merefield
(Robert)
14 februari 2022 om 10:27
1
“BBCode-lite” without the need to install a plugin …
Adds a simple control (palette icon) to the Composer to facilitate colouring of the foreground and background of text
Select a word or text
Hit the palette control
It will be wrapped like so: [wrap=color color=# bgcolor=#]word[/wrap]
Replace the #s with html-compatible colour names, e.g. “red”, “grey” … experiment.
NB Same caveats apply as to BBCode: can be used to hide text.
Credits
Thanks a ton for this useful little component.
It doesn’t seem to be applying the composer.color_ui_button_title properly, both when left at the default or when customized:
kainos
9 februari 2024 om 11:31
3
Hello there. I don t have color text button like on this foto. Here I don t see too.
Moin
9 februari 2024 om 11:36
4
This #theme-component is not installed here. That is why the button does not appear.
Did you add it to your site?
Robert:
kainos
9 februari 2024 om 11:47
5
If I knew how to add a plugin it would be good.
Moin
9 februari 2024 om 11:50
7
There is a guide how to Installing a theme or theme component
All the information is part of the table in the first post
Excellent component!
Bug report: If I click the palette button with no text selected, it inserts the translation descriptor instead of the ‘default text’:
[en_GB.composer.color_ui_default_text]
isn’t found in the site text customization menu, and isn’t on the component settings page.
Canapin
(Coin-coin le Canapin)
30 december 2024 om 13:55
11
Clicking the palette icon without having text selected output this:
[wrap=color color=# bgcolor=#][en.composer.color_ui_default_text][/wrap]
Is this a missing string?
merefield
(Robert)
30 december 2024 om 18:40
12
Canapin
30 december 2024 om 18:47
13
I didn’t even read the last message
nathank
(Nathan Kershaw)
30 december 2024 om 22:20
14
Awesome work @merefield ! This has been a sorely missing feature - until now!
I wonder if this could be combined with this TC to have a single super-awesome BBCode TC:
This theme component adds few formatting options in the composer : underline, align center, align right, justify and strikethrough. You can customize the text of each button in the settings, making it compatible with every languages. Exist in rtl version (change align right to align left).
