We want to update the Ember version used in Discourse.
Right now, we’re on 3.15, and we’d like to get to 4.1
We’ve set a goal to finish this work by the end of this year. Please note that this topic is a roadmap, and all the plans and estimates are tentative. This topic is not intended to house any significant discussions about particular upgrades or changes. So, let’s keep the conversation here a bit focused. Questions about how these updates will affect your site/plugin/theme are off-topic. The planned changes are 100% on the front-end (Ember app).
We’re going to be super careful about the changes we introduce. All the official plugins/themes will get updated (including any custom work CDCK has done for its customers). We’ll also send PRs to update all the popular unofficial plugins/themes.
No worries if you have a custom plugin/theme that you built for your site. We will add deprecation warnings and create the necessary announcements in a timely manner to give you enough time to make any changes required. We will also try to guide you through those changes if needed.
Let’s start with the goals. We obviously want to get to the highest version available, but we need to set intermediate goals between now and our final destination.
We plan to do incremental updates. Instead of one major update to 4.1, we’re going to break this work down into six stages. Each stage focuses on one Ember update.
| Stage | Size | Updates |
| 1 | size-l | Ember 3.15 → Ember 3.16 |
| 2 | size-m | Ember 3.16 → Ember 3.25 |
| 3 | size-xl | Ember 3.25 → Ember 3.26 (Part 1 - General) Ember 3.25 → Ember 3.26 (Part 2 - Templates) Ember 3.25 → Ember 3.26 (Part 3 - jQuery) Ember 3.25 → Ember 3.26 (Part 4 - Octane prep work) Ember 3.25 → Ember 3.26 (Part 5 - Octane) |
| 4 | size-l | Ember 3.26 → Ember 3.27 (Part 1 - General) Ember 3.26 → Ember 3.27 (Part 2 - RenderTemplate) Ember 3.26 → Ember 3.27 (Part 3 - Legacy built-in components) |
| 5 | size-s | Ember 3.27 → Ember 3.28 |
| 6 | size-s | Ember 3.28 → Ember 4.1 |
Choosing those specific versions is entirely based on the deprecations and amount of work they introduce - and the implied risk.
So, let’s break those down further for more clarity.
Deprecations per update
Stage 1 (size-l)
This update only introduces one deprecation.
Use ember-CLI resolver rather than legacy globals resolver
- until: 4.0.0 - size-lDiscourse has its own custom resolver that currently extends
Ember.DefaultResolver.The recommended fix is to do away with any custom resolvers and use the Ember-CLI resolver. This is easier said than done because we have quite a bit of custom logic to handle plugins and themes.
A compromise that works is to extend the Ember-CLI resolver instead of extending
Stage 2 (size-m)
This update introduces eight deprecations.
Use Ember getter and explicitly check for undefined
- until: 4.0.0 - size-sThis is a simple deprecation. We only need to removegetWithDefaultin our codebase, and there are only a few places where we use it. -
String prototype extensions
- until: 4.0.0 - size-mThis is also a simple, low-risk swap, but we use Ember’s extended string prototype in quite a few places. From a quick check, I think we have about < 100 places where we do that between core and plugins/themes.Once we update those, we should also prevent Ember from extending that prototype with something like this.EXTEND_PROTOTYPES: { String: false }in our environment file.
ImportinghtmlSafeandisHTMLSafefrom @ember/string
- until: 4.0.0 - size-mThere’s much overlap between this and #7 in this update, and it should be straightforward and low-risk.
Stage 3 (size-xl)
The upgrade from 3.25 to 3.26 is quite involved. This is where we do most of the “catching up.” There are sixteen deprecations in total. We’re going to break up this update into five parts - where we only do a version bump after all the deprecations have been handled.
This part deals with nine deprecations that are relatively easier to handle.
Transition methods of routes and controllers
- until: 5.0.0 - size-mThis deprecation removes a couple of methods from
routesandcontrollers. It may look like it’s an involved change, but it should be straightforward. We’d only need to inject theRouteras a service and call them from there instead - when required. The tricky part is that we use those in many places, and they all need to be updated. -
Browser Support Policy
- until: 4.0.0 - size-s~~This should be a relatively simple change. Ember won’t support IE11 from 4.0 onwards. The nice thing here is that we haven’t supported it for a long time anyway. The only thing we need to change is to stop transpiling for IE11 in production.
discourse/app/assets/javascripts/discourse/config/targets.js at 1472e47aae5bfdfb6fd9abfe89beb186c751f514 · discourse/discourse · GitHubI did some basic testing, and this change will save us about 60kb (gzip) or ~6% of our main and vendor bundles in production Ember-CLI installs. -
{{hasBlock}} and {{hasBlockParams}}
- until: 4.0.0 - size-sWe use these in a couple of places. This is a simple, low-risk rename. -
{{with}}helper
- until: 4.0.0 - size-sWe rarely use this, but it still needs fixing. We just need to swap them out and use{{let}}or a combination of{{if}}/{{else}}
This part will primarily focus on deprecations involving .hbs templates. There are three deprecations that we need to focus on here.
Property Fallback Lookup
- until: 4.0.0 - size-lStarting from Ember 4.0, this won’t work anymore.
Hello, {{name}}!If we have a property in a template, we have to look it up with a preceding
thislike soHello, {{this.name}}!We’d have to do that with all of our templates. There are ways to reduce the pain here. We can try the ember-no-implicit-this-codemod and see how far it gets us.
I’m in favor of limiting changes to 1 file per PR. This makes it easy to review - and revert if something goes wrong.
Accessing named args via {{attrs}}
- until: 4.0.0 size-xlThe
{{attrs}}object is going to be dropped in Ember 4.0. The change itself is very straightforward, and Ember’s example is quite nice.Before:
{{attrs.foo}} {{this.attrs.foo.bar}} {{deeply (nested attrs.foobar.baz)}}After:
{{@foo}} {{@foo.bar}} {{deeply (nested @foobar.baz)}}We’d have to do this for all of our templates. We can combine this change with converting the templates to the angle-bracket syntax. I’m a huge fan of angle brackets because they’re much closer to the standard custom web-components syntax.
One thing that might expedite our progress here is the ember-angle-brackets-codemod. We’ll have to experiment with it and see how far it takes us. It handles the deprecation and gives us shiny angle-bracket syntax.
Similar to #1 in this part, I also favor fixing and testing one template per PR.
<LinkTo>positional arguments
- until: 4.0.0 - size-mThis is also a deprecation that aims to reduce confusion. There are a few places where we use positional arguments on link-to. We can fix those like so
Before:
{{link-to "About Us" "about"}} {{#link-to "about"}}About Us{{/link-to}} {{#link-to "post" @post}}Read {{@post.title}}...{{/link-to}}After (with angle brackets):
<LinkTo @route="about">About Us</LinkTo> <LinkTo @route="about">About Us</LinkTo> <LinkTo @route="post" @model={{@post}}>Read {{@post.title}}...</LinkTo>
There’s not much I can say about this that you don’t already know. New Ember apps don’t use jQuery, and it will be dropped in Ember 4.0.
In this part, we’ll focus on one deprecation.
Optional Feature: jquery-integration
- until: 4.0.0 - size-xlOver the last couple of years, we’ve made a ton of progress in reducing our jQuery usage. There are still places where we need it, particularly in the composer and as a dependency for some vendor libraries we use. I don’t want to get into the details of this change here. Long story short, we should move away from using jQuery.
However, I would like to highlight that even if we get rid of jQuery EVERYWHERE, we should still keep this option set to true until we’re ready for Ember 4.0. We need a plan to ease the transition for sites with custom themes/plugins that we do not control. In other words, let’s do the work but live with the deprecation warning about turning the option off.
In this part, we should focus on getting our files ready for Octane. We will handle two deprecations.
Optional Feature: template-only-glimmer-components
- until: 4.0.0 - size-mThis is a simple change in theory, but there’s implied work we need to do before we can toggle that option.
We need to ensure that our current template-only components work with glimmer semantics. I did some testing, and our tests choked with that option turned on. Here’s an example list of some template-only components we have in core
- app/templates/components/activation-email-form.hbs - app/templates/components/cancel-link.hbs - app/templates/components/categories-with-featured-topics.hbs - app/templates/components/category-name-fields.hbs - app/templates/components/color-input.hbs - app/templates/components/custom-html-container.hbs - app/templates/components/emoji-group-buttons.hbs - app/templates/components/emoji-group-sections.hbs - app/templates/components/empty-state.hbs - app/templates/components/ip-lookup.hbs - app/templates/components/modal-footer-close.hbs - app/templates/components/popup-menu.hbs - app/templates/components/reviewable-created-by-name.hbs - app/templates/components/reviewable-created-by.hbs - app/templates/components/reviewable-field-editor.hbs - app/templates/components/reviewable-field-text.hbs - app/templates/components/reviewable-field-textarea.hbs - app/templates/components/reviewable-field.hbs - app/templates/components/reviewable-flagged-post.hbs - app/templates/components/reviewable-post-header.hbs - app/templates/components/reviewable-post.hbs - app/templates/components/reviewable-scores.hbs - app/templates/components/reviewable-tags.hbs - app/templates/components/reviewable-topic-link.hbs - app/templates/components/score-value.hbs - app/templates/components/selected-posts.hbs - app/templates/components/subcategories-with-featured-topics.hbs - app/templates/components/text-overflow.hbs - app/templates/components/user-fields/confirm.hbs - app/templates/components/user-fields/dropdown.hbs - app/templates/components/user-fields/multiselect.hbs - app/templates/components/user-fields/text.hbs - app/templates/components/user-profile-avatar.hbs - app/templates/components/user-summary-users-list.hbsWe’ll also need to check our Admin/theme/plugin templates and ensure everything works before shipping that option.
Off the top of my head, I’m not exactly sure how our raw
.hbrtemplates will fit into this. However, @david has been working on glimmer-based topic lists. So, maybe we can do away with raw templates altogether. -
Implicit Injections
- until: 4.0.0 size-xlWe use implicit injections everywhere. We do this in an initializer like so
discourse/app/assets/javascripts/discourse/app/pre-initializers/inject-discourse-objects.js at ac79c5efc61d259705eeb487ca21d0ec3c535807 · discourse/discourse · GitHubEmber is moving away from implicit injections. The preferred path forward is to convert as many of our objects as possible to services and explicitly inject them where they’re needed. Of course, there might be a few things where a service is not ideal. In those cases, we can lookup those objects directly when they’re needed like so
getOwner(this).lookup('thing:main')Another option we have (depending on performance implications) is to wrap the Ember Classes with our own Discourse Class. We’d then use our Class throughout the app. Kind of like we do with the
GlimmerComponent Class
discourse/app/assets/javascripts/discourse/app/components/glimmer.js at fa0c796baf9a7f64a3b27823b1aa4b370a74c3eb · discourse/discourse · GitHub. This would make this task a size-l or even size-mIn any case, this change will need some thinking.
This is the final stretch of the 3.25 → Ember 3.26 upgrade. We will only have one deprecation left at this point, but it’s a big one.
Edition: Classic
- until: 4.0.0 - size-xlBefore can flick our version to Octane, I’d like to spend time converting our Classes to native Classes and our components to Glimmer components. There will be a bit of pain involved, but it’s worth it. The ember-native-class-codemod should alleviate some of that pain. We’ll have to see how far it takes us.
There are a lot of considerations and workflow issues to keep in mind. The only thing I want to highlight is that it will follow the same flow I mentioned for templates - fix and test 1 component per PR.
Stage 4
The Ember 3.26 → Ember 3.27 update introduces twelve deprecations. I propose we split them into three parts. We will do the version bump after all the deprecations have been handled.
Ember 3.26 → Ember 3.27 (part 1 - General)
Deprecate
Route#disconnectOutlet
- until: 4.0.0 - size-sWe only do this in one place. It’s the
build-category-route, and it should be straightforward to fix. -
Invoking Helpers Without Arguments and Parentheses In Named Argument Positions
- until: 4.0.0 - size-sI don’t think we do this anywhere, but I will confirm when the time comes. Essentially, calling a helper without passing it any arguments.
Even if we use something like that, we’d only need to add parentheses. So, this
<SomeComponent @arg={{someHelper}} />becomes
<SomeComponent @arg={{(someHelper)}} />note the parentheses around
someHelper -
Run loop and computed dot access
- until: 4.0.0 - size-mWe use
.to accesscomputedfunctions in ourdecoratorsaddon. They look like this, for example
discourse/app/assets/javascripts/discourse-common/addon/utils/decorators.js at b05fddaa7ce3968ffc70cd8d4bf290e15d06eb11 · discourse/discourse · GitHubWe also have a stray one-off here and there. As far as I can tell, fixing those is mostly about fixing how we import them.
So,
computed.filtershould be imported like this instead.import { filter } from '@ember/object/computed';Our version of the external vendor
buffered-proxyaddon uses.to accesscomputedfunctions; we’d need to bump it.We also use
.to accessrunfunctions in a few places. That said, the same fix applies. We need to update the way we import them. I think themes and plugins especially might have quite a few places where we do that withrun -
Deprecate the Ember Global
- until: 4.0.0 - (#size ?)Emberwon’t be available in the global context after 4.0. It’s hard to estimate the amount of work/impact here without a deeper look. That said, I know @cvx has been doing tons of work to get rid of this pattern.
Ember 3.26 → Ember 3.27 (part 2 - renderTemplate)
This part will only focus on one deprecation.
Deprecate
Route#renderTemplate
- until: 4.0.0 - size-lIn a nutshell, we can’t use named outlets in Ember 4.0. So, this won’t work.
{{outlet "thing"}}We use
renderTemplatein almost 30 places in core alone. The upgrade itself seems pretty straightforward. We can use{{#in-element}}and a plain empty HTML element as a placeholder for what we used to render in named outlets.
Ember 3.26 → Ember 3.27 (part 3 - Legacy built-in components)
This part will focus on built-in legacy components, and it will handle four deprecations.
- Importing Legacy Built-in Components
- until: 4.0.0 - Built-in Components Legacy Arguments
- until: 4.0.0 - Built-in Components Legacy HTML Attribute Arguments
- until: 4.0.0 - Reopening Legacy Built-in Components
- until: 4.0.0
I didn’t add sizes to these because… it really depends. Let me explain.
Legacy built-in components like Checkbox, TextField, TextArea, and LinkComponent will be removed in Ember 4.0. We use them in quite a few places, and we also use some deprecated patterns on them.
Ember offers an upgrade path that allows us to keep using them, but we have to import them differently. However, they will not receive any updates from Ember and will remain frozen. I’m hoping that we can do away with all of them; however, that might be a bit involved. This change will need more discussion when the time comes.
Stage 5
This is a size-s since it’s only a version bump. 3.28 is the last LTS release in the 3.x development cycle. It doesn’t introduce any new deprecations after 3.27, and it’s a good version for us to stop on for a few weeks while things settle down.
3.28 LTS is supported through August 2022 (both bug fixes and security patches)
This “break” has a few benefits.
- It gives us more time to see if any issues arise
- when we ship a stable version, it should be on 3.28
- it gives us time to make any announcements we need to make regarding self-maintained themes and plugins
- it gives us time to ensure that the jQuery → no jQuery is as smooth as possible.
Stage 6
After a few weeks pass, we can finally bump our version to Ember 4
We can now toggle the optional jQuery integration off as the last deprecation from the 3.x cycle.
This update introduces two minor deprecations.
Deprecate Ember.assign
- until: 5.0.0 - size-sWe don’t use that in core, but we’ll need to check themes/plugins. In any case, it’s a simple rename. -
AutoLocation Class
- until: 5.0.0 - size-sIn theory, we’d only need to change
locationType: 'auto'tolocationType: 'history'in our Ember environment file, and it should just work.
Workflow
As I mentioned at the start, we will be very careful with these updates. We will test/fix/pin all the official plugins/themes with every update, and we’ll also send PRs to popular unofficial plugins/themes.
The goal here is not to slow down development or create headaches. So, the PRs should will be strictly-scoped, with one change per PR and nothing too large.
In an ideal world, all of the changes would happen in the background without interrupting anyone else’s work. This is why we plan to keep the PRs short and sweet. Also, we’re not too fond of mixed patterns. So, we don’t want to get stuck in an interim state on a per-file basis. A component is either classic or Glimmer, and a template either uses curly braces or angle brackets, nothing in between.
I hope this road map was clear. Like I mentioned in the beginning, this is just a general top-level overview. If anything is unclear, incorrect, or doesn’t sit right with you, please let us know.
