נושא אוויר
:discourse2: Summary Air Theme is a clean & modern theme with a handful of theme components included to enhance your forum!
:eyeglasses: Preview Preview on Discourse Theme Creator
:hammer_and_wrench: Repository Link https://github.com/discourse/discourse-air
:open_book: New to Discourse Themes? Beginner’s guide to using Discourse Themes
Install this theme
Features
Light Mode
Dark Mode
Categories Page
This theme includes a couple of components to enhance your forum as well.
  • Clickable Topics
  • Modern Category + Group Boxes
:exclamation: Please read through these tips upon installation, as there are a couple of settings that NEED TO BE ENABLED for this to theme to render properly.
Tips
Dark Light Scheme Toggle
For this to work properly, at least 2 color scheme choices need to be enabled in your https://discourse.jordanvidrine.com/admin/customize/colors area. At least two colors need to have color scheme can be selected by users enabled.
Once this is done, users should be able to choose between two color schemes as their light and dark preferences in their user preferences interface menu.
Welcome Banner
Go to Admin > Welcome banner (/admin/config/welcome-banner) page.
  • in Enabled on themes… dropdown select Air Theme
  • in Location dropdown select Below site header
This theme component requires your categories to use the CATEGORY BOXES WITH SUBCATEGORIES setting in your /admin/site_settings/category/all_results?filter=categories area.
This theme component also allows the forum admin to organize their category page with header titles, and choose which categories appear under each header. To keep things simple, I have only allowed up to 5 headings to be used. If no categories + heading settings are chosen, all categories will render as they do above, this is the default rendering option.
:discourse2: Hosted by us? Themes are available to use on our Standard, Business, and Enterprise plans.
137 לייקים
That is just amazing Jordan! :heart_eyes: I love it!
17 לייקים
It will be helpful if the welcome message can be hide when left locale field empty :+1:
7 לייקים
Oh wow, this looks really nice! Thank you for the share. :slight_smile:
9 לייקים
This theme gives discourse the modern look it deserves. Very well done @jordan.vidrine
13 לייקים
Theme looks amazing. Awesome work :heart_eyes:
5 לייקים
This theme looks so amazing. Hope we can get this category page design as a separate component as well. It is looking way better this way. :heart:
8 לייקים
Thanks it is nice…
First time I install a new theme. I really like this one!!
8 לייקים
Hi @jordan-vidrine regarding the # of views column, what kind of code shall i add in the component to override that column being hidden ?
3 לייקים
I believe this should work:
.full-width .contents .topic-list thead th.posts {
width: 10%;
.full-width .contents .topic-list thead th.activity {
width: 10%;
order: 4;
th.num.views {
width: 10%;
order: 3;
display: block;
.full-width .contents .topic-list tbody tr:not(.topic-list-item-separator) td.posts {
width: 10%;
order: 2;
.topic-list .views {
width: 10%;
order: 3;
.full-width .contents .topic-list tbody tr:not(.topic-list-item-separator) td.age {
width: 10%;
order: 4;
6 לייקים
Refreshingly beautiful. Great work @jordan.vidrine!
4 לייקים
Is there any possibility to change the header text “Welcome to the forum”
4 לייקים
Yes, this can be edited in the Discourse Search Banner component :+1:
3 לייקים
A while back I posted an issue with not seeing the categories on a mobile view (☁️ Discourse Air Theme - #172 by Jerdeman). I messaged a bit with @jordan.vidrine, but we were unable to get to the root of the issue. Hopefully someone else has some ideas.
For the details
Using a clean install of Discourse 2.7.11 on kubernetes with the help of a helm chart from Bitnami, and the latest version of the theme installed and configured as mentioned in the opening post, we do not see any categories on a mobile view and styling is off on the latest page.
What we tried
Besides using a clean install, we attempted to use some older versions of the theme as well. The problem however remained, but we did not exhaustively tried all versions.
We also compared the html on our instance with that of discourse.jordanvidrine.com , and noticed that it is significantly different.
Gut feeling
As we cannot use a ‘beta’ version, my gut feeling tells me this is a compatibility issue between the theme or one of its plugins and Discourse 2.7. I’d love to know if someone has this theme working on 2.7, and if so with which versions of the theme and relevant plugins.
Question
Has somebody got this theme working with 2.7 and/or are there any clues on what we could do to get this working?
2 לייקים
Hi. first, Thank you for this great theme :smile:
I want to change font-family, How can I do that.
I try this :point_down:
  • download this Theme Google Fonts theme component , and change Font setting on SITE SETTING → Not work
  • add @import{web font link ~~~ } code in Desktop.css, mobile.css → Not work
Which file should I modify to modify the font??? :sob:
3 לייקים
I believe you should be able to set a customized font without a component here: admin/site_settings/category/all_results?filter=font
If you want more customization, I believe the google fonts theme component you linked would work. Though, the theme uses theme-settings and not a site setting I believe.
Have you brought this issue up in the topic for that font component?
4 לייקים
Hello everyone, can anyone help me change the sizing and “fixed nature” of the background color on mobile?
The css for mobile is transparent on my end. And I just need a little guidance on changing the fixed background for the background colors.
If I’m not mistaken there’s a header background and a page background correct?
3 לייקים
This is because the theme and its included components are fairly picky about how the site is set up.
In the OP I shared that:
6 לייקים
is there any way to make the background an image? i’d rather have an image than colors. using
body {
    background-image: url("image url here");
    background-color: #cccccc;
makes the top of the color thing the image, but not the bottom.
4 לייקים
What you did is fine to add the image, but you will also want to remove the clipping path that is created to give that overlay affect.
html .background-container {
clip-path: unset;
5 לייקים
