meghna
(Meghna Jalan)
30 בדצמבר, 2020, 1:16pm
1
What better way to celebrate the New Year’s eve than fireworks!
Here’s a component that adds fireworks on Discourse forum.
The source code is inspired from Eddie’s Pure CSS Fireworks .
Happy New Year 2021!
32 לייקים
Zup
20 במרץ, 2021, 12:09am
would be cool if this triggered for a few seconds every time a badge is earned
14 לייקים
@Don
if a badge is earned your theme FKB PRO
very usefull
לייק 1
Jagster
(Jakke Flemming)
31 בדצמבר, 2023, 3:40pm
5
Doesn’t work on iPhone (at least).
Well, next year then.
You can try this fork @Jagster :
URL: https://github.com/Arkshine/discourse-fireworks
branch: mobile-support-and-settings
Click on Advanced button to provide the branch name here:
Mobile is supported, and I added a bunch of basic settings (particle count/size, firework width/height, and fall distance) for both desktop and mobile.
I will consider making a proper PR (and eventually other settings) on the original repository later!
6 לייקים
Roi
1 בינואר, 2024, 6:41pm
7
Arkshine:
Hm, I tried but I do not see any fireworks and also no settings.
No worries. I should have explained how to install it.
Make sure you click on Advanced and copy/paste the branch name:
Note: This will install another Theme component; you might want to disable the old one for now.
לייק 1
The implementation of mobile support and settings is absolutely superb. It functions perfectly on my mobile device now, with dimensions that are impeccably suited, without any hint of being overwrought.
Roi
1 בינואר, 2024, 8:14pm
10
You did. I did not notice the branch, sorry. Thank you for making this clear. Looks great now, thank you a lot! An official PR would be great.
לייק 1
Kartoon
8 בפברואר, 2024, 6:31am
11
I think this would be better if you could adjust the frequency somehow it’s (imo) fairly obnoxious but still cool
Jagster
(Jakke Flemming)
28 בדצמבר, 2024, 9:46pm
12
One year after last new year
Arkshine’s fork works nicely. But yet original one is desktop-only.
Either the PR in needed or the OP could be edited including information of the fork. Both solutions are good.
2 לייקים
meghna
(Meghna Jalan)
30 בדצמבר, 2024, 4:15am
13
Jakke Flemming:
I created the PR on @Arkshine ’s behalf and merged it. Updating the component should work for mobile as well.
Thanks again, Arkshine.
5 לייקים
Thanks @meghna ! I have completely forgotten.
2 לייקים
@meghna I’ve opened a PR to add an option to use tsParticles’ fireworks:
master ← NateDhaliwal:add-tsparticles-support
merged 01:33PM - 07 Mar 25 UTC
This adds a new setting, `use_tsParticles_fireworks`, to enable tsParticles' fir… eworks instead of CSS fireworks. The fireworks also includes sound. The setting is disabled by default.
4 לייקים
meghna
(Meghna Jalan)
19 בפברואר, 2025, 5:10am
16
Thanks Nate! I’ll take a look.
2 לייקים
meghna
(Meghna Jalan)
7 במרץ, 2025, 1:34pm
17
I’ve merged the PR, thanks for the improvements, Nate!
3 לייקים
Roi
27 בדצמבר, 2025, 12:56pm
19
I just activated the Fireworks component and see the following warning:
[Admin-Hinweis] Theme ‘discourse-fireworks’ enthält Code, der aktualisiert werden muss. (ID:discourse.script-tag-discourse-plugin) (mehr erfahren )
[THEME 62 ‘discourse-fireworks’] DEPRECATION NOTICE: Adding JS code using is deprecated. Move this code to a dedicated JavaScript file. [deprecation id: discourse.script-tag-discourse-plugin] [info: Modernizing inline script tags for templates & JS API ]
Is it possible to get an update? I myself do not understand enough to make a PR.
4 לייקים
Lilly
1 בינואר, 2026, 4:05pm
20
I’ve had a fix and refactor for this for a couple days in my repo, but finally got around to creating a PR to this one. sorry i know it’s already Jan 1st. lol
master ← Lillinator:main
opened 04:03PM - 01 Jan 26 UTC
Refactored and updated the component using Discourse theme skeleton template, an… d updated for gjs compatibility.
not sure about the acceptance tests though
5 לייקים
