S3로의 업로드 마이그레이션 실패
Hello! I’m having a lot of trouble getting my local file uploads to be migrated to S3.
I’ve done the following:
  1. Restored to a new environment
  2. Disabled “enable S3 uploads”
  3. Ran
    rails c
    SiteSetting.migrate_to_new_scheme = true
    Jobs::MigrateUploadScheme.new.execute(nil) #repeatedly until it stops taking a long time
    exit
    rake posts:rebake
    rake uploads:recover
    DISCOURSE_S3_REGION=us-east-1 DISCOURSE_S3_USE_IAM_PROFILE=true  DISCOURSE_S3_BUCKET=<redacted> rake uploads:migrate_to_s3
Basically, I’ve referenced these: How can I migrate files from the old upload scheme (default/XXX) to the new one (default/original/{1,2}X)? - #5 by kansaichris
I feel like I’m really close to getting this to work, but I’m stuck at these errors:
** Invoke uploads:migrate_to_s3 (first_time)
** Invoke environment (first_time)
** Execute environment
** Execute uploads:migrate_to_s3
Migrating uploads to S3 for 'default'...
Some uploads were not migrated to the new scheme. Running the migration, this may take a while...
rake aborted!
FileStore::ToS3MigrationError: Some uploads could not be migrated to the new scheme. You need to fix this manually.
/var/www/discourse/lib/file_store/to_s3_migration.rb:155:in `migrate_to_s3'
/var/www/discourse/lib/file_store/to_s3_migration.rb:65:in `migrate'
/var/www/discourse/lib/tasks/uploads.rake:245:in `migrate_to_s3'
/var/www/discourse/lib/tasks/uploads.rake:224:in `block in migrate_to_s3_all_sites'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rails_multisite-2.5.0/lib/rails_multisite/connection_management.rb:76:in `with_connection'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rails_multisite-2.5.0/lib/rails_multisite/connection_management.rb:86:in `each_connection'
/var/www/discourse/lib/tasks/uploads.rake:222:in `migrate_to_s3_all_sites'
/var/www/discourse/lib/tasks/uploads.rake:218:in `block in <main>'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/task.rb:281:in `block in execute'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/task.rb:281:in `each'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/task.rb:281:in `execute'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/task.rb:219:in `block in invoke_with_call_chain'
/usr/local/lib/ruby/2.6.0/monitor.rb:235:in `mon_synchronize'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/task.rb:199:in `invoke_with_call_chain'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/task.rb:188:in `invoke'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/application.rb:160:in `invoke_task'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/application.rb:116:in `block (2 levels) in top_level'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/application.rb:116:in `each'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/application.rb:116:in `block in top_level'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/application.rb:125:in `run_with_threads'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/application.rb:110:in `top_level'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/application.rb:83:in `block in run'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/application.rb:186:in `standard_exception_handling'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/application.rb:80:in `run'
bin/rake:13:in `<top (required)>'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/cli/exec.rb:63:in `load'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/cli/exec.rb:63:in `kernel_load'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/cli/exec.rb:28:in `run'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/cli.rb:476:in `exec'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/vendor/thor/lib/thor/command.rb:27:in `run'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/vendor/thor/lib/thor/invocation.rb:127:in `invoke_command'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/vendor/thor/lib/thor.rb:399:in `dispatch'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/cli.rb:30:in `dispatch'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/vendor/thor/lib/thor/base.rb:476:in `start'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/cli.rb:24:in `start'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/exe/bundle:46:in `block in <top (required)>'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/friendly_errors.rb:123:in `with_friendly_errors'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/exe/bundle:34:in `<top (required)>'
/usr/local/bin/bundle:23:in `load'
/usr/local/bin/bundle:23:in `<main>'
Tasks: TOP => uploads:migrate_to_s3
Do any of you have any advice on where I should turn next?
Edit: More info here, I seem to still have uploads in the original scheme:
[1] pry(main)> Upload.where("url NOT LIKE '//%' AND url NOT LIKE '/uploads/default/original/_X/%'").exists?
=> true
did you ever get this resolved? I’m also facing this issue
