[2.4.0beta9] ActiveModel::MissingAttributeError (missing attribute: category_id)
Hi all,
after upgrading to latest, we started receiving this kind of error. Any ideas? :slight_smile:
This could be related to this error I just reported.
Message (5 copies reported)
ActiveModel::MissingAttributeError (missing attribute: category_id) /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activemodel-6.0.1/lib/active_model/attribute.rb:221:in `value’
Backtrace
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activemodel-6.0.1/lib/active_model/attribute.rb:221:in `value' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activemodel-6.0.1/lib/active_model/attribute_set.rb:41:in `fetch_value' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.1/lib/active_record/attribute_methods/read.rb:40:in `_read_attribute' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.1/lib/active_record/associations/belongs_to_association.rb:119:in `stale_state' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.1/lib/active_record/associations/association.rb:89:in `stale_target?' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.1/lib/active_record/associations/singular_association.rb:8:in `reader' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.1/lib/active_record/associations/builder/association.rb:100:in `category' /var/www/discourse/plugins/discourse-knowledge-base/plugin.rb:77:in `block (2 levels) in activate!' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/active_model_serializers-0.8.4/lib/active_model/serializer.rb:375:in `include?' (eval):8:in `_fast_attributes' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/active_model_serializers-0.8.4/lib/active_model/serializer.rb:468:in `rescue in attributes' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/active_model_serializers-0.8.4/lib/active_model/serializer.rb:455:in `attributes' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/active_model_serializers-0.8.4/lib/active_model/serializer.rb:480:in `_serializable_hash' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/active_model_serializers-0.8.4/lib/active_model/serializer.rb:359:in `serializable_hash' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/active_model_serializers-0.8.4/lib/active_model/array_serializer.rb:89:in `block in _serializable_array' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.1/lib/active_record/relation/delegation.rb:85:in `each' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.1/lib/active_record/relation/delegation.rb:85:in `each' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/active_model_serializers-0.8.4/lib/active_model/array_serializer.rb:79:in `map' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/active_model_serializers-0.8.4/lib/active_model/array_serializer.rb:79:in `_serializable_array' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/active_model_serializers-0.8.4/lib/active_model/array_serializer.rb:73:in `serializable_array' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/active_model_serializers-0.8.4/lib/active_model/array_serializer.rb:53:in `as_json' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.1/lib/active_support/core_ext/object/json.rb:172:in `block in as_json' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.1/lib/active_support/core_ext/object/json.rb:172:in `each' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.1/lib/active_support/core_ext/object/json.rb:172:in `map' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.1/lib/active_support/core_ext/object/json.rb:172:in `as_json' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.1/lib/active_support/core_ext/object/json.rb:172:in `block in as_json' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.1/lib/active_support/core_ext/object/json.rb:172:in `each' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.1/lib/active_support/core_ext/object/json.rb:172:in `map' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.1/lib/active_support/core_ext/object/json.rb:172:in `as_json' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.1/lib/active_support/json/encoding.rb:22:in `encode' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.1/lib/active_support/json/encoding.rb:22:in `encode' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.1/lib/active_support/core_ext/object/json.rb:42:in `to_json' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.1/lib/action_controller/metal/renderers.rb:157:in `block in <module:Renderers>' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/active_model_serializers-0.8.4/lib/action_controller/serialization.rb:50:in `block (2 levels) in <module:Serialization>' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.1/lib/action_controller/metal/renderers.rb:150:in `block in _render_to_body_with_renderer' /usr/local/lib/ruby/2.6.0/set.rb:338:in `each_key' /usr/local/lib/ruby/2.6.0/set.rb:338:in `each' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.1/lib/action_controller/metal/renderers.rb:146:in `_render_to_body_with_renderer' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.1/lib/action_controller/metal/renderers.rb:142:in `render_to_body' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.1/lib/abstract_controller/rendering.rb:25:in `render' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.1/lib/action_controller/metal/rendering.rb:36:in `render' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.1/lib/action_controller/metal/instrumentation.rb:44:in `block (2 levels) in render' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.1/lib/active_support/core_ext/benchmark.rb:14:in `block in ms' /usr/local/lib/ruby/2.6.0/benchmark.rb:308:in `realtime' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.1/lib/active_support/core_ext/benchmark.rb:14:in `ms' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.1/lib/action_controller/metal/instrumentation.rb:44:in `block in render' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.1/lib/action_controller/metal/instrumentation.rb:85:in `cleanup_view_runtime' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.1/lib/active_record/railties/controller_runtime.rb:34:in `cleanup_view_runtime' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.1/lib/action_controller/metal/instrumentation.rb:43:in `render' /var/www/discourse/plugins/discourse-data-explorer/plugin.rb:1234:in `block (2 levels) in run' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.1/lib/action_controller/metal/mime_responds.rb:214:in `respond_to' /var/www/discourse/plugins/discourse-data-explorer/plugin.rb:1209:in `run' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.1/lib/action_controller/metal/basic_implicit_render.rb:6:in `send_action' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.1/lib/abstract_controller/base.rb:196:in `process_action' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.1/lib/action_controller/metal/rendering.rb:30:in `process_action' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.1/lib/abstract_controller/callbacks.rb:42:in `block in process_action' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.1/lib/active_support/callbacks.rb:135:in `run_callbacks' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.1/lib/abstract_controller/callbacks.rb:41:in `process_action' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.1/lib/action_controller/metal/rescue.rb:22:in `process_action' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.1/lib/action_controller/metal/instrumentation.rb:33:in `block in process_action' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.1/lib/active_support/notifications.rb:180:in `block in instrument' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.1/lib/active_support/notifications/instrumenter.rb:24:in `instrument' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.1/lib/active_support/notifications.rb:180:in `instrument' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.1/lib/action_controller/metal/instrumentation.rb:32:in `process_action' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.1/lib/action_controller/metal/params_wrapper.rb:245:in `process_action' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.1/lib/active_record/railties/controller_runtime.rb:27:in `process_action' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.1/lib/abstract_controller/base.rb:136:in `process' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionview-6.0.1/lib/action_view/rendering.rb:39:in `process' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-mini-profiler-1.1.3/lib/mini_profiler/profiling_methods.rb:104:in `block in profile_method' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.1/lib/action_controller/metal.rb:191:in `dispatch' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.1/lib/action_controller/metal.rb:252:in `dispatch' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.1/lib/action_dispatch/routing/route_set.rb:51:in `dispatch' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.1/lib/action_dispatch/routing/route_set.rb:33:in `serve' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.1/lib/action_dispatch/journey/router.rb:49:in `block in serve' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.1/lib/action_dispatch/journey/router.rb:32:in `each' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.1/lib/action_dispatch/journey/router.rb:32:in `serve' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.1/lib/action_dispatch/routing/route_set.rb:837:in `call' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.1/lib/rails/engine.rb:526:in `call' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.1/lib/rails/railtie.rb:190:in `public_send' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.1/lib/rails/railtie.rb:190:in `method_missing' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.1/lib/action_dispatch/routing/mapper.rb:19:in `block in <class:Constraints>' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.1/lib/action_dispatch/routing/mapper.rb:48:in `serve' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.1/lib/action_dispatch/journey/router.rb:49:in `block in serve' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.1/lib/action_dispatch/journey/router.rb:32:in `each' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.1/lib/action_dispatch/journey/router.rb:32:in `serve' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.1/lib/action_dispatch/routing/route_set.rb:837:in `call' /var/www/discourse/lib/middleware/omniauth_bypass_middleware.rb:68:in `call' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.0.7/lib/rack/tempfile_reaper.rb:15:in `call' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.0.7/lib/rack/conditional_get.rb:38:in `call' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.0.7/lib/rack/head.rb:12:in `call' /var/www/discourse/lib/content_security_policy/middleware.rb:12:in `call' /var/www/discourse/lib/middleware/anonymous_cache.rb:318:in `call' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.0.7/lib/rack/session/abstract/id.rb:232:in `context' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.0.7/lib/rack/session/abstract/id.rb:226:in `call' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.1/lib/action_dispatch/middleware/cookies.rb:648:in `call' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.1/lib/action_dispatch/middleware/callbacks.rb:27:in `block in call' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.1/lib/active_support/callbacks.rb:101:in `run_callbacks' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.1/lib/action_dispatch/middleware/callbacks.rb:26:in `call' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.1/lib/action_dispatch/middleware/actionable_exceptions.rb:17:in `call' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.1/lib/action_dispatch/middleware/debug_exceptions.rb:32:in `call' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.1/lib/action_dispatch/middleware/show_exceptions.rb:33:in `call' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/logster-2.4.2/lib/logster/middleware/reporter.rb:43:in `call' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.1/lib/rails/rack/logger.rb:38:in `call_app' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.1/lib/rails/rack/logger.rb:28:in `call' /var/www/discourse/config/initializers/100-quiet_logger.rb:18:in `call' /var/www/discourse/config/initializers/100-silence_logger.rb:31:in `call' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.1/lib/action_dispatch/middleware/remote_ip.rb:81:in `call' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.1/lib/action_dispatch/middleware/request_id.rb:27:in `call' /var/www/discourse/lib/middleware/enforce_hostname.rb:17:in `call' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.0.7/lib/rack/method_override.rb:22:in `call' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.1/lib/action_dispatch/middleware/executor.rb:14:in `call' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.0.7/lib/rack/sendfile.rb:111:in `call' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.1/lib/action_dispatch/middleware/host_authorization.rb:77:in `call' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-mini-profiler-1.1.3/lib/mini_profiler/profiler.rb:296:in `call' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/message_bus-2.2.3/lib/message_bus/rack/middleware.rb:57:in `call' /var/www/discourse/lib/middleware/request_tracker.rb:181:in `call' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.1/lib/rails/engine.rb:526:in `call' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.1/lib/rails/railtie.rb:190:in `public_send' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.1/lib/rails/railtie.rb:190:in `method_missing' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.0.7/lib/rack/urlmap.rb:68:in `block in call' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.0.7/lib/rack/urlmap.rb:53:in `each' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.0.7/lib/rack/urlmap.rb:53:in `call' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/unicorn-5.5.1/lib/unicorn/http_server.rb:605:in `process_client' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/unicorn-5.5.1/lib/unicorn/http_server.rb:700:in `worker_loop' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/unicorn-5.5.1/lib/unicorn/http_server.rb:548:in `spawn_missing_workers' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/unicorn-5.5.1/lib/unicorn/http_server.rb:144:in `start' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/unicorn-5.5.1/bin/unicorn:128:in `<top (required)>' /var/www/discourse/vendor/bundle/ruby/2.6.0/bin/unicorn:23:in `load' /var/www/discourse/vendor/bundle/ruby/2.6.0/bin/unicorn:23:in `<main>'
Env
1/5
hostname physiart-app
process_id 9497
application_version ebe6fa95be55998937bafb08711cba65f7a0ef1e
HTTP_HOST rembetiko.gr
REQUEST_URI /admin/plugins/explorer/queries/-5/run
REQUEST_METHOD POST
HTTP_USER_AGENT Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/78.0.3904.108 Safari/537.36
HTTP_ACCEPT /
HTTP_REFERER https://rembetiko.gr/admin/plugins/explorer?id=-5
HTTP_X_FORWARDED_FOR 178.147.25.12, 162.158.158.230, 178.147.25.12
HTTP_X_REAL_IP 178.147.25.12
username chrispanag
time We 1:23 pm
params params {“months_ago”:“12”}
explain false
Did you disable all third party plugins and rebuild?
