Redirecting Old Forum URLs to New Discourse URLs using permalinks
If you’ve moved from other forum software to Discourse using one of our import scripts, then you probably want all your hard-earned Google search results to continue pointing to the same content. Discourse has a built-in way to handle this for you as an alternative to writing nginx rules, using the permalinks lookup table.
The permalinks table allows you to set two things: a url to match, and what that url should show. There are a few options for defining where the url should redirect to. Set one of these:
topic_id: to show a topic
post_id: to show a specific post within a topic
category_id: to show a category
tag_id: to show a tag
user_id: to show a user profile
external_url: to redirect to a url that may not belong to your Discourse instance
For example, if your original forum’s topic urls looked like http://example.com/discussion/12345, and the url for that topic after the import is http://example.com/t/we-moved/987, then you can setup the mapping like this:
cd /var/discourse
./launcher enter app
rails c
Permalink.create(url: '/discussion/12345', topic_id: 987)
Discourse will then perform a redirect with http response status code 301 (permanently moved) to the correct url for topic id 12345. The 301 should cause search engines to update their records and start using the new urls.
If you want some urls to redirect away from Discourse, you can do so by setting external_url:
Is it possible to store the rewrite rule directly in the discourse docker cluster? There is a web server that takes care of http and ssl, can I add something there?
if I call /threads/name.1234 then it is rewritten to /t/name and then it shows me the correct post, the id is not used at that moment, I just tested that.
Probably only when you’re lucky and Discourse and your old forum generate the same slugs (and the slug doesn’t start with a number), but that’s probably good enough.
If you want to change the NGINX as you suggest, you can look at the web template in discourse_docker to see how to change the nginx config inside the container. Here’s an example:
No. You’ll add that to your app.yml and it’ll get applied at every rebuild.
To save time testing you might:
cd /var/discourse
apt update
apt-get install -y vim nano
Then user vim or nano to edit whatever you want to see that it does what you think (and save 10-20 minutes per rebuild).You can restart nginx with `sv restart nginx.
None of the above is tested, but it should be close.
