Blokken rechterzijbalk
:discourse2: Summary Right Sidebar Blocks shows a sidebar to the right of topic lists with a configurable list of blocks.
:eyeglasses: Preview Preview on Discourse Theme Creator
:hammer_and_wrench: Repository Link https://github.com/discourse/discourse-right-sidebar-blocks
:open_book: New to Discourse Themes? Beginner’s guide to using Discourse Themes
Install this theme component
Features
The component includes a few blocks you can display in the sidebar:
  • popular-tags
  • top-contributors
  • recent-replies
  • category-topics
  • custom-html
  • category-list
  • subcategory-list
  • upcoming-events-list*
  • minimal-gamification-leaderboard**
:information_source: The user directory must be enabled for the Top Contributors list to be populated. If your list is blank, search enable user directory in your admin settings to make sure it’s enabled.
* Only available when used with the Calendar plugin.
** Only available when used with the Gamification plugin.
You can also use other Ember components as blocks, you just need to use the correct name. For example, core includes a signup-cta Ember component, and you can use it in the sidebar as is. Note that you can’t use components that expect a set of parameters, but you can build your own Ember component in a separate theme and reference it just by its name in the sidebar’s blocks setting.
You can control some features for the provided blocks via parameters.
name description default value available for
count limits number of results varies number all except custom-html
excerptLimit limits length of each reply excerpt 150 number recent-replies
id category id category id (category-list uses comma-separated) category-topics, category-list
content contents to display html custom-html
scopeToCategory only shows in category or subcategory X category id popular-tags
excludedTags list of excluded tags tagnames popular-tags
displayInSpecificCategories list of categories to show the widget all comma-separated numbers popular-tags
id leaderboard id number minimal-gamification-leaderboard
tag which tag to display tag name tag-topics
period time period of top topics weekly all, yearly, quarterly, monthly, weekly, daily top-topics
title title of the block varies string tag-topics, category-list, top-contributors
excludedGroupNames excludes specified groups Group names top-contributors
order orders the contributors String (likes_received or likes_given) top-contributors
period time period for top contributors yearly all, yearly, quarterly, monthly, weekly, daily top-contributors
includeSubcategories includes subcategory events false false, true upcoming-events-list
upcomingDays events started before the provided value 180 number upcoming-events-list
timeFormat format of event date / time LT momentjs format upcoming-events-list
Settings
Name Description
blocks
show in routes Advanced users only: limit sidebar to the selected routes.
Examples: discovery.latest, discovery.unread, discovery.new, discovery.top, tag.show, “c/category-slug” (for categories), “tag/sample-tag” (for tags).
When empty, the sidebar is shown on all list routes.
blocks: choose the blocks to display and adjust their ordering
show_in_routes: decide on which topic list routes to display the sidebar. By default, it will show it on all discovery routes except for /categories.
Translation Default
top_contributors.heading Top contributors
top_contributors.view_all View all
popular_tags.heading Popular tags
popular_tags.view_all View all
recent_replies.heading Recent replies
subcategory_list.heading Subcategories
top_topics.heading Top topics
category_list.heading Categories
Screenshots
Note that the component comes with only very basic styling, the assumption is that admins using the component will add their own styling in their own theme.
Interactions
When used in conjunction with the Discourse Calendar plugin, you can add a sidebar block for your upcoming events. The block name is upcoming-events-list, and the date format can be customized following this syntax (for example, MMMM D, YYYY ). You can also configure how far in the future to look, and if subcategory events are included (see the table above)
:discourse2: Hosted by us? Theme components are available to use on our Pro, Business, and Enterprise plans.
Discourse Gamification
Sidebar for Subcategories
Add User leaderboard in sidebar
FKB Pro - Social theme
Setup Continuous Integration using GitHub Actions
Blogroll (feature request)
How to extend the Discourse sidebar?
How to include a YouTube video or video widget on the community home page?
Adding a recent comments widget
How do you force keep open the sidebar?
Add social media handles on home page
Alternate presentation of sub-categories which puts the _top_ category first?
Discourse Bars :beers: :cocktail: (a sidebar framework)
Looking for the perfect theme
Add right sidebar gamification mini-leaderboard
Pyx's Modern Theme
Homepage Blocks
Topic List Excerpts
🏷️ Bars Tag List Component
Creating a 'Blocks' API for injecting content
When to switch themes/plugins to `.gjs`?
Recent replies takes 2 seconds to display
Leaderboard in homepage
Discourse Gamification Plugin in the Header
Discourse Calendar updated to use fullcalendar 6
I'm getting errors when I switch categories too quickly
目前我感觉看到的最好看的Discourse主题,有没有谁能爱心奉献一个
Discourse Sidebar Blocks
Tag Icons + Tag Banners + Right Sidebar Blocks
Topic List Previews (TLP)
Hide admin user from user-directory and top contributors
Feedback wanted: userscript to theme component/plugin, or possible core sidebar browsing idea?
Have the upcoming-events block respect the subcategory filter when in Category lists
A reddit-ish theme for Discourse
Cache the right hand sidebar contents
Using Discourse to Build a Blog, Reddit, X or Facebook-Style Scrolling Platform
Adding ‘hot topics’ to the Sidebar
Custom Components -- add button or text at any plugin outlet
Top Posters Widget?
Creating a Top 20 leaderboard for a specific date range
Connectors not rendering
Displaying tags along with categories
Creating and managing events
Customizing your site with existing theme components
Creating and installing plugins?
What should I add in the “name” parameter if I use custom-html?
Great to see this as an official Theme Component! It certainly opens up a new world of customisations.
I’ve got 2 questions:
  1. In the sidebar, I want to display the /latest topic list similar to the way that category-topics displays them. Is this possible? recent-replies almost gets there (especially if the excerpt is hidden), but I really want to include topics without replies.
  2. Is it possible to only display the sideblocks in certain categories? What I mean is that the only route displayed is the Category Topic List, and only for the categories I specify.
Apologies, the documentation for this is lacking (I will update it now). The name of the param for custom-html is content.
We don’t have anything ready-made for the full /latest list, but you build your own and add it to the configuration using its name. Should be very similar to the category/tag lists, just without a filter.
Currently, no, you can’t show it on specific categories only. You can however use discovery.category in the show in routes setting, that will only show the sidebar on category routes (but on all of them, not a subset).
Thank you, is it possible to include the sidebar in each topic as well?
Just noted a limitation of the component, especially when it comes the category-topics & subcategory-list blocks, and that is adding multiple blocks of either of these types with different id always resulted in them surfacing topics/subcategories of the uppermost block in the launch editor (I assume).
One bug I’m having right now is after playing around with the subcategory-list block for around 10-12 times, it stop showing altogether on our staging site (see video below).
The subcategory-list block does not take a parameter at all. When used, it will show the subcategories of the current category based on which current category you have navigated to… so it doesn’t make sense to use that block more than once.
That is also why the subcategory-list isn’t showing in your video. If you’re on a non-category route, that block does not show.
For category-topics, in your video I see the same ID used twice: 7. I did a local test and with different IDs I get different topics displayed (i.e. I can’t reproduce the reported bug).
Hi, a huge thank you for this awesome plugin!
I’ve got a question about the subcategory-list sidebar: is there an option to display it only for a particular category?
Our developers have had a look, and it seems there is no parameter id support for subcategory-list, is this something you could add, please?
And regarding the top-contributors block: is there a way to fetch the results for a period of a week?
Currently, no, this option does not exist. It makes sense to add it, although, I would imagine that it should support multiple IDs so you can show the block for a list of categories (A, B and C, for example). I am happy to review PRs on the repo, if your developers think they can add this, that would be great. (Otherwise, I can add it to a list of nice-to-haves in the theme component.)
Do you mean a) to fetch the results and cache them for a week or b) to fetch the top contributors for the last week on every load? The latter should be easy to add, caching is a little trickier.
@pmusaraj can you add
padding: 3px 4px 3px 4px
for the popular-tags ?
Thanks.
Hi @pmusaraj, thanks a lot for your reply!
Our developer has shared the PRs here, please have a look: Implement the `displayInCategories` parameter which allows to specify a list of categories where the `subcategories-list` block is displayed by d521bb85 · Pull Request #10 · discourse/discourse-right-sidebar-blocks · GitHub
The second variant would be perfect! We need to display the list of top contributors for the last week indeed. Thank you so much!
The component intentionally has very little styling so that consumers can add their own styles in their own themes/theme components.
Thanks, that PR is great and it’s now merged!
I will also shortly work on adding configurability to the top contributors block (or if someone else is faster, happy to review a PR).
I’m not sure where to find the code for that - would you mind directing me? I’d like to look at modifying the category-topics so that having no ID gives you all categories (and thus effectively the /latest list)
It would be great to have that in all the blocks!
@pmusaraj Awesome! Thank you so much for your help, looking forward to using the top contributors block :slight_smile:
Hi! I’m not sure if this component is causing errors. But once disabled, there are no more errors seen. :thinking: Could someone take a look at this to help me figure out the issue? Would appreciate it a lot.
With it enabled, visiting a certain topic on desktop, clicking the site logo in the top bar in the attempt to return to the homepage would bring me to a never-disappearing loading screen and throw errors in the browser console (as below). No related error logs seen in the mysite/logs path.
d6ca234baf8d2d5e65f414f31e198fe956d9a939.js?__ws=www.bfsu.cafe:98 Uncaught (in promise) TypeError: Cannot read properties of undefined (reading 'findFiltered')
    at new CategoryTopics (d6ca234baf8d2d5e65f414f31e198fe956d9a939.js?__ws=www.bfsu.cafe:98:18)
    at h.createComponent (base-component-manager.js:37:1)
    at h.createComponent (ember-component-manager.js:54:1)
    at C.create (manager.js:558:1)
    at Object.evaluate (runtime.js:3301:1)
    at Object.evaluate (runtime.js:1312:1)
    at Dt.evaluateSyscall (runtime.js:5232:1)
    at Dt.evaluateInner (runtime.js:5188:1)
    at Dt.evaluateOuter (runtime.js:5180:1)
    at Wt.next (runtime.js:6191:1)
    at Wt._execute (runtime.js:6175:1)
    at Wt.execute (runtime.js:6166:1)
    at qt.handleException (runtime.js:5369:1)
    at Kt.handleException (runtime.js:5605:1)
    at Lt.throw (runtime.js:5302:1)
    at Be.evaluate (runtime.js:2580:1)
    at Lt._execute (runtime.js:5285:1)
    at Lt.execute (runtime.js:5266:1)
    at Ht.rerender (runtime.js:5634:1)
    at Er.render (index.js:7578:1)
    at index.js:7896:1
    at It (runtime.js:5074:1)
    at Rr._renderRoots (index.js:7876:1)
    at Rr._renderRootsTransaction (index.js:7928:1)
    at Rr._revalidate (index.js:7970:1)
    at invoke (backburner.js:351:1)
    at p.flush (backburner.js:241:1)
    at h.flush (backburner.js:447:1)
    at q._end (backburner.js:999:1)
    at _boundAutorunEnd (backburner.js:648:1)
CategoryTopics @ d6ca234baf8d2d5e65f414f31e198fe956d9a939.js?__ws=www.bfsu.cafe:98
createComponent @ base-component-manager.js:37
createComponent @ ember-component-manager.js:54
create @ manager.js:558
(匿名) @ runtime.js:3301
evaluate @ runtime.js:1312
evaluateSyscall @ runtime.js:5232
evaluateInner @ runtime.js:5188
evaluateOuter @ runtime.js:5180
next @ runtime.js:6191
_execute @ runtime.js:6175
execute @ runtime.js:6166
handleException @ runtime.js:5369
handleException @ runtime.js:5605
throw @ runtime.js:5302
evaluate @ runtime.js:2580
_execute @ runtime.js:5285
execute @ runtime.js:5266
rerender @ runtime.js:5634
render @ index.js:7578
(匿名) @ index.js:7896
It @ runtime.js:5074
_renderRoots @ index.js:7876
_renderRootsTransaction @ index.js:7928
_revalidate @ index.js:7970
invoke @ backburner.js:351
flush @ backburner.js:241
flush @ backburner.js:447
_end @ backburner.js:999
_boundAutorunEnd @ backburner.js:648
Promise.then(异步)
n @ backburner.js:28
flush @ index.js:46
_scheduleAutorun @ backburner.js:1218
_end @ backburner.js:1009
Promise.then(异步)
flush @ index.js:46
Promise.then(异步)
flush @ index.js:46
Promise.then(异步)
flush @ index.js:46
_ensureInstance @ backburner.js:1206
scheduleOnce @ backburner.js:845
k @ index.js:522
queueRerender @ mount-widget.js:124
scheduleRerender @ widget.js:319
rerenderResult @ widget.js:365
F @ hooks.js:207
(匿名) @ hooks.js:247
dispatch @ jquery.js:5430
_.handle @ jquery.js:5234
frame:251 You dismissed the flag, but third party cookies are disabled on your browser so the flag will come back the next time you visit the page.
I see info about this component in the js file mentioned in the first line of the error log above.
// line 96-103 of d6ca234baf8d2d5e65f414f31e198fe956d9a939.js?__ws=www.bfsu.cafe
      const filter = "c/" + categoryId;
      this.category = _category.default.findById(categoryId);
      this.store.findFiltered("topicList", {
        filter
      }).then(result => {
        const results = result.topic_list.topics;
        results.forEach(topic => {
          topic.url = "".concat((0, _getUrl.default)("/t/")).concat(topic.slug, "/").concat(topic.id);
Ah, yes, sorry about that. It should be fixed now, you just need to pull the latest update of the theme component.
Thanks! Works great now.
Hi @pmusaraj, sorry if I’m coming over as pushy - just wanted to know if there’s any ETA regarding this implementation.
It would be an awesome addition :slight_smile:
Thank you so much!
Thank you for this awesome component!
I noticed that my entire header and footer disappears globally when I have this enabled (everything in my header.html and footer.html). Was this intentional? But to work around this I have to use the PluginAPI to manually add a header/footer.
