions on github.
Install required system and development packages
sudo dnf update
sudo dnf install -y "@development-tools" git rpm-build zlib-devel ruby-devel readline-devel libpq-devel ImageMagick sqlite sqlite-devel nodejs npm curl gcc g++ bzip2 openssl-devel libyaml-devel libffi-devel zlib-devel gdbm-devel ncurses-devel optipng pngquant jhead jpegoptim gifsicle oxipng
Install required npm packages
sudo npm install -g svgo pnpm
Install and setup postgres
sudo dnf install postgresql-server postgresql-contrib
sudo postgresql-setup --initdb --unit postgresql
sudo systemctl enable postgresql
sudo systemctl start postgresql
sudo -u postgres -i createuser -s $USER
Install and setup redis
sudo dnf install redis
sudo systemctl enable redis
sudo systemctl start redis
Installing rbenv, ruby-build, and ruby
git clone https://github.com/rbenv/rbenv.git ~/.rbenv
cd ~/.rbenv && src/configure && make -C src
~/.rbenv/bin/rbenv init
printf 'export PATH="$HOME/.rbenv/bin:$PATH"\n' >> ~/.bashrc
printf 'eval "$(rbenv init - --no-rehash)"\n' >> ~/.bashrc
source ~/.bashrc
git clone https://github.com/rbenv/ruby-build.git "$(rbenv root)"/plugins/ruby-build
# confirm the install is correct
curl -fsSL https://github.com/rbenv/rbenv-installer/raw/main/bin/rbenv-doctor | bash
rbenv install 2.7.1
rbenv global 2.7.1
rbenv rehash
Install Ruby dependencies
gem update --system
gem install bundler mailcatcher rails
Clone Discourse code
git clone https://github.com/discourse/discourse.git ~/discourse
cd ~/discourse
Install Discourse dependencies
bundle install
pnpm install
Create the required databases and load the schema
bundle exec rake db:create db:migrate
RAILS_ENV=test bundle exec rake db:create db:migrate
Test installation by running the tests
bundle exec rake autospec
Run the application
bundle exec rails server
You should now be able to see the Discourse setup page at http://localhost:3000.
For further setup, see the existing official install guides.
This document is version controlled - suggest changes on github.
27 לייקים
In Installing rbenv, ruby-build, and ruby, the url to the rbenv-doctor script is not working anymore (apparently the branch has been rename from master to main), the correct command is now:
2 לייקים
Thanks for the info @nicolas-jaussaud, I’ve updated the OP.
FWIW I now prefer to use chruby and ruby-install over rbenv.
2 לייקים
I ran into an issue trying to run bundle install as Fedora now has by default disabled file transport.
The error happens when trying to install the sprockets gem and ends with the message:
transport 'file' not allowed
I don’t know what’s the proper way to do this, but you can temporarily allow the unsafe transport:
git config --global protocol.file.allow always
# run the discourse setup here
git config --global protocol.file.allow never
After that I ran into an error like this when running db:migrate:
At /home/hhyyrylainen/Projects/discourse/lib/site_setting_extension.rb:199:in `public_send`
Deprecation notice: `SiteSetting.enable_personal_messages` has been deprecated. Please use `SiteSetting.personal_message_enabled_groups` instead. (removal in Discourse 3.0)
#<Thread:0x00007f94c3342600 /home/hhyyrylainen/Projects/discourse/lib/scheduler/defer.rb:83 run> terminated with exception (report_on_exception is true):
/home/hhyyrylainen/.gem/ruby/3.2.0/gems/activerecord-7.0.4.3/lib/active_record/connection_handling.rb:309:in `connection_pool': ActiveRecord::ConnectionNotEstablished (ActiveRecord::ConnectionNotEstablished)
	from /home/hhyyrylainen/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rails_multisite-4.0.1/lib/rails_multisite/connection_management/rails_61_compat.rb:8:in `current'
	from /home/hhyyrylainen/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rails_multisite-4.0.1/lib/rails_multisite/connection_management.rb:115:in `current_db_hostnames'
	from /home/hhyyrylainen/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rails_multisite-4.0.1/lib/rails_multisite/connection_management.rb:111:in `current_hostname'
	from /home/hhyyrylainen/Projects/discourse/lib/discourse.rb:232:in `handle_job_exception'
	from /home/hhyyrylainen/Projects/discourse/lib/scheduler/defer.rb:114:in `rescue in do_work'
	from /home/hhyyrylainen/Projects/discourse/lib/scheduler/defer.rb:113:in `do_work'
	from /home/hhyyrylainen/Projects/discourse/lib/scheduler/defer.rb:85:in `block (2 levels) in start_thread'
	from /home/hhyyrylainen/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rails_multisite-4.0.1/lib/rails_multisite/connection_management.rb:79:in `with_connection'
	from /home/hhyyrylainen/Projects/discourse/lib/scheduler/defer.rb:96:in `do_work'
It seems it happened after the migration finished, so as I couldn’t figure out how to fix that I ignored it, but luckily my development site seems to be working.
For the test environment I didn’t get the same error but got an error about missing oxipng, which doesn’t seem to be available as a Fedora package.
After that I didn’t run into any more issues, everything still more or less worked fine on Fedora 38. Though, I had previously installed rbenv using some other setup instructions.
Running bundle exec rake autospec I got some test failures (135) but it seems I got a mostly working development setup.
2 לייקים
I got the Dev version going some time ago but the Production version was too difficult for me . .
Just followed this guide to install on Fedora 40 Workstation, had to add oxipng to the distro installs.
sudo dnf install oxipng
3 לייקים
Thanks for letting us know, I’ve updated the documentation in this commit: docs/fedora-setup: include oxipng package (#14) · discourse/discourse-developer-docs@eb51e54 · GitHub.
לייק 1
I am stuck after installation today on Fedora 41 with the following issue when I connect to localhost:3000 and click on register :
“no administrator emails were defined during setup”; the message provides how to add an administrator email.
I’ve failed to successfuly add an admin acount following this procedure because of 2 errors when using ./launcher enter app :
1° First solved error was: no app.yml file is present → I copied the sampleapp.yml from the sample folder to the container folder, then modified to add email adresses, then did the rebuild with /var/discourse/launcher rebuild app
2° Second error is not solved :
Error response from daemon: No such container: app
If I use the rake commands to create an admin it tells me no rakefile found
Can anyone please help?
This install doesn’t use docker, so you can’t enter a container.
Try creating an admin from the Discourse folder with this command:
bin/rails admin:create
לייק 1
Hi Coconut, you are quick to respond and efficient, thanks a lot !
The command returns gem bunder missing, which I installed with `gem install bundler -v 2.6.2’ and then I could successfuly apply your solution !
2 לייקים
Just tried running a local install and ran into issues with pgvector. This is on Fedora 42 and Postgres16. The packaged version of pgvector is 0.6.2 and it seems I need to compile from source to get a more recent one.
Then ran into conflicts trying to build pgvector, which seems to require postgresql-private-devel package that had conflicting requests with libpq-devel.
Resolved it by:
  •  sudo dnf install postgresql-server-devel --allowerasing
  • Build pgvector
  • Check installed version
    sudo -u postgres psql discourse_development -c "SELECT * FROM pg_available_extensions WHERE name = 'vector';"
  •  sudo systemctl restart postgresql
3 לייקים
Soo… is this official? (That line should probably be removed, no?)
Pardon me, but is this version out of date? The most recent version of Ruby listed on rbenv install -l is 4.0.5 IIRC (as is the most recent version on ruby-lang.org)
לייק 1
Running bundle exec rails server, it starts a whole bunch of migrations. It’s been running for about an hour and still not done. My laptop has enough RAM and CPU power for this, is this just because of the sheer amount of migrations needed to be run?
EDIT: 3 hours in and still going strong.
EDIT #2: Into the 4th hour…
EDIT #3: Me being me, I misread the console output for 4 hours and realised now that it’s not actually migrations running :facepalm: … it’s the Sidekiq jobs… and port 3000 actually shows the instance. No cause for alarm!
